Creating a new Visual Class [message #12394] |
Mon, 22 December 2003 08:10 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: ERASE-adamsawchuk.hotmail.com
First of all, let me congragulate the development team on the VE, it is
already very powerful, I find it very usefull when trying to layout a GUI
using the layout managers.
I would like to make one small suggestion though:
When you create a new visual class it gives you the option to create a
method stub for the public static void main(String[] args).
VE creates the stub correctly but it does not instantiate an instance of the
class. I thought that if a class had a main method it was assumed that it
would instantiate itself, but I guess it doesn't have to.
Anyway I thought it might be good if that option was selected it would also
instantiate an instance of itself.
Adam
Re: Creating a new Visual Class [message #13284 is a reply to message #12420] |
Fri, 02 January 2004 17:00 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: mendelgili.netscape.net
--------------090501070604020400000405
Content-Type: text/plain; charset=us-ascii; format=flowed
David J. Orme wrote:
> JustBeginning wrote:
> Thanks. A lot of people have worked hard to make the VE project happen.
>> of the
>> that it
>> also
> Hmmmm.... That option comes from the JDT project, I believe, and we just
> carry it forward in the VE project.
> Probably this should be another option--another checkbox that people can
> optionally use to have Eclipse construct the class when it generates a
> main() method.
> Feel free to add a bug against JDT requesting this feature. :-)
Yes. the main() option carried over from the JDT wizard. And it is a
good idea to generate this stub if the main() is selected on the wizard.
open an bugzilla enhencement.
Note that a main()+instance generation was typically made in the past so
that one to be able and Run/Debug the bean. It is not needed with VE,
as the "launch as a JavaBean" will run/debug a Components with out a
main method; hence removing the need to create a main() (most beans are
typically embedded soemwhere else).
In the meantime, you can use a Java template to generate the bean (see
attachement).
Content-Type: image/jpeg;
name="Image2.jpg"
Content-Disposition: inline;
filename="Image2.jpg"
/9j/4AAQSkZJRgABAQEASABIAAD/2wBDAAUDBAQEAwUEBAQFBQUGBwwIBwcH Bw8LCwkMEQ8S
EhEPERETFhwXExQaFRERGCEYGh0dHx8fExciJCIeJBweHx7/2wBDAQUFBQcG Bw4ICA4eFBEU
Hh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4eHh4e Hh4eHh7/wAAR
CAIYAuQDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDyB9QWxtoZpEkkLsEVUGWJ PQAVfv76/wBN
hSS/0TU7QOMqJ4ShIHXg81c8Ix6Smu6VLrN0La1iuElEjMFQOrArvJUhVz3y uODuHQ9R4n1K
z1fVb+7167nl1Jp3F00zsrBwSNuPJGAMYAxjAGOK/YMzzLEYbEypwmklbe3Z eR8xl2VYLE4a
NSrT5m79X0b7M4bS9YXU7dpoVkRQ20h+uamM0mfvGo7aPTFluf7JYvB5mTli 3zd+qr7dvxr6
M+MWurpuufE6y8Ra9p15ZXdnDFoeiveJPcxXRtodkqQhi0CB9zHIXOd3Q5O9 POqlKjQc487n
zdbbSS0SWr18tjzMRlNF4mtGl7sYcvnvG+rb0289z5386T+9R50n96vWLb4c eGL3xZ4H8J21
zrUeo67pVtqt9cySRNDFE8UzukahQ28tDgZJAByd3Stb4YaB4Dt/jD4N/sm+ TVDfRXkr6e+q
Wd7JYTQKSjytb7kYMCGVRghhncdpWuitxDhqcW1dtJyta10r9f8At1/d6X5K eT1pNXta6X32
/wA0eI+dJ/eo86T+9Xq+ieEvDXiPwzpXjDxl4rvbG88VvezQXup63aqlosR2 xiXzdjzkkKP3
KqqggYQYzj2fg/w5deDPAU8curjXPGNxJFC++M2tuqXccRdk2hz8kgIAbkjq BV08+w0tHe6d
no3Z2d/kuV39NtUKplNWL0Sta69NPzujgPOk/vUedJ/er1TxF4D8DW3ijR9F 03xBL9qn8Tro
l5YPqdncXRi3YNyqwkmIZVl2yLuBK7gOh0rP4VeFdb1K0tdGvtatFHiy68O3 TXbxSF/s8Esz
yR7VXbuEJAznGc89Kj/WLBKCm27NN7bWH/Y2I5nHlVzxnzpP71HnSf3q9A8D eHPBXjPVJpNN
XxDYabYaTd6peLeXdqHlSNlESpKQqRllYMxcbV5G4j5q3ND8AfDzVPEV7p9j 4lm1WT+z7S7s
9PsdVs3naSQyCa384ZieWMR7sDbkMOcfNWlXPcNRbjO6aV7W/r1vtbqTDKq0 1eKTV7b/ANen
qeR+dJ/eo86T+9VnVbJ7TVbyzNvc25t7iSLyrgL5qbWK4faSNwxzg4zVbym9 D+VezC84qS2Z
50lGLafQPOk/vUedJ/eo8pvQ/lR5Teh/Kq5ZE+6HnSf3qPOk/vUeU3ofyo8p vQ/lRyyD3Q86
T+9R50n96jym9D+VHlN6H8qOWQe6HnSf3qPOk/vUeU3ofyo8pvQ/lRyyD3Q8 6T+9R50n96jy
m9D+VHlN6H8qOWQe6HnSf3qPOk/vUeU3ofyo8pvQ/lRyyD3Q86T+9R50n96j ym9D+VHlN6H8
qOWQe6HnSf3qPOk/vUeU3ofyo8pvQ/lRyyD3Q86T+9R50n96jym9D+VHlN6H 8qOWQe6HnSf3
qPOk/vUhjI9aTYaOWQ/dHedJ/eo86T+9Tdho2GjkkFojvOk/vUedJ/epuw0b DRySC0R3nSf3
qPOk/vU3YaNho5JBaI7zpP71HnSf3qbsNGw0ckgtEd50n96jzpP71N2GjYaO SQWiO86T+9R5
