Home » Eclipse Projects » DTP » ParameterInOutWrapper
ParameterInOutWrapper [message #12560] |
Thu, 04 May 2006 18:46 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: francine.grimmer.ncr.com
I am extending the CallableSQLResultRunnable class and trying to overwrite the handleSuccess method to display the output paramters of the stored procedure. In doing this, I need access to the ParameterInOutWrapper class. But when I include this in my method, I get an access restriction error. The same thing happens for the Parameter class.
Is this an oversite or is this intentional? If intentional, then what is recommended for implementers to extend this class and use the IN and OUT parameters of the stored procedure?
please respond.
regards,
Francine
Re: ParameterInOutWrapper [message #12671 is a reply to message #12560] |
Fri, 05 May 2006 22:06 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: jograham.sybase.com
Hi Francine,
I've forwarded this question to our SQL Dev team. The committer who knows
the answer is currently on vacation, but will be back on 5/8, so look for an
answer early next week.
John Graham
Eclipse Data Tools Platform PMC Chair
"Francine Grimmer" <francine.grimmer@ncr.com> wrote in message
news:19562234.1146768429909.JavaMail.root@cp1.javalobby.org...
> please respond.
> regards,
> Francine
Re: ParameterInOutWrapper [message #12815 is a reply to message #12671] |
Mon, 08 May 2006 03:17 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hui Cao![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=hui.cao%40sybase.com) Messages: 14 Registered: July 2009 |
Junior Member |
Hi Francine,
This is an interesting question. We didn't expect you extend
CallableSQLResultRunnable in this way and didn't expose the
ParameterInOutWrapper class. But now it seems that we should do so. Since
this envolves API changes and we're approaching Callisto, we need DTP
PMC's approval for this change. BTW, the
org.eclipse.datatools.sqltools.result.Parameter class is already exposed.
I'll get you updated ASAP.
Hui Cao
Sybase Inc.
John Graham wrote:
> Hi Francine,
> John Graham
>> please respond.
>> regards,
>> FrancineHi
Re: ParameterInOutWrapper [message #14472 is a reply to message #12815] |
Tue, 16 May 2006 01:47 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Junior Member |
Hi Francine,
The "org.eclipse.datatools.sqltools.routineeditor.parameter" package in
org.eclipse.datatools.sqltools.routineeditor plugin has been exposed so
that you should have no problem extending CallableSQLResultRunnable now.
You can checkout RC3 for the latest changes.
Regards!
Hui Cao
Sybase Inc.
Hui Cao wrote:
> Hi Francine,
> Hui Cao
> Sybase Inc.
> John Graham wrote:
>> Hi Francine,
an
>> Regards,
>> John Graham
>>> please respond.
>>> regards,
>>> FrancineHi
Re: ParameterInOutWrapper [message #574073 is a reply to message #12671] |
Mon, 08 May 2006 03:17 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Junior Member |
Hi Francine,
Hui Cao
Sybase Inc.
John Graham wrote:
> Hi Francine,
> John Graham
>> please respond.
>> regards,
>> FrancineHi
Re: ParameterInOutWrapper [message #577792 is a reply to message #12815] |
Tue, 16 May 2006 01:47 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Junior Member |
Hi Francine,
Regards!
Hui Cao
Sybase Inc.
Hui Cao wrote:
> Hi Francine,
> Hui Cao
> Sybase Inc.
> John Graham wrote:
>> Hi Francine,
an
>> Regards,
>> John Graham
>>> please respond.
>>> regards,
>>> FrancineHi
Current Time: Sat Jul 27 12:32:47 GMT 2024
Powered by FUDForum. Page generated in 0.10650 seconds
