Re: TreeViewer refresh [message #12813 is a reply to message #12642] |
Wed, 28 March 2007 10:14 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: rsternberg.innoopract.com
Hi Markus,
sorry for the delay.
Yes, there are some open issues on the Tree widget. I adapted the
workbench demo to test your setup, and I get a JavaScipt error, too. I
will look after it as soon as possible. However, I'm not sure if this is
exactly the same error that breaks your application.
It would help if you could provide a code snippet to reproduce the
error. If you like, you can also file a bug in the Eclipse bugzilla.
>> the UI gets loocked and I can not work in the workbench properly anymore.
>> This behavior does not happen, if I right click on an element that is
>> still in the model.
If the UI gets locked, this means that either a JavaScript error has
occured or an Exception was thrown on the server side. JavaScript errors
are reported by most web browsers. A copy of this error message would be
very helpful.
Ralf
Re: TreeViewer refresh [message #14548 is a reply to message #12813] |
Thu, 29 March 2007 12:18 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Markus rüger![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=webmaster%40playershouse.com) Messages: 369 Registered: July 2009 |
here is the example. It is based on You DemoTreeViewPart. So just replace
the code with mine to test it.
Now, the error/lock occurs if you do the following steps:
- Replace the code of DemoTreeViewPart with the one I included.
- Start the demo with your included launchconfiguration (use the cvs state
of the plugins)
- Navigate to the demo in IE or Firefox so that you see the demo workbench
- Now right click for example on "tree object 5" in view "View I" and choose
"update model"
- Now right cliick again and choose "refresh"
The result should be an empty tree and a locked UI.
Good luck ;-)
Makrus
"Ralf Sternberg" <rsternberg@innoopract.com> schrieb im Newsbeitrag
news:eudf6b$d8j$1@utils.eclipse.org...
> Hi Markus,
>>> anymore.
>>> still in the model.
> very helpful.
> Ralf
Re: TreeViewer refresh [message #14668 is a reply to message #14548] |
Thu, 29 March 2007 15:51 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Markus,
this bug was lurking in the disposal of tree items. It's fixed, thanks
for the hint.
> of the plugins)
> "update model"
The result is now an empty tree.
Ralf
FUDForum. Page generated in 0.04317 seconds