0n96m7DRsNHJILRHedJ/eo86T+9Tdho2GjkkFojvOk/vUedJ/epuw0bDRySC 0R3nSf3qPOk/
vU3YaNho5JBaI7zpP71HnSf3qbsNGw0ckgtEd50n96jzpP71N2GjYaOSQWiO 86T+9R50n96m
7DRsNHJILRHedJ/eo86T+9Tdho2GjkkFojvOk/vUhml7NSbDRsNHLIPdF8+b 1o8+b1pPL+lH
l/SnyyD3RfPm9aPPm9aTy/pR5f0o5ZB7ovnzetHnzetJ5f0o8v6Ucsg90Xz5 vWjz5vWk8v6U
eX9KOWQe6L583rR583rSeX9KPL+lHLIPdF8+b1o8+b1pPL+lHl/SjlkHui+f N60efN60nl/S
jy/pRyyD3RfPm9aPPm9aTy/pR5f0o5ZB7ovnzetHnzetJ5f0o8v6Ucsg90Xz 5vWjz5vWk8v6
UeX9KOWQe6L583rR583rSeX9KPL+lHLIPdF8+b1o8+b1pPL+lHl/SjlkHuna 29hp1vpsBktI
biZoY5HeZ5ASXRXwAjqABux+FUp7jTY/+YVp+f8AfuP/AI7U84mmmhtoI3kk NnbYRFJJ/wBH
jPQVlarpt/bp5tzZ3MKE7Q0kbKM+mSPavKppyaUpu78z1fZ01G6ivuGTzwXc F4IbGC1ktoRM
rwvIQ48xEKkOzf3wQRjoeuePaZ/A2g29xPpel+F4NYuLOSSGR5GvJJpPLbY0 jCKZVAJHQKAM
gc9a8O05cw6qP+nEf+lENfQMGvX+leKfHl7plx5F3ayXIjfarbc38anhgR0J 7V5uayxEGlSk
931a/kSu1rbU68HToSbcorZdF/e/yMG48GzoDs+Fiv8AS11P/wCP1yUGjaP4 lmsIrbTo9Fkb
XrDTJWs5ZXSSO68358TO5Dr5J6Ng7unHPoPhj4m+Pb3xnolhc675lrc6hbwz J9kgG5GkUMMh
MjIJ6c1xPw1PmX1iP7vjHQCfzvK5YTxtKnOVaWqs1aUnu2tU9OhcoYWclGEd He90ltbsdf8A
8Ih4JMcbReG9NZGQMDLdXjP/AMCKzqCfoAPYUVn2l+WtYjnogFFfhX+tOavX 6zP/AMDl/mfu
v+qWWR09hD/wFf5Hhktlb30VsJWCtA3mRkoG2uBwcHg4znBBHtTrzRZ9QRRe +IdSuGVNvmSM
rOw/2mxlvqSa+jfg/wDCnwDr3w80zVtV0H7RezGYSSfbJ03bZnVeFcDhVA6d q64fBT4ZDp4b
P/gfc/8Axyv2LMeJMk+tVI16EnJNpvTW2n8y7H4thMBmsaEfYVlGLV0rLrr/ ACvufJeg6Pba
PavbwzySqzbsydc1ta5qV9rmu32t6xfNe6hfSLJPKyImdqLGoAQKAAqKOnbn Jr6b/wCFK/DP
/oW2/wDBhc//AByj/hSnwz/6Fs/+B9z/APHKuhxvk9BRUKM1y3tpHS+r15r6 nPX4dzGvKUql
VNytfdXtotEraHzcfEmuHXdP1o6xOL3TLSCysZEVE+zww7tiDaBu++2S2Sc4 PHFXn8eeMZNe
stdk8SzNqGnxyR2UgtbdVtxICH2xrGEJIPVga+g/+FKfDP8A6Fs/+B9z/wDH KP8AhSnwz/6F
s/8Agfc//HKmXGeRytfDy0TXwx2d7r4tnd3XmC4ezJXtWXTq+lrdOlkfOnh7 xh4p8PeH49C0
TxFc2VjGrKiiKGRlDDDbWkRime+zbzzVGbVtTmttFtZNTn+z6Ikq6cihVMBk kWR2DgByxZFO
SxxjjFfTP/ClPhn/ANC2f/A+5/8AjlH/AApT4Z/9C2f/AAPuf/jlOPGuSRk5 qhK9735Y76q/
xb2bXzYPh3MZR5XWVtt3/l5Hz5qfjzxhqd9YXWoeI5pzp12t5ax/Z4ERJx0k O1AXP++Wqpbe
KvEtv5XleILpTHrMuuFljiRnvZVZXlJVAeQ7DYMLg9K+jv8AhSnwz/6Fs/8A gfc//HKP+FKf
DP8A6Fs/+B9z/wDHKhcYZCkorDOy/ux9f5inkGZt3df8X6dj56Xxx4tXVoNT HiGVbi3jljhE
dtbxRqsp3SZjSNUfceTvDZPNPXx/40W/udQPiaWS7uBArSSWVq4UQsWi2oYt ilWJIIUHPOa+
gv8AhSnwz/6Fs/8Agfc//HKP+FKfDP8A6Fs/+B9z/wDHKT4vyF/8wz7fDHa9 /wCbvr6h/YOZ
/wDP9fe/TsfLUjGaaa4uLh7i4nleaaWRstJI7FmYn1JJP40mI/UV9Tf8KU+G f/Qtn/wPuf8A
45R/wpT4Z/8AQtn/AMD7n/45XbHxByyEVGNOaS8o/wDyRyy4Txcm5Oorv1/y PlnEfqKMR+or
6m/4Up8M/wDoWz/4H3P/AMco/wCFKfDP/oWz/wCB9z/8cqv+IiZd/wA+5/dH /wCSF/qjiv54
/j/kfLOI/UUYj9RX1N/wpT4Z/wDQtn/wPuf/AI5R/wAKU+Gf/Qtn/wAD7n/4 5R/xETLv+fc/
uj/8kH+qOK/nj+P+R8s4j9RRiP1FfU3/AApT4Z/9C2f/AAPuf/jlH/ClPhn/ ANC2f/A+5/8A
jlH/ABETLv8An3P7o/8AyQf6o4r+eP4/5HyziP1FGI/UV9Tf8KU+Gf8A0LZ/ 8D7n/wCOUf8A
ClPhn/0LZ/8AA+5/+OUf8REy7/n3P7o//JB/qjiv54/j/kfLOI/UUYj9RX1N /wAKU+Gf/Qtn
/wAD7n/45R/wpT4Z/wDQtn/wPuf/AI5R/wAREy7/AJ9z+6P/AMkH+qOK/nj+ P+R8s4j9RRiP
1FfU3/ClPhn/ANC2f/A+5/8AjlH/AApT4Z/9C2f/AAPuf/jlH/ERMu/59z+6 P/yQf6o4r+eP
4/5HyziP1FGI/UV9Tf8AClPhn/0LZ/8AA+5/+OUf8KU+Gf8A0LZ/8D7n/wCO Uf8AERMu/wCf
c/uj/wDJB/qjiv54/j/kfLOI/UUYj9RX1N/wpT4Z/wDQtn/wPuf/AI5R/wAK U+Gf/Qtn/wAD
7n/45R/xETLv+fc/uj/8kH+qOK/nj+P+R8s4j9RRiP1FfU3/AApT4Z/9C2f/ AAPuf/jlH/Cl
Phn/ANC2f/A+5/8AjlH/ABETLv8An3P7o/8AyQf6o4r+eP4/5HywRH7Ufu/a vqb/AIUp8M/+
hbb/AMGFz/8AHKP+FKfDL/oW2/8ABhc//HKP+IiZd/z7n90f/kg/1RxX86/H /I+Wf3ftR+79
q+pv+FKfDL/oW2/8GFz/APHKP+FKfDL/AKFtv/Bhc/8Axyj/AIiJl3/Puf3R /wDkg/1RxP8A
Ovx/yPln937Ufu/avqb/AIUp8Mv+hbb/AMGFz/8AHKP+FKfDL/oW2/8ABhc/ /HKP+IiZd/z7
n90f/kg/1RxP86/H/I+Wf3ftR+79q+pv+FKfDL/oW2/8GFz/APHKP+FKfDL/ AKFtv/Bhc/8A
xyj/AIiJl3/Puf3R/wDkg/1RxP8AOvx/yPln937Ufu/avqb/AIUp8Mv+hbb/ AMGFz/8AHKP+
FKfDL/oW2/8ABhc//HKP+IiZd/z7n90f/kg/1RxP86/H/I+Wf3ftR+79q+pv +FKfDL/oW2/8
GFz/APHKP+FKfDL/AKFtv/Bhc/8Axyj/AIiJl3/Puf3R/wDkg/1RxP8AOvx/ yPln937Ufu/a
vqb/AIUp8Mv+hbb/AMGFz/8AHKP+FKfDL/oW2/8ABhc//HKP+IiZd/z7n90f /kg/1RxP86/H
/I+Wf3ftR+79q+pv+FKfDL/oW2/8GFz/APHKP+FKfDL/AKFtv/Bhc/8Axyj/ AIiJl3/Puf3R
/wDkg/1RxP8AOvx/yPln937Ufu/avqb/AIUp8Mv+hbb/AMGFz/8AHKP+FKfD L/oW2/8ABhc/
/HKP+IiZd/z7n90f/kg/1RxP86/H/I+Wf3ftR+79q+pv+FKfDL/oW2/8GFz/ APHKP+FKfDL/
AKFtv/Bhc/8Axyj/AIiJl3/Puf3R/wDkg/1RxP8AOvx/yPln937Ufu/avqb/ AIUp8Mv+hbb/
AMGFz/8AHKP+FKfDL/oW2/8ABhc//HKP+IiZd/z7n90f/kg/1RxP86/H/I+W f3ftR+79q+pv
+FKfDL/oW2/8GFz/APHKP+FKfDL/AKFtv/Bhc/8Axyj/AIiJl3/Puf3R/wDk g/1RxP8AOvx/
