Error installing q4e plugin on Eclipse 3.4 [message #12503] |
Thu, 24 July 2008 18:13 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: joe.chambers.cox.com
I get the following error when I try to install q4e on the Eclipse 3.4
application:
Cannot complete the request. See the details.
Eclipse Modeling Framework (EMF) - org.eclipse.emf.common will be ignored
because a newer version is already installed.
Eclipse Modeling Framework (EMF) - org.eclipse.emf.common.ui will be ignored
Eclipse Modeling Framework (EMF) - org.eclipse.emf.ecore will be ignored
Eclipse Modeling Framework (EMF) - org.eclipse.emf.ecore.edit will be
ignored because a newer version is already installed.
Eclipse Modeling Framework (EMF) - org.eclipse.emf.edit will be ignored
Eclipse Modeling Framework (EMF) - org.eclipse.emf.edit.ui will be ignored
Eclipse XML Editors and Tools will be ignored because a newer version is
already installed.
Graphical Editing Framework will be ignored because a newer version is
already installed.
WST Common Core will be ignored because a newer version is already
installed.
WST Common UI will be ignored because a newer version is already installed.
WST XML Core will be ignored because a newer version is already installed.
WST XML User Documentation will be ignored because a newer version is
already installed.
XML Schema Infoset Model (XSD) - org.eclipse.xsd will be ignored because a
XML Schema Infoset Model (XSD) - org.eclipse.xsd.edit will be ignored
Cannot find a solution where both Match[requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.zest.layouts/[1.0.0.v2 0080226,1.0.0.v20080226]]
and Match[requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.zest.layouts/[1.0.0.v2 0080115,1.0.0.v20080115]]
can be satisfied.
can be satisfied.
can be satisfied.
can be satisfied.
can be satisfied.
Any help would be appreciated.
Joe
Re: Error installing q4e plugin on Eclipse 3.4 [message #12526 is a reply to message #12503] |
Mon, 28 July 2008 18:26 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Carlos Sanchez![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=carlos.sanchez%40devzuz.com) Messages: 40 Registered: July 2009 |
Member |
Have you selected the Dependency Viewer feature?
In 3.3 at least it complains if you don't have all requirements selected
> application:
> already installed.
> already installed.
> installed.
> already installed.
> can be satisfied.
> can be satisfied.
> can be satisfied.
> can be satisfied.
> can be satisfied.
> Joe
Re: Error installing q4e plugin on Eclipse 3.4 [message #12547 is a reply to message #12503] |
Mon, 28 July 2008 18:27 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Member |
> application:
> already installed.
> already installed.
> installed.
> already installed.
> can be satisfied.
> can be satisfied.
> can be satisfied.
> can be satisfied.
> can be satisfied.
> Joe
Re: Error installing q4e plugin on Eclipse 3.4 [message #566810 is a reply to message #12503] |
Mon, 28 July 2008 18:26 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Member |
> application:
> already installed.
> already installed.
> installed.
> already installed.
> can be satisfied.
> can be satisfied.
> can be satisfied.
> can be satisfied.
> can be satisfied.
> Joe
Re: Error installing q4e plugin on Eclipse 3.4 [message #566832 is a reply to message #12503] |
Mon, 28 July 2008 18:27 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Member |
> application:
> already installed.
> already installed.
> installed.
> already installed.
> can be satisfied.
> can be satisfied.
> can be satisfied.
> can be satisfied.
> can be satisfied.
> Joe
FUDForum. Page generated in 0.05027 seconds
