Home » Archived » Visual Editor (VE) » Extending the palette
Extending the palette [message #135708] Mon, 12 February 2007 00:45 Go to next message
Originally posted by: savrahami.gmail.com
I extended the ve bean palette by my own bean.
The problem is that while dropping the bean from the palette onto the ve, a
rename dialog pops up with an "XYZ" as its default name.
I don't know where this "XYZ" came from, what I need is the class name as
the default name to appear in the dialog
Any idea?
Shachar
Re: Extending the palette [message #135733 is a reply to message #135708] Mon, 12 February 2007 09:53 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
What kind of entry in the palette did you use? The EMFCreationToolEntry
or the EMFPrototypeToolEntry?
Did you include an entry like this?
<keyedValues xsi:type="ecore:EStringToStringMapEntry"
key="org.eclipse.ve.internal.cde.core.nameincomposition"
value="menu"/>
Shachar wrote:
> Hello,
> Any idea?
> Shachar
Rich Kulp
Re: Extending the palette [message #135965 is a reply to message #135733] Sun, 18 February 2007 00:40 Go to previous messageGo to next message
Here's what I've done:
<org.eclipse.ve.internal.cde.palette:Drawer xmi:version="2.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:org.eclipse.ve.internal.cde.palette="http:///org/eclipse/ve/internal/cde/palette.ecore"
xmlns:org.eclipse.ve.internal.cde.utility="http:///org/eclipse/ve/internal/cde/utility.ecore">
<entryLabel xsi:type="org.eclipse.ve.internal.cde.utility:ConstantString "
string="FE Infra Components" string="fromXmiFile" />
<children
xsi:type="org.eclipse.ve.internal.cde.palette:EMFCreationToolEntry "
icon16Name="platform:/plugin/MyFirstPlugin/icons/mir29.gif"
creationClassURI="java:/controler#MyControl">
<entryLabel
string="MyControl" />
key="org.eclipse.ve.internal.cde.core.nameincomposition" value="myControl"
</children>
</org.eclipse.ve.internal.cde.palette:Drawer>
"Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> wrote in message
news:eqpv1i$4ga$1@utils.eclipse.org...
> What kind of entry in the palette did you use? The EMFCreationToolEntry or
> value="menu"/>
> Shachar wrote:
>> Hello,
>> a rename dialog pops up with an "XYZ" as its default name.
>> Any idea?
>> Thanks,
>> Shachar
> Rich Kulp
Re: Extending the palette [message #135989 is a reply to message #135965] Mon, 19 February 2007 10:04 Go to previous messageGo to next message
I don't know why. The xmi looks correct. The only reason that I could
see this occurring is that the name in composition was not set
correctly. But I don't see why that would happen.
You would need to see if there are any errors in the log or trace to see
if:
1) CreationToolEntryImpl.getFactory() to see if it adds in a
AnnotationCreationFactory for the getKeyedValues().
2)
NameInCompositionPropertyDescriptor.getUniqueNameInCompositi on(EditDomain
domain, String name, Set otherNames) if the incoming name is null (if it
is then XYZ is used). Trace backward from there.
Rich
Re: Extending the palette [message #135999 is a reply to message #135989] Tue, 20 February 2007 00:19 Go to previous message
news:erce9i$e4l$1@utils.eclipse.org...
>I don't know why. The xmi looks correct. The only reason that I could see
>this occurring is that the name in composition was not set correctly. But I
> if:
> 2)
> Rich
Re: Extending the palette [message #615059 is a reply to message #135708] Mon, 12 February 2007 09:53 Go to previous message
value="menu"/>
Shachar wrote:
> Hello,
> Any idea?
> Shachar
Rich Kulp
Re: Extending the palette [message #615077 is a reply to message #135733] Sun, 18 February 2007 00:40 Go to previous message
<children
<entryLabel
</children>
> value="menu"/>
> Shachar wrote:
>> Hello,
>> Any idea?
>> Thanks,
>> Shachar
> Rich Kulp
Re: Extending the palette [message #615079 is a reply to message #135965] Mon, 19 February 2007 10:04 Go to previous message
if:
2)
Rich
Re: Extending the palette [message #615080 is a reply to message #135989] Tue, 20 February 2007 00:19 Go to previous message
> if:
> 2)
> Rich
Previous Topic:Plug-in
Next Topic:This is a test for line separator
Current Time: Tue Jul 01 13:16:48 EDT 2025
Powered by FUDForum. Page generated in 0.29133 seconds
