Adding Code for setting a property programatically [message #137032] |
Thu, 29 March 2007 03:36 |
Originally posted by: solomonpaul55.gmail.com
Hi All,
I am trying to add code using the context menu programatically. I have
defined a context menu using
'objectClass=" org.eclipse.ve.internal.java.core.IJavaBeanContextMenuContri butor "
I was successful in adding the code for setting a property if it is a text
property . For example,
EStructuralFeature esf = model.eClass().getEStructuralFeature("name");
ResourceSet rs = model.eResource().getResourceSet();
IJavaObjectInstance ijoi = BeanUtilities.createString(rs,"Field1");
RuledCommandBuilder cb = new
RuledCommandBuilder(EditDomain.getEditDomain(editpart));
cb.applyAttributeSetting((EObject) model, esf, ijoi);
Command command = cb.getCommand();
command.execute();
I also want to add code for setting a property that has a method call to a
object creation method as the attribute. For Example
field.setProperty(getField2());
Any help in this regards is greatly appreciated.
Thank You and Regards,
SOLOMON
FUDForum. Page generated in 0.03487 seconds
