Home » Archived » XML Schema Definition (XSD) » XSD Schema schema discovery problem
XSD Schema schema discovery problem [message #1043] Thu, 26 September 2002 21:57 Go to next message
Originally posted by: dsingh.altoweb.com
hi all.
The XSDSchemaImpl needs to load the base xml schema definitions prior to
attempting to
parse any user xml schemas. I guess that there needs to be a initialization
phase that invokes
the "XSDSchema.createMetaSchema" method with all the possible base schemas.
I could simple parse each xml schema schema from xsd.resources.jar into a
dom node and invoke it
myself. Is this the right thing to do?
If I have missed something blatantly obvious, please excuse me.
I appreciate any help to resolve this issue.
Dharminder Singh
Re: XSD Schema schema discovery problem [message #1100 is a reply to message #1043] Fri, 27 September 2002 11:25 Go to previous messageGo to next message
Dharminder,
The schema for schema is available via XSDUtil.getSchemaForSchema. All this
meta information is created automatically (on demand) so you should not need to
do anything. Are you experiencing a problem?
Dharminder Singh wrote:
> hi all.
> attempting to
> phase that invokes
> Thanks
> Dharminder Singh
Ed Merks
Re: XSD Schema schema discovery problem [message #1182 is a reply to message #1100] Fri, 27 September 2002 20:12 Go to previous message
Sorry Ed I think I figured out how to solve the problem.
I had crimson in the classpath and using crimson I was getting the following
exception when the
loading of the schema was happening.
Dharminder Singh
org.xml.sax.SAXParseException: Relative URI "XMLSchema.dtd"; can not be
resolved without a document URI.
at org.apache.crimson.parser.Parser2.fatal(Parser2.java:3035)
at org.apache.crimson.parser.Parser2.fatal(Parser2.java:3029)
at org.apache.crimson.parser.Parser2.parseSystemId(Parser2.java :2627)
at org.apache.crimson.parser.Parser2.maybeExternalID(Parser2.ja va:2605)
at org.apache.crimson.parser.Parser2.maybeDoctypeDecl(Parser2.j ava:1116)
at org.apache.crimson.parser.Parser2.parseInternal(Parser2.java :488)
at org.apache.crimson.parser.Parser2.parse(Parser2.java:304)
at org.apache.crimson.parser.XMLReaderImpl.parse(XMLReaderImpl. java:433)
org.apache.crimson.jaxp.DocumentBuilderImpl.parse(DocumentBu ilderImpl.java:1
79)
at javax.xml.parsers.DocumentBuilder.parse(DocumentBuilder.java :122)
org.eclipse.xsd.util.XSDResourceImpl.getDocument(XSDResource Impl.java:136)
at org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl. java:280)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:812)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:690)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetIm
pl.java:209)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetI
mpl.java:275)
org.eclipse.xsd.impl.XSDSchemaImpl.getMagicSchemaForSchema(X SDSchemaImpl.jav
a:550)
org.eclipse.xsd.impl.XSDSchemaImpl.getSchemaForSchema(XSDSch emaImpl.java:628
at org.eclipse.xsd.impl.XSDSchemaImpl.createSchema(XSDSchemaImp l.java:440)
at org.eclipse.xsd.util.XSDParser.getSchema(XSDParser.java:266)
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:3D944019.6059C5DC@ca.ibm.com...
> Dharminder,
this
need to
> > hi all.
> > attempting to
initialization
> > phase that invokes
schemas.
a
> > Thanks
> > Dharminder Singh
> Ed Merks
Re: XSD Schema schema discovery problem [message #562562 is a reply to message #1043] Fri, 27 September 2002 11:25 Go to previous message
Dharminder,
> hi all.
> attempting to
> phase that invokes
> Thanks
> Dharminder Singh
Ed Merks
Ed Merks
Re: XSD Schema schema discovery problem [message #562638 is a reply to message #1100] Fri, 27 September 2002 20:12 Go to previous message
exception when the
Dharminder Singh
79)
pl.java:209)
mpl.java:275)
a:550)
> Dharminder,
this
need to
> > hi all.
> > attempting to
initialization
> > phase that invokes
schemas.
a
> > Thanks
> > Dharminder Singh
> Ed Merks
Previous Topic:Can't load Schema
Next Topic:Can't load Schema
Current Time: Thu Dec 26 18:48:14 GMT 2024
Powered by FUDForum. Page generated in 0.03610 seconds