yPln937Ufu/avqb/AIUp8Mv+hbb/AMGFz/8AHKP+FKfDL/oW2/8ABhc//HKP +IiZd/z7n90f
/kg/1RxP86/H/I+Wf3ftR+79q+pv+FKfDL/oW2/8GFz/APHKP+FKfDL/AKFt v/Bhc/8Axyj/
AIiJl3/Puf3R/wDkg/1RxP8AOvx/yPln937Uh8s19T/8KU+GX/Qtt/4MLn/4 5Qfgn8Mj18NM
f+4hc/8Axyj/AIiJl3/Puf3R/wDkh/6pYn+dfj/kfLGI/WjEfrX1N/wpL4Y/ 9C0f/A+5/wDj
lH/Ckvhj/wBC0f8AwPuf/jlH/ERMu/59z+6P/wAkH+qWJ/5+L8f8j5ZxH60Y j9a+pv8AhSXw
x/6Fo/8Agfc//HKP+FJfDH/oWj/4H3P/AMco/wCIiZd/z7n90f8A5IP9UsT/ AM/F+P8AkfLO
I/WjEfrX1N/wpL4Y/wDQtH/wPuf/AI5R/wAKS+GP/QtH/wAD7n/45R/xETLv +fc/uj/8kH+q
WJ/5+L8f8j5ZxH60Yj9a+pv+FJfDH/oWj/4H3P8A8co/4Ul8Mf8AoWj/AOB9 z/8AHKP+IiZd
/wA+5/dH/wCSD/VLE/8APxfj/kfLOI/WjEfrX1N/wpL4Y/8AQtH/AMD7n/45 R/wpL4Y/9C0f
/A+5/wDjlH/ERMu/59z+6P8A8kH+qWJ/5+L8f8j5ZxH60Yj9a+pv+FJfDH/o Wj/4H3P/AMco
/wCFJfDH/oWj/wCB9z/8co/4iJl3/Puf3R/+SD/VLE/8/F+P+R8s4j9aMR+t fU3/AApL4Y/9
C0f/AAPuf/jlH/Ckvhj/ANC0f/A+5/8AjlH/ABETLv8An3P7o/8AyQf6pYn/ AJ+L8f8AI+Wc
R+tGI/Wvqb/hSXwx/wChaP8A4H3P/wAco/4Ul8Mf+haP/gfc/wDxyj/iImXf 8+5/dH/5IP8A
VLE/8/F+P+R8s4j9aMR+tfU3/Ckvhj/0LR/8D7n/AOOUf8KS+GP/AELR/wDA +5/+OUf8REy7
/n3P7o//ACQf6pYn/n4vx/yPlnEfrRiP1r6m/wCFJfDH/oWj/wCB9z/8co/4 Ul8Mf+haP/gf
c/8Axyj/AIiJl3/Puf3R/wDkg/1SxP8Az8X4/wCR8s4j9aMR+tfU3/Ckvhj/ ANC0f/A+5/8A
jlH/AApL4Y/9C0f/AAPuf/jlH/ERMu/59z+6P/yQf6pYn/n4vx/yPlnEfrRi P1r6m/4Ul8Mf
+haP/gfc/wDxyj/hSXwx/wChaP8A4H3P/wAco/4iJl3/AD7n90f/AJIP9UsT /wA/F+P+R87L
LerqEGqaTcWeVt4ox5l1DGyMsSxsCsjD0ODgjBp2r3XiPU7YW95cafLGrbwP t9ovOCOzj1Nf
Q/8AwpL4Y/8AQtH/AMD7n/45R/wpL4Y/9C0f/A+5/wDjlcT43yzmUvZyutm4 xv8AfzHcsgxi
hyc6s/N/5HzFaWkmnx38l7JbA3FuIYkiuY5ST5qOSdjHAAQ9fUe+PQ7q+1yP xbruteHrzw7c
2GsXE0yfatSsBuikl80I8Ny4KspC5yvVeCRzXrX/AApL4Y/9C0f/AAPuf/jl H/Ckvhj/ANC0
f/A+5/8AjlZ4njXLq+rjO+u8Yta26c3kupdHIsVSeko9Or6X8vM8lGteOIZo 7i1j8EQzxMHj
kS50MMjA5BB3cEHvWP4Tmh8IyWs+vXtgZZPEWm3/AJNneRXZjgtfP3szQsyg nzlwucna3A4z
7l/wpL4Y/wDQtH/wPuf/AI5R/wAKS+GP/QtH/wAD7n/45WEeLss5XBwkk97Q im7ba87KeSYr
m5lJX823+h4xFa6jAvkxX3h24jU4SVfEFkgdex2vKGGfRgCO4FFezf8ACkPh f/0LH/k/c/8A
xyivz7+x+Hek633Q/wAz9F/1uzzrCl/5N/mWvgB/ySXRv965/wDSmWui1nxH baZqcenNY6ne
XMkJnVLK0ac7A20kheRgkfmK534Af8kl0b/euf8A0plrodO/5K5B/wBgGb/0 oirpzdXzGuv7
8v8A0pnzWA/3Sl/hX5Ir/wDCVj/oWvFX/gnm/wAKP+ErH/QteKv/AATzf4VN 49+IOleDnaXX
fEOi6VFJfwWVtFdbRLLvMCvIN8yZSMzhnIHyoCTmui8Pa1Bf27ytqenXUTuh tbi2YCO4ieOJ
1dPmbcCZVAIJByvrXD7NHVzHL/8ACVj/AKFrxV/4J5v8KP8AhKx/0LXir/wT zf4VV8a/Eqbw
tea7aakLKCaz1KxktFaGR/M0l4fOubhipI3pHaaqyrwf9GQbGLoJLlt8Qrlt U1G0t9Bvdcd9
Su4dIt9M8mOWa1tFghu5pDcSxoPLvJJIcZDMNjKrLl6fskLmG/8ACVj/AKFr xV/4J5v8KP8A
hKx/0LXir/wTzf4VkeI/i9pV3oFxqPh2e9tbCw1LRftmtXVusNkLW7nsJD88 uPv2122fl3R7
WL+XmIvNcfEu90/xlrE994f8QHwza+H7LU5nMFvG2mxme/EtzNG8iz7Xigjc RqryKEIMaOSh
PZIOY0f+ErH/AELXir/wTzf4Uf8ACVj/AKFrxV/4J5v8KztT+O/gWw1nWtLk lmll0mK+ZvJu
LV5J5LOOSSeJYBN56MBDNh5Y442KcOQ8Zfaf4kW8Mx0278LeILXxC0sKW+hy G0a5uRKk7o6S
LObcKVtLo/PKp/cNxlow57JBzFb/AISsf9C14q/8E83+FH/CVj/oWvFX/gnm /wAKq6B8QtRj
8V+IbPX9B1q30yPW7Kxt7x/shi097mysSlrKI5TIzm4uMbkWRAZR8+xSV9Mo 9kg5jz3/AISs
f9C14q/8E83+FH/CVj/oWvFX/gnm/wAK9Coo9kg5jz3/AISsf9C14q/8E83+ FH/CVj/oWvFX
/gnm/wAK9Coo9kg5jz3/AISsf9C14q/8E83+FH/CVj/oWvFX/gnm/wAK9Coo 9kg5jz3/AISs
/gnm/wAK9Coo9kg5jjtE1VtVabbpWrWSwqGLX1m0AbJxhd3LH6dO/UZ0a1dT /wBSf93/ANmW
sqs5R5XYpO5WtZ725tormDRr14pUDo2+EZUjIPMnpUn/ABMv+gJe/wDfyD/4 5VPWvE6+Dvhh
b+I5tF1PVrSx05Z7tLAweZDCkBd5SJpIwVAXopLEkYU84boXxI8PXngew8Y6 63/CIaTqXltY
ya/eWsH2hJIhLGylJnUblJwrEP8AK2VAGa19mieZl7/iZf8AQEvf+/kH/wAc o/4mX/QEvf8A
v5B/8cpNV+IXgHSfsn9qeOPDNh9stku7X7TqsEfnwPnZKm5huRsHDDIODg1M /jfwXHDqsz+L
/D6xaNKsOqOdShC2Ls5RUmO792xcFQGwSQR1o9mg5mRf8TL/AKAl7/38g/8A jlH/ABMv+gJe
/wDfyD/45XPeMPi3oGl2Phi+8OXGmeKbTXPFNp4deew1JHjtXnDEuWQOGZQF OzgkMORW1q/x
H8F2Fj4hmh8RaZqd34esbm91HTrC9hmu4ktwTKDEHyrAjb82AGIBIo9mg5mT /wDEy/6Al7/3
8g/+OUf8TL/oCXv/AH8g/wDjlUdC+KXgHVvA9h4x/wCEr0Ww0m88tPMvdQgj 8id4hL9mkO8q
syqfmjySMHtzWnrHjfwXo1jp99q/i/w/p1pqUXnWE91qUMUd0mFO+JmYB1w6 nK5GGHqKPZoO
ZkX/ABMv+gJe/wDfyD/45R/xMv8AoCXv/fyD/wCOV0tFHs0HMzmv+Jl/0BL3 /v5B/wDHKP8A
iZf9AS9/7+Qf/HK6Wij2aDmZzX/Ey/6Al7/38g/+OUf8TL/oCXv/AH8g/wDj ldLRR7NBzM5r
/iZf9AS9/wC/kH/xyj/iZf8AQEvf+/kH/wAcrpaKPZoOZnNf8TL/AKAl7/38 g/8AjlH/ABMv
+gJe/wDfyD/45XS0UezQczOa/wCJl/0BL3/v5B/8co/4mX/QEvf+/kH/AMcr paKPZoOZnNf8
TL/oCXv/AH8g/wDjlH/Ey/6Al7/38g/+OV0tFHs0HMzmv+Jl/wBAS9/7+Qf/ AByj/iZf9AS9
/wC/kH/xyuloo9mg5mc1/wATL/oCXv8A38g/+OUf8TL/AKAl7/38g/8AjldL RR7NBzM5r/iZ
