Home » Language IDEs » C / C++ IDE (CDT) » CDT help enchancement - Variuos questions
CDT help enchancement - Variuos questions [message #137631] Fri, 04 February 2005 15:04 Go to next message
Pelle Svensson is currently offline Pelle SvenssonFriend
Member
I'm interested to know what status the integrated help enhancement has.
Reading bug 71240 indicated that there are activities in the same
direction as I am looking. The diagram gives a good picture but on
the same time raise some questions about the provider's capability.
Specially what kind of format or structure will the information/help
have.
Some reflections which also applies for the normal help window:
1. Storage format (XML) should have usable tags.
API and example tags are important.
2. Indexing should be able of multiple views, i.e.
Searching for something can be sorted in any order.
Then you can exclude what is irrelevant.
Books/Chapter/Section/<tags>
<tags>/Books/Chapter/Section
3. Hierarchy result presentation.
Google has a good presentation. You can easily ready
a short piece of the information without scrolling
the hole document.
A good presentation is:
/Book/Chapter/Section/<hit summary
4. Sub query, i.e. a secondary query can be applied
on the result set. When the total help data is large
number of hits may be too long and a sub filtering
is handy for tracking down.
5. Good content assistant help.
Hover and F1 help should popup some kind of dialog/
window (set focus F2). As example: Hitting F1 shows
a hit list of 20 items (see 3), navigating to the
one of interest, select Example or API and hit past.
Dose the proposed implementation include something
like this then I would be more than happy.
Are there any patch or stuff ready for testing.
Are there need of help with cooding.
71240: (https://bugs.eclipse.org/bugs/show_bug.cgi?id=71240)
diagram: (https://bugs.eclipse.org/bugs/attachment.cgi?id=14398)
Re: CDT help enchancement - Variuos questions [message #137876 is a reply to message #137631] Fri, 04 February 2005 17:39 Go to previous messageGo to next message
Originally posted by: alain.nowhere.ca
Yes the head and CDT-2.1
Help is more then welcome, you seem to have some good ideas
if you can code it ... we'll accept it 8-)
> have.
> the hole document.
Re: CDT help enchancement - Variuos questions [message #137920 is a reply to message #137876] Fri, 04 February 2005 18:33 Go to previous message
Member
Ok, will take look and see what it is.
>> have.
>> the hole document.
Previous Topic:Linking static winsock library
Next Topic:Content Assist Key Binding + Emacs Mode
Current Time: Thu Dec 26 22:51:42 GMT 2024
Powered by FUDForum. Page generated in 0.03276 seconds
