3.1.2 Bug [message #135130] |
Sat, 04 February 2006 16:21 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: jaschulz.wiseware.com
If I choose Run As | Ant Build, and then click the JRE Tab, the contents
are or the tab larger than the display area and the "Java Executable"
group box is half cut off (and if there is anything below it...)
JAS
Re: 3.1.2 Bug [message #135179 is a reply to message #135156] |
Sat, 04 February 2006 19:52 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
OK. That works. But I don't think there's any reason I should have to
do that. Eclipse should know how big its dialogs need to be.
JAS
Darin Swanson wrote:
> The dialog is resizable.
> Resize it to see the full contents of the tab.
> HTH
> Darins
> "James A. Schulz" <jaschulz@wiseware.com> wrote in message
> news:ds2k9i$bo7$1@utils.eclipse.org...
>> JAS
Re: 3.1.2 Bug [message #136372 is a reply to message #135179] |
Thu, 09 February 2006 19:12 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
http://bugs.eclipse.org/bugs
Search, then file a new one if you don't find anything related.
Hope this helps,
Eric
FUDForum. Page generated in 0.08314 seconds