f9AS9/7+Qf8Axyj/AImX/QEvf+/kH/xyuloo9mg5mc1/xMv+gJe/9/IP/jlH /Ey/6Al7/wB/
IP8A45XS0UezQczOa/4mX/QEvf8Av5B/8co/4mX/AEBL3/v5B/8AHK6Wij2a DmZzX/Ey/wCg
Je/9/IP/AI5R/wATL/oCXv8A38g/+OV0tFHs0HMzmv8AiZf9AS9/7+Qf/HKP +Jl/0BL3/v5B
/wDHK6Wij2aDmZzX/Ey/6Al7/wB/IP8A45R/xMv+gJe/9/IP/jldLRR7NBzM 5r/iZf8AQEvf
+/kH/wAco/4mX/QEvf8Av5B/8crpaKPZoOZnNf8AEy/6Al7/AN/IP/jlH/Ey /wCgJe/9/IP/
AI5XS0UezQczOa/4mX/QEvf+/kH/AMco/wCJl/0BL3/v5B/8crpaKPZoOZnN f8TL/oCXv/fy
D/45R/xMv+gJe/8AfyD/AOOV0tFHs0HMzmv+Jl/0BL3/AL+Qf/HKP+Jl/wBA S9/7+Qf/AByu
loo9mg5mc1/xMv8AoCXv/fyD/wCOUf8AEy/6Al7/AN/IP/jldLRR7NBzM5r/ AImX/QEvf+/k
H/xyj/iZf9AS9/7+Qf8Axyuloo9mg5mc1/xMv+gJe/8AfyD/AOOUf8TL/oCX v/fyD/45XS0U
ezQczOa/4mX/AEBL3/v5B/8AHKP+Jl/0BL3/AL+Qf/HK6Wij2aDmZzX/ABMv +gJe/wDfyD/4
5R/xMv8AoCXv/fyD/wCOV0tNlYIhO4LwfmIyBx1PtR7JBzM5z/iZf9AS9/7+ Qf8Axyj/AImX
/QEvf+/kH/xytySXBJEkiZGRlRjt2PJ7Dju2PpAzn/ntOSdrAgDPOODztPOA MDH1G6qVFC5z
K/4mX/QEvf8Av5B/8co/4mX/AEBL3/v5B/8AHK0fNwRi4nPIxgZHX68jge5D L3JzGz4UES3b
YAAyGOc9MbWHU8ZPBPTgcV9XQvaFL/iZf9AS9/7+Qf8Axyj/AImX/QEvf+/k H/xyp3mCuMXc
+0njLdeQOu8Z5yMjj72OnEfmkhT9rvjk7Rt5ySBjHzHn1+uOKf1Zdxe1Gf8A Ey/6Al7/AN/I
P/jlH/Ey/wCgJe/9/IP/AI5TftP/AFEL3/vn/wCyo+0/9RC9/wC+f/sqf1Vd xe1Hf8TL/oCX
v/fyD/45R/xMv+gJe/8AfyD/AOOVG1yMc6jfD8Mf+z1G9yD/AMxLUMnOBtIz 3H8dP6ou4e1J
1OosMrot4RnHEsH/AMcoqqbxc/8AH/qj/wC6Dx9cP/nNFH1Rdw9qcp8AP+SS 6N/vXP8A6Uy1
0Onf8lcg/wCwDN/6URVz3wA/5JLo3+9c/wDpTLXQ6d/yVyD/ALAM3/pRFW2b f8jKv/jl/wCl
MywP+6U/8K/JGt4i0M3iTLcTWklpNqNpeLFLC2UnikhaJtwlTIEkUbY74xhs 4OvpdpPam6ku
biOaW5m81jHEY1GERAACzdk9e9cd8QvH2k+Eiz694i0fSYX1G3tLWK4YLLLu a3DSDdNHmOMz
q0mPuoCTnoek8Pa1Bf27ytqenXUTuhtbi2YCO4ieOJ1dPmbcCZVAIJByvrXI dBDrXg7QNZ8R
Q61qlhDdyx2M1k8E0KPDOknGZFZTuZEadF5wFubhcYkaswfD2zt9L0W30jXt a0m/0i2lto9V
t/s8l1cJMyPcGbzonjd5ZYo5Xk2By4JBG5w1Lxn411XR/iBpul2VvZPo9t9i /t1pkY3B/tC5
a0svs2GC/LPG5l3jhMFNzZFZni34urp3hXxFqdn4d1O0ayi1aDS76/WBrS+v bBLlniCxTGYK
fsk7ZdYwVjPzBmUGhHQad8NfDem6HNomnm9trCTUtO1BIlmDeS1itosEalgS U22MIbcSxy/z
DIxmXPwi0iS+1L7P4i8QWej6nYx6bd6LC1sbRrJDKfsqloWmji/0icARyKUV 9qFFSMJ3OiXt
zqGlw3l3pN7pE0m7dZ3jwtLHhiBuMLunIAIwx4Izg5Au0AcNqfw006/sda0q TxB4gi0XVor5
W0uGeJIIJLwSefKrCPzHYtNM4SV5I1Z8hBsj2XfEfgPTtZ8RP4iXU9T07WBF apbXdq0Ra1MH
2tQ6LJG6FmS+uEberjDAgKwDV1lFAHJr4D05rG+t7rU9Tu5b/V7DWLq4laIS SXFmLQIcJGqh
W+xRFgFHLPt2gqF6yiigAooooAKKKKACiiigAooooAKKKKAKmp/6k/7v/sy1 lVq6n/qT/u/+
zLWVXPU+IuOxneItEuvEvwV1Lw5YyQx3eq+HJbKB5iRGry2xRSxAJC5YZwCc djXnviL4PeIb
rR/hLJbXVlcX/gfTXsby1TVrrTVuvMs44WeK7gQyx7XiBxsG9WIJXofULBtS s7G3s4tQtDHB
EsalrBskKMDP77rxU32vVf8An+sv/ABv/j1a86Jszxa3+BWr2t3qh0Ww8P8A h/Trr4d3/he2
06LVbm8WC6uLuWYOZZIlZoj5mSSNwJICkAE8Z8dfgz40tvh299ZwQ6xLY/Dv SfC7WWmpNPcz
XUGo20rvHGI/mi2Ixzw3HKgc19Ofa9V/5/rL/wAAG/8Aj1H2vVf+f6y/8AG/ +PU+dBZni2sf
BbxprvxBm8cX1z4fsbu88ZaFrU9hDdzTxw2unW8kTbZjCheVzISFKKoC/fOe My9+A3xF1/X9
Ll8UeKLK++zW2vWl5rMuq3dxLdLqEEsMMkdg6CC18sOmYopApA6/KK98+16r /wA/1l/4AN/8
eo+16r/z/WX/AIAN/wDHqOdBZnjt78I/G1/o/wAL5LtNFW/8CW0unNa2fiG8 tFvoHs44RMt3
DAssDh4wTGEYFSQX6g0ta+BXiGOXwtdfD6Ky+HupaRbfZDead4ourpIoGvWu HiaCW1/0tPmZ
wryRAvIVYMiKT7f9r1X/AJ/rL/wAb/49R9r1X/n+sv8AwAb/AOPUc6CzN2is L7Xqv/P9Zf8A
gA3/AMeo+16r/wA/1l/4AN/8eo50FmbtFYX2vVf+f6y/8AG/+PUfa9V/5/rL /wAAG/8Aj1HO
gszdorC+16r/AM/1l/4AN/8AHqPteq/8/wBZf+ADf/HqOdBZm7RWF9r1X/n+ sv8AwAb/AOPU
fa9V/wCf6y/8AG/+PUc6CzN2isL7Xqv/AD/WX/gA3/x6j7Xqv/P9Zf8AgA3/ AMeo50FmbtFY
X2vVf+f6y/8AABv/AI9R9r1X/n+sv/ABv/j1HOgszdorC+16r/z/AFl/4AN/ 8eo+16r/AM/1
l/4AN/8AHqOdBZm7RWF9r1X/AJ/rL/wAb/49R9r1X/n+sv8AwAb/AOPUc6Cz N2isL7Xqv/P9
Zf8AgA3/AMeo+16r/wA/1l/4AN/8eo50FmbtFYX2vVf+f6y/8AG/+PUfa9V/ 5/rL/wAAG/8A
j1HOgszdorC+16r/AM/1l/4AN/8AHqPteq/8/wBZf+ADf/HqOdBZm7RWF9r1 X/n+sv8AwAb/
AOPUfa9V/wCf6y/8AG/+PUc6CzN2isL7Xqv/AD/WX/gA3/x6j7Xqv/P9Zf8A gA3/AMeo50Fm
btFYX2vVf+f6y/8AABv/AI9R9r1X/n+sv/ABv/j1HOgszdorC+16r/z/AFl/ 4AN/8eo+16r/
AM/1l/4AN/8AHqOdBZm7RWF9r1X/AJ/rL/wAb/49R9r1X/n+sv8AwAb/AOPU c6CzN2isL7Xq
v/P9Zf8AgA3/AMeo+16r/wA/1l/4AN/8eo50FmbtFYX2vVf+f6y/8AG/+PUf a9V/5/rL/wAA
G/8Aj1HOgszdorC+16r/AM/1l/4AN/8AHqPteq/8/wBZf+ADf/HqOdBZm7RW F9r1X/n+sv8A
wAb/AOPUfa9V/wCf6y/8AG/+PUc6CzN2isL7Xqv/AD/WX/gA3/x6j7Xqv/P9 Zf8AgA3/AMeo
50FmbtFYX2vVf+f6y/8AABv/AI9R9r1X/n+sv/ABv/j1HOgszdorC+16r/z/ AFl/4AN/8eo+
16r/AM/1l/4AN/8AHqOdBZm7RWF9r1X/AJ/rL/wAb/49R9r1X/n+sv8AwAb/ AOPUc6CzNxiF
