Home » Language IDEs » C / C++ IDE (CDT) » multiplatform projects
multiplatform projects [message #137648] |
Fri, 04 February 2005 15:04 |
Originally posted by: nik.cain.neuf.fr
My projects are compilable on both linux and windows (mingw), requiring
only a few different build settings (-DWin32 for example). However,
it seems that a CDT project has a single platform (ie GNU on Windows),
and I can't have a single project which can be either 'GNU' *or* 'GNU on
Windows' (depending on build configuration chosen, ie Win32_Debug,
Linux_Debug etc).
And since a folder can only have one project in it, I'm a bit stuck.
My only option looks like using standard makefiles, but I don't want to
do that since they give me a headache - is there any way to do this with
managed make?
nik
Re: multiplatform projects [message #137685 is a reply to message #137661] |
Fri, 04 February 2005 15:46 |
I've set those settings in a new build configuration (clicking the
'Manage' button, I created Linux_Debug from the default Debug config - I
did this while running eclipse on linux, although the project was
originally created on windows), but it failed to build on linux. The
makefile created had this in it;
myTarget.so: $(OBJS) /home/me/otherlib/libblah.a
@echo 'Building target: $@'
null null $@ $(OBJS) $(USER_OBJS) $(LIBS)
@echo 'Finished building: $@'
Those null's should be g++ and -o, just the same as the windows build.
In the Tool Settings Command box (when C++ Compiler item is selected) it
says g++
In the .cdtbuild file, the newly created Linux_Debug Configuration is;
<configuration
id="cdt.managedbuild.config.gnu.cygwin.lib.debug.747260194"
name="Linux_Debug" parent="cdt.managedbuild.config.gnu.cygwin.lib.debug"
artifactName="CMLicense"
errorParsers=" org.eclipse.cdt.core.MakeErrorParser;org.eclipse.cdt.core.GC CErrorParser;org.eclipse.cdt.core.GLDErrorParser;org.eclipse .cdt.core.GASErrorParser "
artifactExtension="a" cleanCommand="rm -rf">
It looks like it inherited the cygwin settings, so maybe that's messing
something up when running on linux. A further clue is in the C/C++ Build
dialog the project type is still 'Gnu on Windows' (uneditable, ie greyed
out).
nik
SpeedadeYxa wrote:
> I think You can,
> Project/Properties/C/C++ Build/Configuration/Tool Settings.
> Add as many Configurations you need.
> Change command line stuff under Tool Settings for each configuration.
> Just don't know a easy way of changing active configuration without
> going in to Properties again.
>> requiring only a few different build settings (-DWin32 for example).
>> However, it seems that a CDT project has a single platform (ie GNU on
>> Windows), and I can't have a single project which can be either 'GNU'
>> *or* 'GNU on Windows' (depending on build configuration chosen, ie
>> Win32_Debug, Linux_Debug etc).
>> to do that since they give me a headache - is there any way to do this
>> with managed make?
>> nik
Re: multiplatform projects [message #137697 is a reply to message #137685] |
Fri, 04 February 2005 16:04 |
I've found the problem - setting the artifact extension ( .exe ) to
nothing causes those nulls. Guess I'll just have to live with my
executables on linux having extensions for a while...
nik
> says g++
> <configuration
> out).
> nik
> SpeedadeYxa wrote:
>> I think You can,
>>> example). However, it seems that a CDT project has a single platform
>>> (ie GNU on Windows), and I can't have a single project which can be
>>> either 'GNU' *or* 'GNU on Windows' (depending on build configuration
>>> chosen, ie Win32_Debug, Linux_Debug etc).
>>> this with managed make?
>>> nik
Re: multiplatform projects [message #137709 is a reply to message #137697] |
Fri, 04 February 2005 16:20 |
ah, perhaps not the entire problem - shared objects still produce that
'null null' in the makefile, reagardless of extension...
Any help would be much appreciated,
nik
> nik
>> I did this while running eclipse on linux, although the project was
>> it says g++
>> <configuration
>> name="Linux_Debug"
>> errorParsers=" org.eclipse.cdt.core.MakeErrorParser;org.eclipse.cdt.core.GC CErrorParser;org.eclipse.cdt.core..GLDErrorParser;org.eclips e.cdt.core.GASErrorParser "
>> messing something up when running on linux. A further clue is in the
>> C/C++ Build dialog the project type is still 'Gnu on Windows'
>> (uneditable, ie greyed out).
>> nik
>> SpeedadeYxa wrote:
>>> I think You can,
>>>> nik
Current Time: Thu Oct 10 10:10:57 GMT 2024
Powered by FUDForum. Page generated in 0.03421 seconds
