Home » Eclipse Projects » Remote Application Platform (RAP) » image + war
image + war [message #134866] Thu, 04 June 2009 03:40 Go to next message
I have following problem. I create an image of a byte array with this code
snippet:
Image image = Graphics.getImage(imageName, new
ByteArrayInputStream(imageData));
It works fine when I start my application from eclipse. If I build a war
and deploy it on jboss, I don't will see my image.
How can I do that it works on jboss as war and from eclipse?
Kristin
Re: image + war [message #134882 is a reply to message #134866] Thu, 04 June 2009 06:33 Go to previous messageGo to next message
did you check the FAQ? E.g.
http://wiki.eclipse.org/RAP/FAQ#I_cannot_access_resource.2Fi mage_after_deploying_as_a_WAR
HTH
Rüdiger
Kristin Polenz wrote:
> Hello,
> code snippet:
> Kristin
Re: image + war [message #134909 is a reply to message #134882] Thu, 04 June 2009 08:29 Go to previous messageGo to next message
I read the FAQ article but I think it don't help me. The imageName in the
code snippet of my first post has the following path
"/icons/test"+Math.random()+".gif"
I don't see the generate image of the image byte array on this path. Which
resource files or entries of images should in the build.properties file?
Kristin
Re: image + war [message #134922 is a reply to message #134909] Thu, 04 June 2009 09:00 Go to previous messageGo to next message
> the code snippet of my first post has the following path
The first parameter is used to uniquely identify the image (the one
given by the stream). In addition the path partly specifies where to
store a copy of the image so that is is accessible by the browser
(but that may change in the future).
Did you make sure that the imageData isn't empty?
> Which resource files or entries of images should in the build.properties
> file?
My previous suggestion might be misleading (see above)
> Kristin
Re: image + war [message #134933 is a reply to message #134922] Thu, 04 June 2009 09:36 Go to previous messageGo to next message
Yes, I'm sure that the imageData isn't empty.
What can I try else?
Kristin
Re: image + war [message #134945 is a reply to message #134933] Thu, 04 June 2009 15:15 Go to previous messageGo to next message
> Hello,
> Yes, I'm sure that the imageData isn't empty. What can I try else?
Puh, not sure. How do you display the image?
> Kristin
Re: image + war [message #134971 is a reply to message #134945] Fri, 05 June 2009 02:31 Go to previous messageGo to next message
Hello Rüdiger,
I diplay my image in a browser. Here is the code snippet how I get the
image of the imageData and set the image in the browser control.
imageName = "/icons/test"+Math.random()+".gif";
browser.setText("<img src=\""+imageName+"/>");
Kristin
Re: image + war [message #134980 is a reply to message #134971] Fri, 05 June 2009 03:30 Go to previous messageGo to next message
Hi Kristin,
the path started with "/" like in your imageName means root of the
server and not the relative path. When you deploy your application as
war in Tomcat this path does not exist (there is one more folder witch
is the war filename) - in Eclipse Jetti the application is in the app
server root. Try to change the path to
"icons/test"+Math.random()+".gif"" (without leading backspash).
Best,
Ivan
> Hello Rüdiger,
> Kristin
Re: image + war [message #135191 is a reply to message #134980] Fri, 05 June 2009 12:28 Go to previous messageGo to next message
I changed the path of my imageName but it doesn't help. Do you have any
other ideas to solve my problem?
Kristin
Re: image + war [message #135405 is a reply to message #135191] Mon, 08 June 2009 05:12 Go to previous messageGo to next message
I tried to set my image on the browser as backgroundImage and then it
works fine. Which control can I use to set an image? Or, how can I set a
backgroundImage once, so that the backgroundImage wouldn't repeat?
Kristin
Re: image + war [message #135442 is a reply to message #135405] Mon, 08 June 2009 06:49 Go to previous messageGo to next message
Hi Kristin,
Not sure whether I understand this question correctly. You can set an
image on any control that supports setBackgroundImage().
> Or, how can I set a
Preventing a backgroundImage from repeating is not possible. See the
Javadoc of setBackgroundImage:
"The background image is tiled to fill the available space."
Ralf
Re: image + war [message #135455 is a reply to message #134971] Mon, 08 June 2009 06:53 Go to previous messageGo to next message
Hi Kristin,
I think the advise that Ivan gave you is absolutely right. Even though
an absolute path like /icons/... is appropriate for Graphics
#getImage(), you can not use it directly in your html code - it will
work from Eclipse but not in a deployment. Try this instead:
imageName = "icons/test" + Math.random() + ".gif";
Image image = Graphics.getImage( "/" + imageName, ...
browser.setText( "<img src=\"" + imageName + "/>" );
Ralf
Re: image + war [message #135468 is a reply to message #135442] Mon, 08 June 2009 06:57 Go to previous messageGo to next message
I don't set a background image. I want set a image but I don't know what
control is the best.
I try to set an image on a browser with the following code but if I deploy
the application as war, I don't will show the image.
imageName = "icons/test"+Math.random()+".gif";
image = Graphics.getImage(imageName, new ByteArrayInputStream(imageData));
browser.setText("<img src=\""+imageName+"\"/>");
I try to set an background image as test whether the image is correct on
the browser with the following code and it works.
browser.setBackgroundImage(image);
For this reason, I search a control where I can set an image. I tried this
with a label but I can scroll this control. It is right?
I have no idea what I can do to solve my problem.
Kristin
Re: image + war [message #135480 is a reply to message #135455] Mon, 08 June 2009 07:39 Go to previous messageGo to next message
it doesn't work :(
Kristin
Re: image + war [message #135530 is a reply to message #135480] Mon, 08 June 2009 11:40 Go to previous message
I have a solution. :D
It is correct that I set my image path without a "/" at the beginning.
But if I deploy my war and call my RAP application, the path of the
process image will be
"<servername>/<servletName>/org.eclipse.swt.browser/icons/test0.21146213068309738.jpg ".
I think that the package name of the browser is false in these url. I see
my image when I delete the package name of the browser.
I don't know why but I changed my code snippet from:
imageName = "icons/test"+Math.random()+".jpg";
browser.setText("<img src=\"" + imageName + "\"/>");
to this code snippet:
browser.setText("<img src=\"" + "/<servletName>/"+imageName + "\"/>");
I set for the "<servletName>" the application servletName and then it
works.
Kristin
Previous Topic:Combo
Next Topic:webappBuilder: binary cycles?
Current Time: Wed Apr 16 00:44:15 EDT 2025
Powered by FUDForum. Page generated in 0.05346 seconds