GWIAzjmopJFyVErhiemAMZO3uPXkeuOM9KyPteq/8/1l/wCADf8Ax6j7Xqv/ AD/WX/gA3/x6
hTiHKzRaTL8SyLlsDdgYJOMcnrt5A7dSCcVCZWVFcSyjGRkqdpI+rZ6AZ5+u MPVT7Xqv/P8A
WX/gA3/x6k+1aruLfb7PJGP+PF//AI9VKrEXIy15hX7s9wxHQbSSce2efuj8 36c7YnljXIN5
cbQQuSeMfMc5z34Oep6D0EP2jVSoDahaE7dpP2Fxn34m60GfVCCPt9pyCP8A jyfv/wBtv/1d
qftoi5GEs5DHdd3AOMnJHoeRh8e4/wCA+vLZJsLuN1egfMSVOe+B/GflBwPf nn0Uzamc/wCn
2vP/AE5ye/8A039/5egoM2pnP+n2vP8A05ye/wD039/5egqvbxF7NkH2n/qI Xv8A3z/9lR9p
/wCohe/98/8A2VTNLqTZzqFtyMcWkg75/wCe/wDnpTWbUWYsdQgyTni2lH/t en9YgL2bIWus
Y/4mN7/3z1/8fpjXRHH9pahz/sdf/H/Y9Ks51H/oIw/+A0v/AMfozqP/AEEY f/AaX/4/T+sQ
D2bKD3nP/ITvvxGP/agoq/nUf+gjD/4DS/8Ax+in9ZgHs2cP8AP+SS6N/vXP /pTLXQ6d/wAl
cg/7AM3/AKURVz3wA/5JLo3+9c/+lMtdDp3/ACVyD/sAzf8ApRFV5t/yMq/+ OX/pTM8D/ulP
/CvyRreItDN4ky3E1pJaTajaXixSwtlJ4pIWibcJUyBJFG2O+MYbODr6XaT2 pupLm4jmluZv
NYxxGNRhEQAAs3ZPXvUuottt1O7b++iGd2OsijH3l/LPPTDfdIl/Yvt2Xts2 7G3EqnOduMc9
96f99L6iuWyOg4fxR8HfAPiZ/E1xreg2V7f+Ic+bqE1pBJdWn+jR24+zyNGT HtWIOuc4dmPf
Au6j8NfDepaHDomoG9ubCPUtR1B4mmC+c18t2s8bFQCE230wXaQwwnzHBzzN 58RPENv8T9V0
RfsTabY63ZaWls2i3SeYlxBas0jakZPs0bq1yxWFl3ybEjX55UNbN/8AE7Sj pHhK9s4r2H/h
J7azvrMy2qybIJruxgKSKJV2uft8YyCwXDNh9oR2I7PRLK50/S4bO71a91ea PduvLxIVlkyx
I3CFETgEAYUcAZyck3a8T0n4oa5f/DbwhPZ2ep3uozy+HINb1mOO1W2gmu5L J5onRnVyzw3K
8xRMq+cuGUq2z0DXtW1++8VT+FvC1zpmn3djYwaheXmpWb3UZSd5o4o44o5Y iWJt5SzlwFCo
Ar7yYwDrKK850v4uaNM19BqWl6nZy6TY3F7rM8UXnWllHbz3lvM/mjDOolsZ AoCCR1dGEeBL
5eNqXxePh3xVrbeLtJ1PQrGOx0tNP02/uNPjkluJn1AyOJhcGFVMdsP9bMvM JCjc6hwD1+iu
G8F/FDQPGGrWunaBZ6ndmexW9kuY40a2t0MtzCweZXKMyzWrx/IXD7laMvGH dO5oAKKKKACi
iigAooooAKKKKACiiigCpqf+pP8Au/8Asy1lVq6n/qT/ALv/ALMtZVc9T4i4 7GR/wlPhn/hJ
P+EZ/wCEj0f+3P8AoG/bY/tX3N/+qzv+583Tpz0rXryGTUNR0b4M6j4KgsPE cfjG18O3cRuL
PSrt0ub8W7s1xHdpGY2eWTMoYuJGaQBgspKin8R9I8ZWniG2s9L8R+I47aLT ozptxHYXd/Lc
ai00zTNIbeeGBOtthbsfZgDtRUjWRamw7nsl9dWtjZT3t7cw2trbxtLNNM4R IkUZZmY8AAAk
k8ACpq+fviVb+N9b8Qa5pmlwawk2r2+qaZNpf2O/e1MH2C5W3l+1SSmxXzZE tnxGkbqZdjPk
S77ni638RT39h/wi2r+L9O0ddOX+xfO0vVru6e+8+fzfN3zxbcf6Nt+37oSD 8uEEmXyhc91o
rO0jWbXU9Q1iyt45lk0i9WzuC4ADO1vDOCuCcjbOg5wchuMYJ8P8MW/xFj0q 5l1DV/EdzeNb
23/CQ2yaXfQ+W5urf7X5Es07h3EH20L/AGdGqnqu1vs4KSA9qHifw9/aV1pr 6xZw3lrcLbSw
zSCNvNZYCFXdjfn7VbDK5G6ZF+8cVr182XGhanfapq8WkWHjU+GZtVF/Ibsa jHcSxwS+H3aQ
GbFw0ipDe+XjMh2OsWeBXrHjbf8A8It4b+x/8JH/AMI/9oj/ALU+y/bP7R+x /ZpfLzs/0zf5
/wBm3bf3n3t/y+ZTaC53dFeW/DCx8TXHjC4vNcvPEcemWmnRnS7e6lkSKVGv dRWFpQw3vMto
bbcsh3ZZGlUyKjJD4p0/xhIvj/UNO1LXYpf7Vs7fT4j5rww2BhsDeSwRRlHk JUXA/dtvDI4h
KSO5ZW1A9Yor5+lsPG66LNc2ep+L78afo2t32juttf2WbuNbE2qPDNPJPP8A vftW2O6Lb8yB
UMQTO7e22p2HiK70rW28av4Ksr24jtXsZtRnumka20+SEma3JupY976iNzM0 YYBSQViUPlC5
7JRXlugWPxCa70DTNcvLwf2lb2OrazciU77W5tYo1ubVHjHlIksy2pEYBDqb 85GUqn8D7fxl
HrTS+JdX1i5uG07/AInFtcaXdwwR3xaP7ktzO8b4PngfYo1hIyTtHkgqwXPW LO6tbyJprS5h
uI1keJnicMA6OUdcjurKykdQQQeRU1eFahpGuadoWp2Omy+I9NuJfFV5c65I sGpXUS2M099N
bNbJbyIx3M9sXFm4YFv33AdaLXSvGUxWa71DxfdGK30e2tpVa7sle3uNVuor omETOd62TRZe
VmnjUJI5jlBIfKFz3WqekanY6taPdafP50KXE9szbGXEsMrxSLggHh0cZ6HG RkYNeCXF14gO
s+INLlufGreIbHSnj8LwwPqBhWZdR1SK0e52fuWDRxWn7y7ysiruZmG80eMP +Ez07w1eLpVt
rul3lne65faU9rpupXZvrmTUrt442jtZEjQBVgdWukljkE/ClVkDHKFz6Bs7 q1vImmtLmG4j
WR4meJwwDo5R1yO6srKR1BBB5FTV4VqGka5p2hanY6bL4j024l8VXlzrkiwa ldRLYzT301s1
slvIjHcz2xcWbhgW/fcB1q3psfiqLV/CUd7eeI9eI8sLaPa6jpSwxG7kP2uS dJJI5NsAjH2W
8cyssYLFZZHjkLBc9qorI8I/8gqb/kMf8hG+/wCQp/rv+PqX7v8A0x/55f8A TLy616kYUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABR
RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBwnwA/wCS S6N/vXP/AKUy
10Onf8lcg/7AM3/pRFXPfAD/AJJLo3+9c/8ApTLXQ6d/yVyD/sAzf+lEVepm 3/Iyr/45f+lM
48D/ALpT/wAK/JHZai223U7tv76IZ3Y6yKMfeX8s89MN902K4H4hePtJ8JFn 17xFo+kwvqNv
aWsVwwWWXc1uGkG6aPMcZnVpMfdQEnPQ9J4e1qC/t3lbU9OuondDa3FswEdx E8cTq6fM24Ey
qAQSDlfWuW50GNcfD2zuPE99q82va01lf6lbapc6R/o4tJLq3SBYZNwi88bT bQPtEoUsnIKl
lOZB8ItIju9LaTxF4gnsdGihg0mwka2ENjDFd2lykSMsIkdQ1jAmZHdiob5t x3VDq/jHxVp1
/wCONdaXRZPDXhC523NgLGUXtxAthb3UrpcedsDgTvtQxYbYFLpuLri+P/jj 4eg0/wAY6HoG
oeRr+nabqi2Nx51rJm9tLeZ3X7P5jTrsMMh3SwrG3l8MwePexHQWHwi0jTrH TNM07xF4gtNL
spdNnmsUa2aO+msBbrBLKzwmQMVtLdWEbRqRHwoLMT03iTwwuq3yanp+tan4 f1QRCCS+00QG
SaEEsIpFmjkjdVZiykruQs+1lEkgbM0/4hWc2v2Xh7U9B1rRdYvLlIUs7z7O 7IjwXU0czNDL
ImxhZXCgBi4ZBlQrBjmaz8XdIsdO1a+s/DviDVotFiu59VFotsrWcNvcXNuZ W82ZN6u9ncFR
