Re: Instance Id Constraint and record type constraint in same template,not possible? [message #12593 is a reply to message #12573] |
Fri, 20 February 2009 00:15 |
Originally posted by: david_whiteman.us.ibm.com
Please create a bug report for this in bugzilla.
Thanks!
David
arunachalam wrote:
> Hi ,
> I am not able to run the query when I am having the instance id
> constraint , record type constraint with in a same template. when I am
> running the following query file ,
> <query xmlns="http://cmdbf.org/schema/1-0-0/datamodel">
> <itemTemplate id="template2">
> <instanceIdConstraint>
> <instanceId>
> <mdrId>CCMDBMDR</mdrId>
> <localId>Server1</localId>
> </instanceId>
> </instanceIdConstraint>
> <recordConstraint>
> <recordType localName="OS" namespace=""/>
> </recordConstraint>
> </itemTemplate>
> </query>
> I am getting the following exception.
> Exception in thread "main" java.lang.NullPointerException
> at
> com.ibm.cmdbf.query.CMDBfQueryOperation.applyItemConstraints (CMDBfQueryOperation.java:485)
> at
> com.ibm.cmdbf.query.CMDBfQueryOperation.processItemTemplates (CMDBfQueryOperation.java:216)
> at
> com.ibm.cmdbf.query.CMDBfQueryOperation.execute(CMDBfQueryOp eration.java:139)
> at
> com.ibm.cmdbf.query.CMDBfQueryOperation.execute(CMDBfQueryOp eration.java:126)
> at com.ibm.cmdbf.query.QueryLauncher.getResponse(QueryLauncher. java:93)
> at com.ibm.cmdbf.query.QueryLauncher.main(QueryLauncher.java:64 )
> I am getting the error on the applyItemConstraints method ,
> Logically it is wrong to have the instance id constraint record
> constraint with in the same template , but the api is just throwing the
> null pointer exception.
> Is this not possible to have the instance id constraint and record
> constraint with in the same template ?
> if this is not possible the API should inform the user by throwing
> the custom exception something like "it is not possible to have the
> instance id constraint and record constraint with in the same template"
> Regards
> Arunachalam.
FUDForum. Page generated in 0.04126 seconds
