Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Teneo 1.0.1 does not support Lazy-Loading of Many-to-One and One-to-One
Re: Teneo 1.0.1 does not support Lazy-Loading of Many-to-One and One-to-One [message #137130 is a reply to message #136872] |
Wed, 10 June 2009 11:25 |
Ajay Messages: 12 Registered: July 2009 |
Junior Member |
Hello Martin,
I am using two EMF classes and two DAOs (one for Employee and other one
for EmailAddresses) for performimg operations on EMF objects.
Testcases for both Employee and EmailAddresses are working fine with
Teneo1.0.1 libraries but asking "setters" for EList type attributes while
running test cases using Teneo 1.0.3 libraries.
The generated interfaces are as follows:
1.EmailAddresses
2.Employee
The generated implementation classes are as follows:
1.EmailAddressesImpl
2.EmployeeImpl
Two DAOs:
1. DAO_Employee
2. DAO_EmailAddress
The association between Employee and EmailAddresses is a bidirectional
one-to-many relationship.
I am pasting complete Hbm file, Test class and Exception Log for your
perusal.
Hbm for these two classes are listed below:
<!-- Hibernate XML Mapping File -->
<!-- Author: U129098 -->
<!-- Modified: Thursday, January 15, 2009 1:39:10 PM -->
<!DOCTYPE hibernate-mapping PUBLIC
"-//Hibernate/Hibernate Mapping DTD//EN"
"http://hibernate.sourceforge.net/hibernate-mapping-3.0.dtd">
<hibernate-mapping auto-import="true">
<class
name="com.person.impl.EmployeeImpl"
table="employee" entity-name="Employee" mutable="true"
dynamic-update="false"
dynamic-insert="false" select-before-update="false" lazy="false"
abstract="false">
<id name="personId" column="employee_id">
<generator class="increment" />
</id>
<property name="name" insert="true" update="true" lazy="false"
optimistic-lock="true" not-null="true">
<column name="name" sql-type="varchar" not-null="true" />
</property>
<bag name="emailAddresses" lazy="true" table="email_address"
fetch="select" cascade="all" inverse="true">
<key column="owner_id" />
<one-to-many class="com.person.impl.EmailAddressesImpl"
entity-name="EmailAddresses" />
</bag>
</class>
<class
name="com.person.impl.EmailAddressesImpl"
table="email_address" entity-name="EmailAddresses" mutable="true"
abstract="false">
<id name="emailId" column="email_id">
</id>
<property name="emailAddress" insert="true" update="true"
lazy="false" optimistic-lock="true">
<column name="email_address" sql-type="varchar" not-null="true" />
</property>
<many-to-one name="owner" column="owner_id"
not-null="true"
class="com.person.impl.EmployeeImpl"
lazy="proxy" entity-name="Employee" cascade="all"/>
</class>
</hibernate-mapping>
TestClass for Employee class:
public class EmployeeMappingTest {
protected static final String CONTEXT_FILE_NAME = "spring.xml";
protected static final ConfigurableApplicationContext springContext = new
ClassPathXmlApplicationContext(
CONTEXT_FILE_NAME);
DAO_Employee employeeDAO = null;
SessionFactory sessionFactory = null;
* SetUp method
@Before
public void setUp() throws Exception {
employeeDAO = (DAO_Employee) springContext.getBean("employeeDAO");
sessionFactory = (SessionFactory) springContext
.getBean("sessionFactory");
@After
public void tearDown() throws Exception {
employeeDAO = null;
* Test method for saving an Employee object
@Test
public void testSaveEmployee() {
Employee employee = new EmployeeImpl();
EmailAddresses emailAddress = new EmailAddressesImpl();
emailAddress.setEmailAddress("ajay.chauhan@ps.net");
emailAddress.setOwner(employee);
EmailAddresses emailAddress1 = new EmailAddressesImpl();
emailAddress1.setEmailAddress("call2aps@gmail.com");
emailAddress1.setOwner(employee);
List<EmailAddresses> eList = new ArrayList<EmailAddresses>();
eList.add(emailAddress);
eList.add(emailAddress1);
employee.setName("Ajay Chauhan");
employee.getEmailAddresses().addAll(eList);
try {
Transaction tx = sessionFactory.getCurrentSession()
.beginTransaction();
employeeDAO.save(employee);
tx.commit();
} catch (Exception e) {
e.printStackTrace();
* Test method for Load
@Test
public void testLoadByIdID_Employee() {
// set the existing id
Integer id = 1;
Employee obj = null;
try {
Transaction txn = sessionFactory.getCurrentSession()
obj = (Employee) sessionFactory.getCurrentSession().get("Employee",id,
LockMode.READ);
System.out.println("Employee ID :: " + obj.getPersonId());
System.out.println("Employee Name :: " + obj.getName());
List<EmailAddresses> eList = obj.getEmailAddresses();
for (EmailAddresses email : eList) {
System.out.println("Email ID :: " + email.getEmailId());
System.out.println("Email Address :: "
+ email.getEmailAddress());
txn.commit();
Exceptions are:
log4j:WARN No appenders could be found for logger
(org.springframework.context.support.ClassPathXmlApplication Context).