HvbEfzKpZQQDag+HfheKHWLUWszWOs6RHpF7atOxWWFXuXZi+fMMsjXcxeQu WYndndknL/4V
jHJqk2tXnjTxNea4fs32XU5VsllsvJW5VfLRLZYmyl7cqfMR+HyMFVI9AooA 5/w34VtdE1a5
1ZdR1O/vruxt7O4mvZxI0giluJQ/CjazPdSZVcIoCKioqgV0FFFABRRRQAUU UUAFFFFABRRR
QAUUUUAVNT/1J/3f/ZlrKrV1P/Un/d/9mWsquep8RcdjlrH4cfDyxvYL2y8B +FrW6t5Flhmh
0iBHidTlWVgmQQQCCOQRXU0UVBQUUUUAQ2dra2cTQ2ltDbxtI8rJEgUF3cu7 YHdmZmJ6kkk8
mpqKKACiiigAooooAKKKKACiiigAooooAhS1tUvZb1LaFbqWNIpJggDuiFii lupCl3IHQF2x
1NTUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAF
FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRR
QBwnwA/5JLo3+9c/+lMtdDp3/JXIP+wDN/6URVz3wA/5JLo3+9c/+lMtdDp3 /JXIP+wDN/6U
RV6mbf8AIyr/AOOX/pTOPA/7pT/wr8ka3iLQzeJMtxNaSWk2o2l4sUsLZSeK SFom3CVMgSRR
tjvjGGzg6+l2k9qbqS5uI5pbmbzWMcRjUYREAALN2T171x3xC8faT4SLPr3i LR9JhfUbe0tY
rhgssu5rcNIN00eY4zOrSY+6gJOeh6Tw9rUF/bvK2p6ddRO6G1uLZgI7iJ44 nV0+ZtwJlUAg
kHK+tch0GNd/D2zutf1e/uNe1qTTNauUudS0Q/Z/sV06wRQYc+V5xQrBHuj8 3Y+CrBkZlMOp
/DTTr+x1rSpPEHiCLRdWivlbS4Z4kggkvBJ58qsI/Mdi00zhJXkjVnyEGyPZ z/jX4tyeHbL4
jxtp17Lf+HPM/sxodDvbi1fGnQXK/aJokMa/vZXDZdMIFJx940vH/wAcfD0G n+MdD0DUPI1/
TtN1RbG4861kze2lvM7r9n8xp12GGQ7pYVjby+GYPHvoR1r/AA3t5pjqV34p 8QXXiFZYXt9c
kFotzbCJJ0REjWAW5ULd3Q+eJj+/bnKxlOS8YfCHV30CfQ/CniC9h/tu2u7P xBqd5dwLLcRT
zzzZaEWbpJte8uiFia1JDhS/3WTs9C+IVnqmuR6e+g61YW1xqV5pdlqNz9nN veXVq0yyxoI5
WlXi2nYNIiKRGeclQ3Z0AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAFT U/8AUn/d/wDZ
lrKrV1P/AFJ/3f8A2Zayq56nxFx2OR0PUvGms6YmpWdv4cjt5JJUQT3E6udk jRkkKhA5U9zV
3Hjz/nn4U/8AAq4/+NUfDX/kRrD/AK7Xf/pVLXmPw9+Ievjw/wCCIvFmuQ/b LmSG/wBUvpo4
YUudOudKvbuORtqhIQksDxHBDEWu84WQAqwz07Hjz/nn4U/8Crj/AONUY8ef 88/Cn/gVcf8A
xquI034r61qGoW+hW/g+GPXp72GFYby5vLO3EUtvdzLJvns0lJ/0KVSBCV+Z cOTuCkvxjZdL
tJo/DM0l5qsdldaTBFJNOJbW7iuZYWm8mCSWOQJZz7kjjmVTs+cqWZC3kF0d vjx5/wA8/Cn/
AIFXH/xqjHjz/nn4U/8AAq4/+NVa8G6zN4g8N2mrXGl3mlzTb1ktbqGSN0ZH ZCQsio+xiu5S
yIxVlJVSSo16QznsePP+efhT/wACrj/41Rjx5/zz8Kf+BVx/8aroaKLoDnse PP8Ann4U/wDA
q4/+NUY8ef8APPwp/wCBVx/8aroaKLoDnsePP+efhT/wKuP/AI1Rjx5/zz8K f+BVx/8AGq6G
ii6A57Hjz/nn4U/8Crj/AONUY8ef88/Cn/gVcf8AxquhoougOSbUPGo12PRx D4Ya5e1e6yLm
42qiuicny+pLjGM9DnHGbmPHn/PPwp/4FXH/AMaoX/kqKf8AYAm/9KIao6zP q2t+M7vwvp+t
3mgQ6dp1tfy3VlFBJPO08lxGsY8+ORERRbuT8pZi6YZAjCR6AXsePP8Ann4U /wDAq4/+NUY8
ef8APPwp/wCBVx/8arFm8ZX2malLYtY/2hpelajZaLqGpT3apeSXdwtuI3WB IhG6E3UBZt8e
MybUO1Q/LX/xO8VXXhLQb2LQtN0vUPEEem6hpKxam1wklvJfWMUsVwzW6+SW W9jXKLLgFyMF
V3FvIR6Hjx5/zz8Kf+BVx/8AGqMePP8Ann4U/wDAq4/+NVzTfEnUU8bL4aPh K8uPs1xbWWpz
2cd3cLBcTRRSEo623ktCgnjLPJLC4UOfL4QPD4q8b+Jf7EuF0fR4bLU9O1XT dPv/AD7xTD9q
nvbVTbowjYtG8E28zFFZVmiwhk8xIi3kB1ePHn/PPwp/4FXH/wAaox48/wCe fhT/AMCrj/41
W3YtdPZQPewww3TRqZo4ZTIiPj5lVyqlgDkAlVJHOB0qaldDOex48/55+FP/ AAKuP/jVGPHn
/PPwp/4FXH/xquhoougOex48/wCefhT/AMCrj/41Rjx5/wA8/Cn/AIFXH/xq uhoougOex48/
55+FP/Aq4/8AjVGPHn/PPwp/4FXH/wAaroaKLoDkde1LxpoujXeq3cXhgwWs RkdY7m4LNjsB
5fU9OcD1Iq8yePlYq0XhQEHBH2q4/wDjVQ/FT/knutf9e5/mKd8Xr3UrHw4z 6VqM2m3Vxq+m
2YuoY43eJJ7+CGQqJFZM7JGA3KQCc4oQD8ePP+efhT/wKuP/AI1Rjx5/zz8K f+BVx/8AGq47
XvHep+B9Sn8M3a3nim+P2NtPuZIGWWX7Qt45SZbSBydgsZiHih5Dxqyja8pu WfxLu7m/0G0m
8O/2L/aOxZpddlnsIzI07wiG2L2/76Y+W0ixSeRI0bxMF5cRu3kK50uPHn/P Pwp/4FXH/wAa
ox48/wCefhT/AMCrj/41XNQfEHxDcaT4d1W18I2dxb+KLiKPRUTVyJfKktJ7 lZLkNCFi2rEm
9UaUgM+3eVVZM2H4navAPEM0ehQ3um+HY7u+1O5udT2XAt47+/g2wRJb7JCE sWKq7p95FZyd
0hLeQXO3x48/55+FP/Aq4/8AjVGPHn/PPwp/4FXH/wAargv+Fia3ouitrfiS 383S4fEWtW8c
tjcIZ57a0XU5NkkLQqq7VtEVdsmXIVmcfMr7F/498TWWu2nheXwro58RXVxA qRLrcn2MQywX
squZvs2/fmwmBTysfMh3HJClgudLjx5/zz8Kf+BVx/8AGqMePP8Ann4U/wDA q4/+NVa8H63/
AMJBoS6g1t9lmS4uLS4iEm9Umt53glCNgFk3xttYhSVwSqklRr0hnPY8ef8A PPwp/wCBVx/8
aox48/55+FP/AAKuP/jVdDRRdAc9jx5/zz8Kf+BVx/8AGqMePP8Ann4U/wDA q4/+NV0NFF0B
z2PHn/PPwp/4FXH/AMaox48/55+FP/Aq4/8AjVdDRRdAc9jx5/zz8Kf+BVx/ 8aox48/55+FP
/Aq4/wDjVdDRRdAc9jx5/wA8/Cn/AIFXH/xqjHjz/nn4U/8AAq4/+NV0NFF0 Bz2PHn/PPwp/
4FXH/wAaox48/wCefhT/AMCrj/41XQ0UXQHPY8ef88/Cn/gVcf8AxqjHjz/n n4U/8Crj/wCN
V0NFF0Bz2PHn/PPwp/4FXH/xqjHjz/nn4U/8Crj/AONV0NFF0Bz2PHn/ADz8 Kf8AgVcf/GqM
ePP+efhT/wACrj/41XQ0UXQHPY8ef88/Cn/gVcf/ABqmSv47iUNJF4WAPIxc XJ4zjtF7V0lc
58Q9fHh/Tftn2S5vHMUccNvAhZpJGkZVXIB2gnAyfoMkgHpwtGNafKzKrPkj crHUPGIYBh4X
XJxzNdAfn5NdLpiaiuno2rfYxeGR1dbUsY1CnAALAEn8B6dsny7w3rviJdXO ieLdP8q9mjN1
bz2yloSnBaMkZClCwXJPPHJJBf1eBi1q5J/5fLkflKa6Mbg4UIKUepnQrOo2 mWHWBNoZZCSo
