Is layout supported in visual editor? [message #135235] |
Sun, 05 February 2006 13:38 |
Originally posted by: ajay_kumar444.yahoo.com
I started using visual editor....... how ever i am doubtfull asto how to
use layouts in ve..... infact i dont see the layout option in pallete
column...... help me how to use the visual editor to build swing appl
using layouts..!
Re: Is layout supported in visual editor? [message #135259 is a reply to message #135235] |
Sun, 05 February 2006 15:23 |
Originally posted by: myersj.gmail.com
Jackie,
Select a container (a JPanel for example). There are three ways to
change the layout:
1) From the Properties view make a selection in the layout property's
combo box.
2) Right click on the container in the graphical view or the Java Beans
view. Select a layout from the Set Layout submenu.
3) On the toolbar there is a Customize layout button with a pulldown
submenu. Select a layout from the submenu.
There is much more basic help such as this in the VE documentation
available under the Visual Editor for Java User Guide in Eclipse help,
or online here:
http://help.eclipse.org/help31/index.jsp?topic=/org.eclipse. ve.doc/topics/tve_overview.html
Hope this helps,
- Jeff
FUDForum. Page generated in 0.08668 seconds