log4j:WARN Please initialize the log4j system properly.
java.lang.ExceptionInInitializerError
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknow n Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Un known
Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
org.junit.internal.runners.TestClassMethodsRunner.createTest (TestClassMethodsRunner.java:52)
org.junit.internal.runners.TestClassMethodsRunner.invokeTest Method(TestClassMethodsRunner.java:58)
org.junit.internal.runners.TestClassMethodsRunner.run(TestCl assMethodsRunner.java:35)
org.junit.internal.runners.TestClassRunner$1.runUnprotected( TestClassRunner.java:42)
org.junit.internal.runners.BeforeAndAfterRunner.runProtected (BeforeAndAfterRunner.java:34)
at org.junit.internal.runners.TestClassRunner.run(TestClassRunn er.java:52)
org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.r un(JUnit4TestReference.java:45)
org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:460)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:196)
Caused by: org.springframework.beans.factory.BeanCreationException: Error
creating bean with name 'employeeDAO' defined in class path resource
[spring.xml]: Cannot resolve reference to bean 'employeeSessionFactory'
while setting bean property 'sessionFactory'; nested exception is
org.springframework.beans.factory.BeanCreationException: Error creating
bean with name 'employeeHbSessionDataStore' defined in class path resource
[spring.xml]: Instantiation of bean failed; nested exception is
org.springframework.beans.factory.BeanDefinitionStoreExcepti on: Factory
method [public synchronized org.eclipse.emf.teneo.hibernate.HbDataStore
com.person.teneo.
EmployeeHbHelper.createRegisterDataStore(java.lang.String,or g.hibernate.cfg.Configuration)]
threw exception; nested exception is
org.hibernate.PropertyNotFoundException: Could not find a setter for
property emailAddresses in class com.person.impl.EmployeeImpl
org.springframework.beans.factory.support.BeanDefinitionValu eResolver.resolveReference(BeanDefinitionValueResolver.java: 275)
org.springframework.beans.factory.support.BeanDefinitionValu eResolver.resolveValueIfNecessary(BeanDefinitionValueResolve r.java:104)
org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.applyPropertyValues(AbstractAutowireCapable BeanFactory.java:1245)
org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.populateBean(AbstractAutowireCapableBeanFac tory.java:1010)
org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFac tory.java:472)
org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.ja va:409)
org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.createBean(AbstractAutowireCapableBeanFacto ry.java:380)
org.springframework.beans.factory.support.AbstractBeanFactor y$1.getObject(AbstractBeanFactory.java:264)
org.springframework.beans.factory.support.DefaultSingletonBe anRegistry.getSingleton(DefaultSingletonBeanRegistry.java:22 2)
org.springframework.beans.factory.support.AbstractBeanFactor y.doGetBean(AbstractBeanFactory.java:261)
org.springframework.beans.factory.support.AbstractBeanFactor y.getBean(AbstractBeanFactory.java:185)
org.springframework.beans.factory.support.AbstractBeanFactor y.getBean(AbstractBeanFactory.java:164)
org.springframework.beans.factory.support.DefaultListableBea nFactory.preInstantiateSingletons(DefaultListableBeanFactory .java:429)