PDDuPpTc2/8Acl/77H+FFz99P+ua/wAhUVec2dJLm3/uS/8AfY/wozb/ANyX /vsf4Vxfxgu9
btPA0n/COav/AGPql1qOnWUF99mSf7P9ovYIWby3+VsLI3B/Mda4qf4t39tq jt/ZM1xPc2Vh
bxaSiyyi01HzdTF4jSQQSSuE+wMm5I3UmNSAqMzhq7Ee05t/7kv/AH2P8KM2 /wDcl/77H+Fe
US/GG3tLRptV8P3mmPHb2txJFdCWJwjS3ouXCPEHCRW+n3Fwu5VaVdq7Edgp 7vwjrf8Ab+lT
X32b7N5Wo31ls8zfn7NdS2+7OB97yt2O27GTjJTugNzNv/cl/wC+x/hRm3/u S/8AfY/wqKii
4yXNv/cl/wC+x/hRUVFFwOE+AH/JJdG/3rn/ANKZa6HTv+SuQf8AYBm/9KIq 574Af8kl0b/e
uf8A0plrodO/5K5B/wBgGb/0oir082/5GVf/ABy/9KZx4H/dKf8AhX5I1vEW hm8SZbia0ktJ
tRtLxYpYWyk8UkLRNuEqZAkijbHfGMNnB19LtJ7U3UlzcRzS3M3msY4jGowi IAAWbsnr3rjv
iF4+0nwkWfXvEWj6TC+o29paxXDBZZdzW4aQbpo8xxmdWkx91ASc9D0nh7Wo L+3eVtT066id
0NrcWzAR3ETxxOrp8zbgTKoBBIOV9a5DoKep+CtK1DR/GOlzXF6sPi7zPt7I 6ho99nFaHysr
gfu4VPzBvmJPTAGZqfw006/sda0qTxB4gi0XVor5W0uGeJIIJLwSefKrCPzH YtNM4SV5I1Z8
hBsj2UvEHjfWfDvjrX7e+hh1LRbKx0l7KysLPbfy3F/dyWkaGWW4WIqHhJ5V OJRz8h3zTfFP
TUvLXR08P61J4luLma2/sHzLNLtGihimk+d51gfEVxA+I5XbbJ0+STZQg8E/ D250vUP7Q1vX
r2/+z63qeqadpy+SLSze6uLllkUrEszP5Ny6sru6BpHwOEK+gV5zpnxKnh8H +IvEfiDQprW0
0fV7uyjuRd2dvBeJHqE1qhjae5UKyhE3+aYwzE7A2QK5/Sfifc+Jvif4dj8P apu8Oal9kV4N
kL/OYNd89fMXcGxLYQDcjsh8rKMVclgD2aivOfg/4v1nxLd3Cak8MtpcaRaa 9p7+XsmW3vru
/aCKTHy7o7eG2U4B+YP8z5DVS+H3xdXXdB0i81Tw7qcCzRaZBqGqQrALCG9v ba2ljiVDMbja
Wu4UB8sgF/mbaGYAHqdFeWQ/E2e98VWN9DpWp2fhV/C2p61FPdPZxx6mkT2R hmiZpt0S+XK5
xP5IAlG8Dadh4b+L1v4p8VaFY+GNJm1OxvIr5NRFvcWkslhNA9jtdpUuDC8Q jvNzeU0rZZQA
GV1AB6nRXn/w4+Lvg/x7rk2kaDc75ltmvLc/abaX7RbqyqZNkMrvDzJH8k6x P8+NuVcL6BQA
UUUUAFFFFABRRRQAUUUUAVNT/wBSf93/ANmWsqtXU/8AUn/d/wDZlrKrnqfE XHY4TwPqmtw+
FLSDT/C9xfwpNdfvxfW8QYm5lJwrPuwM45A5z2wTnz+FLa4Xw+lz8LGuI/Dt lLYaXHNrEDpF
bywiCSNlaUiUNGoU+YG49ya89+IV3N5/ws0i58aeJvCmgXI8T3Wr3Oh38lvL 5VqGnDHYG3bd
h42scFgOTWP8T7TRtCuZ9D8I/Gn4weI9aTw/e65JLb+KvOtLC3is5J4ZZ3SP lZXEKqoYZWUN
uG6MPap3V7icj1rSPC7aZq8esQ+AdZuNQikjkjub7xV9sdSkc8aAGa4bgLdX A29MyE4yAQf8
IrGLKC1i+G19brbWVrY20sHiFIpoIbYSiERypMHQhZ5lLKwZlkZWLA4q54N8 bavB4V+EOkNP
NNd+IPD9ve3t/Np9zqMkgjSzWRW8ogxtIbncbmUlEKfMrbwR1knxS8CQ2c97 d679isofLYXd
3aT29vPHJMkKzQyyIEmh3yxAzRlo1EiMzBWUl+z8w5jE0aTXNH02LTtO8A3E NvFkgHV7Z2Zm
YszuzSFndmLMzsSzMxYkkk1c/tfxT/0JFx/4NLX/AOLrvLC5jvbG3vIVmWKe JZUWaF4ZAGGQ
GRwGRueVYAg8EA1NS9kg5jz3+1/FP/QkXH/g0tf/AIuj+1/FP/QkXH/g0tf/ AIuvQqKPZIOY
89/tfxT/ANCRcf8Ag0tf/i6P7X8U/wDQkXH/AINLX/4uvQqKPZIOY89/tfxT /wBCRcf+DS1/
+Lo/tfxT/wBCRcf+DS1/+Lr0Kij2SDmPPf7X8U/9CRcf+DS1/wDi6P7X8U/9 CRcf+DS1/wDi
69Coo9kg5jy1ZfFA8VDW28H3IA017NYhqFqcs0sb5J8zgYRu3XHrxB4kstU8 QeQ2oeBdUjmt
9wiuLLxFHZzorY3IJYJkfYxVCUztJRCQSqkeqy/6yH/f/wDZTWHqvimy07xU mgzJM0v9kXGq
uI7W4kkaOJ40IiCRMsrfvPmRX8wEx4RhJkHsw5jzpfD8w1K21A/D/VJJoPKb bJ4lV4p5IlUR
zTRtOUnmUJHiWQNIDHGd2UUgfw9v03TdOb4aXH2fS9O/s2xA1yENbwboWARh LuDq1tAyyZ3q
0YZWB5r0XQfGXh3W76CwsLyb7dNFPKLS4s5reeMQmESCSOVFaJh9pgYK4Uss qsoKnNQ23jzw
zcf2K8V1em21u2gubC8bTblbSRJ/9SGuDH5UbuSoWN2VyzouMsoL9n5hzHAL 4fmGpW2oH4f6
pJNB5TbZPEqvFPJEqiOaaNpyk8yhI8SyBpAY4zuyikH/AAj3+ifZl+Glwqm3 +zu665Cskg83
zlkdxLueZZS0qzMTIsjyOrBncn2Wij2fmHMeb2N/4ls7KC0h8FXzRwRrGjTa 1byuQowCzvIW
c8csxJJ5JJqb+1/FP/QkXH/g0tf/AIuvQqKXskHMee/2v4p/6Ei4/wDBpa// ABdH9r+Kf+hI
uP8AwaWv/wAXXoVFHskHMee/2v4p/wChIuP/AAaWv/xdH9r+Kf8AoSLj/wAG lr/8XXoVFHsk
HMee/wBr+Kf+hIuP/Bpa/wDxdH9r+Kf+hIuP/Bpa/wDxdehUUeyQcx5R4tbx Zrnhu/0lPB00
L3MRRXOpWpCnryPMqx4uGqeJrC403UPAmoS2Ms0cy7NahtpQ0cqyxuHjlDow dEb5W4I616fW
Rrmrx6JotreSmELJd2doPNd1XM9xHAMFEc7syDAwATgMyKS6nsw5jzH/AIR+ b+xf7K/4V/qm
z7R9q+1f8JKv23ztuzzftXn+fv8AL/d7t+fL/d/c+WiHw/NFcWEq/D/VCthh oYH8Sq1u0gkM
nnSQmfy5ZvMYyebIrSF8OW3AEdL4W+K/h/WPA+h+JLmz1q0m1W2SZdPi0e9u LgExRvI0aJDv
lhQyov2hU8ollG7LAVtad498J6nealaaTq39qTabbC6ulsLeW52xNDHNGwMa sH8yOVWjC5Mm
HCbjG4V+z8w5jgNL8PzaZd21xZ/D/VF+yXAubOGTxKskFo4ilhAhiacxxII5 5FCIqqAV4+Vc
Y7eBZpPFN9q83gjVGs7u3SJ9Oj8QrHBI5ubq4mMyrcBJ0ke7bMcisoAYAbWK j0RPiboc3irQ
9FtLXU511WK63MNNuhPZzQvaqI57cxeZArLdq/mShFVdjZKyKa2fDfjLw74h vns9KvJpJREZ
oWls5oY7uEEAzW7yIq3EQ3J+8iLriSM5w65PZ+Ycx51P4e+0Xcs9x8NLidZb h7lraXXIXtfN
eKaKRhbmUxL5iXE28BQHLlm3Ng0aX4fm067tryL4f6pcXltcC5iur3xKt3Or iKWIAyTTs5QJ
PNhCSoMjsAGJNdzqPxH8H6dNqKXupzQxafFcST3LWFx9mYwIzzxxT7PLmlRY 5S0UbM48qQFc
o+LmveMvDuiX09hf3k326GKCU2lvZzXE8gmMwjEccSM0rH7NOxVAxVYmZgFG aPZ+YcxyOkSa
5pNo9rp/gG4hhe4nuWX+17ZsyzSvLI2TITy7ucdBnAwMCrn9r+Kf+hIuP/Bp a/8Axdbmk+Pf
Ceq65a6Hp+refqdzbC6S1FvKJEi3SozSKVzFskgkjcPtMcm1H2u6K13VfE+k aXrlpo+oPewT
