Home » Eclipse Projects » Commercial » Error when generating a PDF report
Error when generating a PDF report [message #12552] Mon, 26 February 2007 21:18
Originally posted by: pherrera.vmware.com
The error below occurs when I try to generate a PDF report. The report
looks fine, but when I try to generate the same report in PDF format, I
get the error below. Any ideas?
Caused by: java.lang.ClassCastException
org.eclipse.birt.report.engine.layout.pdf.PDFLayoutManagerFa ctory$ContentVisitor.visitForeign(PDFLayoutManagerFactory.ja va:188)
org.eclipse.birt.report.engine.content.impl.ForeignContent.a ccept(ForeignContent.java:52)
org.eclipse.birt.report.engine.layout.pdf.PDFLayoutManagerFa ctory.createLayoutManager(PDFLayoutManagerFactory.java:79)
org.eclipse.birt.report.engine.layout.pdf.PDFBlockStackingLM .layoutChildNode(PDFBlockStackingLM.java:93)
org.eclipse.birt.report.engine.layout.pdf.PDFBlockStackingLM .traverseChildren(PDFBlockStackingLM.java:75)
org.eclipse.birt.report.engine.layout.pdf.PDFStackingLM.layo utChildren(PDFStackingLM.java:130)
org.eclipse.birt.report.engine.layout.pdf.PDFAbstractLM.layo ut(PDFAbstractLM.java:134)
org.eclipse.birt.report.engine.layout.pdf.PDFRowLM.traverseC hildren(PDFRowLM.java:88)
org.eclipse.birt.report.engine.layout.pdf.PDFBlockStackingLM .layoutChildNode(PDFBlockStackingLM.java:95)
org.eclipse.birt.report.engine.layout.pdf.PDFTableLM.travers eChildren(PDFTableLM.java:135)
org.eclipse.birt.report.engine.layout.pdf.PDFPageLM.layout(P DFPageLM.java:198)
org.eclipse.birt.report.engine.layout.pdf.PDFReportLayoutEng ine.layoutReport(PDFReportLayoutEngine.java:55)
org.eclipse.birt.report.engine.layout.pdf.PDFReportLayoutEng ine.layout(PDFReportLayoutEngine.java:68)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:187)
Previous Topic:Use Eclipse Update Manager to distribute non-java code
Next Topic:Error when generating a PDF report
Current Time: Fri Nov 08 22:15:20 GMT 2024
Powered by FUDForum. Page generated in 0.02630 seconds