org.springframework.context.support.AbstractApplicationConte xt.finishBeanFactoryInitialization(AbstractApplicationContex t.java:728)
org.springframework.context.support.AbstractApplicationConte xt.refresh(AbstractApplicationContext.java:380)
org.springframework.context.support.ClassPathXmlApplicationC ontext. <init>(ClassPathXmlApplicationContext.java:139)
org.springframework.context.support.ClassPathXmlApplicationC ontext. <init>(ClassPathXmlApplicationContext.java:83)
com.person.test.EmployeeMappingTest.<clinit>(EmployeeMappingTest.java:49)
... 16 more
creating bean with name 'employeeHbSessionDataStore' defined in class path
resource [spring.xml]: Instantiation of bean failed; nested exception is
com.person.teneo.EmployeeHbHelper.createRegisterDataStore(ja va.lang.String,org.hibernate.cfg.Configuration)]
org.springframework.beans.factory.support.ConstructorResolve r.instantiateUsingFactoryMethod(ConstructorResolver.java:444 )
org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.instantiateUsingFactoryMethod(AbstractAutow ireCapableBeanFactory.java:903)
org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.createBeanInstance(AbstractAutowireCapableB eanFactory.java:817)
org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFac tory.java:440)
org.springframework.beans.factory.support.ConstructorResolve r.instantiateUsingFactoryMethod(ConstructorResolver.java:287 )
org.springframework.beans.factory.support.BeanDefinitionValu eResolver.resolveReference(BeanDefinitionValueResolver.java: 269)
... 34 more
Caused by: org.springframework.beans.factory.BeanDefinitionStoreExcepti on:
Factory method [public synchronized
com.person.teneo.employeeHbHelper.createRegisterDataStore(ja va.lang.String,org.hibernate.cfg.Configuration)]
org.springframework.beans.factory.support.SimpleInstantiatio nStrategy.instantiate(SimpleInstantiationStrategy.java:127)
org.springframework.beans.factory.support.ConstructorResolve r.instantiateUsingFactoryMethod(ConstructorResolver.java:435 )
... 58 more
Caused by: org.hibernate.PropertyNotFoundException: Could not find a
setter for property emailAddresses in class com.person.impl.EmployeeImpl
org.hibernate.property.BasicPropertyAccessor.createSetter(Ba sicPropertyAccessor.java:240)
org.hibernate.property.BasicPropertyAccessor.getSetter(Basic PropertyAccessor.java:233)
at org.hibernate.mapping.Property.getSetter(Property.java:299)
org.hibernate.tuple.entity.PojoEntityTuplizer.buildPropertyS etter(PojoEntityTuplizer.java:272)
org.hibernate.tuple.entity.AbstractEntityTuplizer.<init>(AbstractEntityTuplizer.java:149)
org.hibernate.tuple.entity.PojoEntityTuplizer.<init>(PojoEntityTuplizer.java:76)
org.hibernate.tuple.entity.EntityEntityModeToTuplizerMapping . <init>(EntityEntityModeToTuplizerMapping.java:80)
org.hibernate.tuple.entity.EntityMetamodel.<init>(EntityMetamodel.java:325)
org.hibernate.persister.entity.AbstractEntityPersister.<init >(AbstractEntityPersister.java:457)
org.hibernate.persister.entity.SingleTableEntityPersister.<init >(SingleTableEntityPersister.java:131)
org.hibernate.persister.PersisterFactory.createClassPersiste r(PersisterFactory.java:84)
org.hibernate.impl.SessionFactoryImpl.<init>(SessionFactoryImpl.java:261)
org.hibernate.cfg.Configuration.buildSessionFactory(Configur ation.java:1327)
at com.person.teneo.
