How does the Alt+click work? [message #12481] |
Fri, 13 July 2007 18:34 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: xiaoyang.guan.gmail.com
In the structured views with "focus on active task" turned on, I suppose
Alt+click on an element will reveal all its uninteresting children.
But when I do that, nothing happened except that the mouse icon turned
into a "+" sign. Alt+Right arrow works as expected, although I found
that just pressing Right Arrow itself also does the same if the view is
wide enough.
Is there any configuration in Preference in order to make Alt+click
work? BTW, I'm on a Linux machine (Ubuntu 6.06) if it's relevant.
Xiaoyang
Re: How does the Alt+click work? [message #12586 is a reply to message #12481] |
Fri, 13 July 2007 19:07 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: beatmik.acm.org
Xiaoyang Guan wrote:
> Alt+click on an element will reveal all its uninteresting children. But
> when I do that, nothing happened except that the mouse icon turned into
> a "+" sign. Alt+Right arrow works as expected, although I found that
> just pressing Right Arrow itself also does the same if the view is wide
> enough.
A short explanation of how it works is here:
http://www.eclipse.org/mylyn/tips/
And a longer one here:
http://wiki.eclipse.org/index.php/Mylyn_User_Guide#Alt.2BCli ck_navigation
Mik
Re: How does the Alt+click work? [message #14061 is a reply to message #12586] |
Mon, 16 July 2007 19:01 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
>> suppose Alt+click on an element will reveal all its uninteresting
>> children. But when I do that, nothing happened except that the mouse
>> icon turned into a "+" sign. Alt+Right arrow works as expected,
>> although I found that just pressing Right Arrow itself also does the
>> same if the view is wide enough.
> Mik
Thanks Mik.
Follow-up: the problem I had was because the window manager uses
Alt+click for moving a window. Setting the window movement key to
something else makes Alt+click navigation in Mylyn work as expected.
FUDForum. Page generated in 0.06702 seconds
