Home » Modeling » Epsilon » Odd bug in generated graphical editor
Odd bug in generated graphical editor [message #12507] |
Thu, 12 February 2009 10:15 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Michael Moser![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=mmo%40zurich.ibm.com) Messages: 914 Registered: July 2009 |
------=_NextPart_000_0011_01C98D03.323719E0
Content-Type: text/plain;
format=flowed;
charset="iso-8859-1";
reply-type=original
I generated a simple editor from the attached .emf file. Oddly, when
running the generated graphical editor, one can nicely draw nodes and
connections. But whenever one creates a new node, then suddenly all
connections drawn so far are removed again from the diagram.
Can others reproduce this? Any idea why? Can one fix this somehow? And
is this now an Epsilon/Eugenia bug or a genuine GMF bug? I presume the
latter, but just wanted to double check. Before reporting transferring
this to the GMF NG.
Michael
Content-Type: application/octet-stream;
name="leonardo2.emf"
Content-Disposition: attachment;
filename="leonardo2.emf"
@namespace(uri=3D"leonardo2", prefix=3D"leonardo2")=0A=
=0A=
@gmf (foo=3D"bar")=0A=
package leonardo2;=0A=
=0A=
@gmf.diagram (foo=3D"bar")=0A=
class Leonardo2 {=0A=
attr String title =3D "Diagram";=0A=
attr String description;=0A=
val Artifact[*] artifacts;=0A=
val Process[*] processes;=0A=
val ArtifactRelation[*] artifactRelations;=0A=
val ProcessRelation[*] processRelations;=0A=
}=0A=
=0A=
@gmf.node(label =3D "name", label.icon=3D"true", figure=3D"rectangle", =
color=3D"255,255,200")=0A=
class Artifact {=0A=
id attr String name;=0A=
attr String location;=0A=
}=0A=
=0A=
@gmf.node(label =3D "name", label.icon=3D"true")=0A=
class ArtifactContainer extends Artifact {=0A=
val Artifact[*] contents;=0A=
}=0A=
=0A=
@gmf.node(label =3D "name", label.icon=3D"true", color=3D"200,255,200")=0A=
class Process {=0A=
val ArtifactRelation[*]#process1 artifactRelations;=0A=
val ProcessRelation[*]#process2 processRelations;=0A=
}=0A=
=0A=
@gmf.link(target=3D"artifact", source=3D"process1", label=3D"name", =
target.decoration=3D"arrow", style=3D"dash", width=3D"2", =
incoming=3D"true")=0A=
class ArtifactRelation {=0A=
attr ArtifactRelationType relationType =3D "0";=0A=
ref Artifact artifact;=0A=
ref Process#artifactRelations process1;=0A=
}=0A=
=0A=
enum ArtifactRelationType {=0A=
CREATES =3D 0;=0A=
READS =3D 1;=0A=
UPDATES =3D 2;=0A=
DELETES =3D 3;=0A=
IS_INSTANTIATED_FROM =3D 4;=0A=
}=0A=
=0A=
@gmf.link(target=3D"target", source=3D"process2", label=3D"name", =
target.decoration=3D"arrow", style=3D"dot", width=3D"2", =
class ProcessRelation {=0A=
attr ProcessRelationType relationType =3D "0";=0A=
ref Process target;=0A=
ref Process#processRelations process2;=0A=
}=0A=
=0A=
enum ProcessRelationType {=0A=
INSTANTIATES =3D 0;=0A=
CALLS =3D 1;=0A=
SENDS_DATA =3D 2;=0A=
RECEIVES_DATA =3D 3;=0A=
TERMINATES =3D 4;=0A=
}=0A=
=0A=
------=_NextPart_000_0011_01C98D03.323719E0--
Re: Odd bug in generated graphical editor [message #12559 is a reply to message #12507] |
Thu, 12 February 2009 11:10 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Dimitrios Kolovos![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=dskolovos%40gmail.com) Messages: 1776 Registered: July 2009 |
Hi Michael,
Apparently the artificial containment workaround I proposed was not a
good one. However, there is no need for it any more since I've fixed it
properly in Eugenia. I've uploaded the new version under
http://download.eclipse.org/modeling/gmt/epsilon/interim/ so once the
download server has picked up the changes you can update from there
(I'll send a message to the newsgroup when it is ready).
Once you have updated, you can remove the artificial containment
references from class Leonardo2:
and everything will work as expected. Again, apologies for the previous
bad workaround!
Dimitris
> this to the GMF NG.
> Michael
Re: Odd bug in generated graphical editor [message #12580 is a reply to message #12559] |
Thu, 12 February 2009 13:03 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
On an update to this, the interim update site
(http://download.eclipse.org/modeling/gmt/epsilon/interim/) is now ready.
Dimitris
Dimitris Kolovos wrote:
> Hi Michael,
> bad workaround!
> Cheers,
> Dimitris
>> this to the GMF NG.
>> Michael
Re: Odd bug in generated graphical editor [message #12599 is a reply to message #12580] |
Thu, 12 February 2009 13:27 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
.... and the bug report for tracking purposes:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=264677
> Cheers,
> Dimitris
>> Hi Michael,
>> it properly in Eugenia. I've uploaded the new version under
>> previous bad workaround!
>> Cheers,
>> Dimitris
>>> And is this now an Epsilon/Eugenia bug or a genuine GMF bug? I
>>> presume the latter, but just wanted to double check. Before reporting
>>> transferring this to the GMF NG.
>>> Michael
Re: Odd bug in generated graphical editor [message #565240 is a reply to message #12507] |
Thu, 12 February 2009 11:10 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hi Michael,
bad workaround!
Dimitris
> this to the GMF NG.
> Michael
Re: Odd bug in generated graphical editor [message #565265 is a reply to message #12559] |
Thu, 12 February 2009 13:03 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Dimitris
> Hi Michael,
> bad workaround!
> Cheers,
> Dimitris
>> this to the GMF NG.
>> Michael
Re: Odd bug in generated graphical editor [message #565291 is a reply to message #12580] |
Thu, 12 February 2009 13:27 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
> Cheers,
> Dimitris
>> Hi Michael,
>> Cheers,
>> Dimitris
>>> Michael
Current Time: Sat Jul 27 12:51:48 GMT 2024
Powered by FUDForum. Page generated in 0.03842 seconds