EmployeeHbSessionDataStore.buildSessionFactory(EmployeeHbSes sionDataStore.java:232)
EmployeeHbSessionDataStore.initialize(EmployeeHbSessionDataS tore.java:112)
com.person.teneo.EmployeeHbHelper.createRegisterDataStore(Em ployeeHbHelper.java:104)
org.springframework.beans.factory.support.SimpleInstantiatio nStrategy.instantiate(SimpleInstantiationStrategy.java:115)
... 59 more
Re: Teneo 1.0.1 does not support Lazy-Loading of Many-to-One and One-to-One [message #137143 is a reply to message #137130] |
Wed, 10 June 2009 13:36 |
Martin Taal Messages: 5468 Registered: July 2009 |
FYI, this post has been answered on the main EMF newsgroup (eclipse.tools.emf).
gr. Martin
Ajay Chauhan wrote:
> Hello Martin,
> while running test cases using Teneo 1.0.3 libraries.
> 1.EmailAddresses
> 2.Employee
> 2.EmployeeImpl
> Two DAOs:
> 1. DAO_Employee
> 2. DAO_EmailAddress
> perusal.
> <class
> abstract="false">
> </id>
> </property>
> </bag>
> </class>
> <class
> mutable="true" dynamic-update="false"
> abstract="false">
> </id>
> not-null="true" />
> </property>
> not-null="true"
> </class>
> = new ClassPathXmlApplicationContext(
> CONTEXT_FILE_NAME);
> * SetUp method
> @Before
> @After
> employeeDAO = null;
> @Test
> try {
> tx.commit();
> @Test
> Integer id = 1;
> try {
> obj = (Employee)
> sessionFactory.getCurrentSession().get("Employee",id, LockMode.READ);
> txn.commit();
> Exceptions are:
> Method)
> Source)
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Error creating bean with name 'employeeDAO' defined in class path
> resource [spring.xml]: Cannot resolve reference to bean
> 'employeeSessionFactory' while setting bean property 'sessionFactory';
> nested exception is
> com.person.teneo.
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 16 more
> Error creating bean with name 'employeeHbSessionDataStore' defined in
> class path resource [spring.xml]: Instantiation of bean failed; nested
> exception is
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 34 more
> Caused by:
> at
> at
> ... 58 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 59 more
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo 1.0.1 does not support Lazy-Loading of Many-to-One and One-to-One [message #621010 is a reply to message #136872] |
Junior Member |
Hello Martin,
1.EmailAddresses
2.Employee
2.EmployeeImpl
Two DAOs:
1. DAO_Employee
2. DAO_EmailAddress
perusal.
<class
abstract="false">
</id>
</property>
</bag>
</class>
<class
abstract="false">
</id>
</property>
not-null="true"
</class>
CONTEXT_FILE_NAME);
* SetUp method
@Before
@After
employeeDAO = null;
@Test
try {
tx.commit();
@Test
Integer id = 1;
try {
LockMode.READ);
txn.commit();
Exceptions are:
Source)
com.person.teneo.
... 16 more
... 34 more
... 58 more
... 59 more
Re: Teneo 1.0.1 does not support Lazy-Loading of Many-to-One and One-to-One [message #621011 is a reply to message #137130] |
gr. Martin
Ajay Chauhan wrote:
> Hello Martin,
> 1.EmailAddresses
> 2.Employee
> 2.EmployeeImpl
> Two DAOs:
> 1. DAO_Employee
> 2. DAO_EmailAddress
> perusal.
> <class
> abstract="false">
> </id>
> </property>
> </bag>
> </class>
> <class
> abstract="false">
> </id>
> not-null="true" />
> </property>
> not-null="true"
> </class>
> CONTEXT_FILE_NAME);
> * SetUp method
> @Before
> @After
> employeeDAO = null;
> @Test
> try {
> tx.commit();
> @Test
> Integer id = 1;
> try {
> obj = (Employee)
> txn.commit();
> Exceptions are:
> Method)
> Source)
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> nested exception is
> com.person.teneo.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 16 more
> exception is
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 34 more
> Caused by:
> at
> at
> ... 58 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 59 more
The Netherlands
Current Time: Wed Feb 05 14:10:21 GMT 2025
Powered by FUDForum. Page generated in 0.03764 seconds