XewRTtYT/ZNzsURGuQnko7MAqozhmZkABLqCvZIOY5b+1/FP/QkXH/g0tf8A 4uj+1/FP/QkX
H/g0tf8A4ur+j/FLwJq/9jf2Zrv2r+3N39l+XaTn7Zs8nzPL+T5tnnpvx9zb Lu2+TLsuyePP
DMOoT6fd3V7ZXMNzHbBLvTbm3895LhLdTCZIwJk82WJTJHuRfMQsQGUk9kg5 jD/tfxT/ANCR
cf8Ag0tf/i6P7X8U/wDQkXH/AINLX/4uupvfFOhWen+IdQub7ZbeHN/9rP5T n7Ptt0uG4Ay+
IpEb5c9cdQRWZ4s8f+HdA0zVp5r+EXGmyzWzxzJMsf2iOwN+Y2dI3IX7ON5Z VbjgBm+UnskH
MZP9r+Kf+hIuP/Bpa/8AxdH9r+Kf+hIuP/Bpa/8AxdZ1x8XYBNppXSNTji/4 Sm90PUFTSLy6
ZkgS/CSW5ji/fMz2aFhGJBGHYNgjdXT+JfHemaV4Gi8XWcU2pWL31paNHFFJ 5yma8jtnBiCG
TzY2dsw7N+5ChAboeyQcxk/2v4p/6Ei4/wDBpa//ABdH9r+Kf+hIuP8AwaWv /wAXW4vjzwyd
UttON1exzXHkrul025SKCSVVaKGeVowkEzB48QyskhMkY25dQaWhfFDwVrf2 A2Go3uy/8s28
lxpV1boVlx5Ls0sahElY7InYhZXDJGWZSAeyQcxQ/tfxT/0JFx/4NLX/AOLo /tfxT/0JFx/4
NLX/AOLq/pHxQ8FappZ1K21G9jtjbJdQG60q6tmvInZFRrZJY1a5y0kSgRBy WliXrIgae2+I
/g+e+03T11OaPUNSlkhtbGawuIrovGYt6NC6CSNlWeKQh1B8pvN/1YZweyQc xk/2v4p/6Ei4
/wDBpa//ABdH9r+Kf+hIuP8AwaWv/wAXWtqfxH8H6U1+NZ1ObSFsZVjmk1Kw uLSNg06QeZG8
qKssQkkjDSoWRBIhZgrAm5D4y8Oy2M959smiit7600+ZZrOaKSK4uhAYI2R0 DKzfaoM5Hyl8
NtKtg9kg5jnf7X8U/wDQkXH/AINLX/4uj+1/FP8A0JFx/wCDS1/+LrqdY8U6 FpH9s/2hfeT/
AGJpq6pqP7p28m1bzsScA7v+Peb5Vy3ydORmlrvjzwzoN5f22s3V7YfYbaS5 lmn025S3dI4T
M4imMflzOI1dzHGzPhH4+RsHskHMYf8Aa/in/oSLj/waWv8A8XR/a/in/oSL j/waWv8A8XWt
bePtDuWv57WSa9sLSxtrxXsbK6uZ5knnnhV0hjhJkiYwFkkjLhly+Am13xU+ K2hp4yu7G5mm
GirpFnexXsel3Trbu895FOLuQIVtVj+zKG87yyhWXcflYKeyQcxJ/a/in/oS Lj/waWv/AMXR
/a/in/oSLj/waWv/AMXTtE+JukLYTN4huPs9zHqWpQSfZbKeWK1tre/uLaOe 5dFdbdCsBJkl
ZEJSUggI230Cj2SDmPPf7X8U/wDQkXH/AINLX/4ur97bXd4lrctYXkcxt1WS KJoZNh5JUkyK
MgkjjIOAQa7OqH/LV/8Aeb+da0ZyoT5okTipqzOSOjXsrjfp+qbc8/Lb9P8A v/W8sLQWwR8b
2nmkYA5ALNuIz3xnGa3ErLvv/ar/ANK0xWJnWilIVKjGm3Yiufvp/wBc1/kK irDvvBGj6hdy
Xt1aahLNM25n+3XAB+gD4A7ADgDgVD/wrzw//wBA7UP/AAPuf/i64Wmblvxh pE2t6E1jbS2c
Nwtxb3MEl3BJNEksM6TIzJHJGzYaMEDeBnGdwyp5DSvho7+JNa1vxHd6Pd3G seRJcz6TaXmn
XQmgQxxSJN9skMWImkjPlhCwchiQSG6T/hXnh/8A6B2of+B9z/8AF0f8K88P /wDQO1D/AMD7
n/4ujUWhb0vwzommXFhcWVl5c1hbz20Ehldm2TyRyTFySTI7vEjs75Ytkk5Z smk+GdE0r+yP
sFl5P9jac2mWH7128m2bysx8k7v9RFy2T8vXk5qf8K88P/8AQO1D/wAD7n/4 uj/hXnh//oHa
h/4H3P8A8XRZhoW9J8M6JpX9kfYLLyf7G05tMsP3rt5Ns3lZj5J3f6iLlsn5 evJzr1zv/CvP
D/8A0DtQ/wDA+5/+Lo/4V54f/wCgdqH/AIH3P/xdFmM6Kiud/wCFeeH/APoH ah/4H3P/AMXR
SswMb4Af8kl0b/euf/SmWuh07/krkH/YBm/9KIq574Af8kl0b/euf/SmWuh0 7/krkH/YBm/9
KIq9TNv+RlX/AMcv/SmceB/3Sn/hX5I1vEWhm8SZbia0ktJtRtLxYpYWyk8U kLRNuEqZAkij
bHfGMNnB19LtJ7U3UlzcRzS3M3msY4jGowiIAAWbsnr3rm/FPi7SdEvJYde8 X+G/DsP2gJaj
U5xC0+xIpGKs0ybgDIoIA6EA9a1/D2tQX9u8ranp11E7obW4tmAjuInjidXT 5m3AmVQCCQcr
61yHQY2r/D2z1XxZfeILzXtab7Z/Zu6yX7OLeP7BdC6g2/uvM/1nmbsuciVx xhNkPin4ZaR4
iXWLW/1XUxpeuXy3mr6aEtngvCILeEIS8LSIoW1Qho3RwzMwYEJtu+KtW1/S vHPhO2t7nTG0
XWb6TT7i3ks3NyrrZ3VwJEmEoUL+4RdhjJ5Y7ugGL4P+MfhTxNMkFmsyS/bo LOfbdWl1FbGd
JTA8s1tPLEqyPC0Krv3+Y8YKgSIWoRp3Hw9sz5v2PXta0/bqT6pp3kfZ2/sy 6l877RJD5kTb
/N+0z7lm81V8z92EwuOfuPhEum2NzqfhvxFqbeKoYrifT77UGgMZvXGpsksq pCF2+Zqs7EKu
MJHheGDXfEvxj8KeHtG0vW9UWaDS9SluhDdSXVpEDDBJsNwiSTrJcROpEqeQ srOjIQuXUH0a
gDjH+HtnafYv+EX17WvCv2TTbfS/+Jd9nm821t9/2eNvtUU3+r8yXDLhjvO4 thduN4Z+FMOl
6vqMbavew+GhqVjdadoUDxtb7bO0s4oGld4jPvSW0VgFm2sETdnc6n0yigDz mL4RaQrWqP4i
8QS2mmWP2LRbV2thHpSLPbTxGIiEPI0b2duV89pQQmHD7mzd0X4b2+maz/by +KfEFzrT3z3N
xqEwtPMuI3jtY5LZkWBYxEy2VtkqiyAp8rjc2e5ooA5nwb4Oh8L+XDa65rV3 YWlsLPTbC5lj
+z2FuNoEaCNFMmFRFDzGVwFOGG+Qv01FFABRRRQAUUUUAFFFFABRRRQBU1P/ AFJ/3f8A2Zay
q1dT/wBSf93/ANmWsquep8RcdjwLxVoHi69f4Z+JvDPgRPGlrosniGHUtNlv IbaOVLpjCEYy
5DKQXyArA7cHGaxtD8O/EHwx8NPFfgrwh+zTJpKeJLa7guL2Txha3Eq+cjog JKgskSvhUJHA
JJLMzNU+Llj4Xv734TJ4002bU/D1tF4tvb+1hkZJJUt42nwpVkO7MYI+YAkY Jxmub8b+F/gT
rcWr2Xwl8Bf2xbaX4bvdY1fxAuo3v2fTf9ClktY1DygNM0ojLIwO0K6lSRJ5 W0b2RL3PqH4Z
eFLzS9D+H13qjSWt/oHhH+xrqy8rf+9kWyLnzFJHyNaFeMht+QeOcy2+FlwL bQrK88RrLaeG
orO00VYtKeORbWC8srkrcMZGE0rCwgTzEWJQWkbYcqq5XgHW9cg8K/BXw5pc epm0vvC0F7ev
pwtfMCwJYIBKbg4+zkXL7/KBmyE2EYbPTS/GDQLfToNTvNG8QQWN9FBc6VKL VJ21O2luLeAT
wxxO8gUNd27FJFSUiQbUZgyh6iPQvOT0k/79t/hR5yekn/ftv8KbYTSXNjb3 E1pNZyyxK728
xQyQkjJRijMpYdDtZhkcEjmpqNQI/OT0k/79t/hR5yekn/ftv8Kkoo1Aj85P ST/v23+FHnJ6
Sf8Aftv8Kkoo1Aj85PST/v23+FHnJ6Sf9+2/wqSijUCPzk9JP+/bf4UecnpJ /wB+2/wqSijU
CCWVS8XEnD/3G/un2rgviF4UvPF3iy2KtJZ2FrolzbPPJF5kdxLNdWcqwvEC DJCVsmSZGKB4
5wisdzlPQJf9ZD/v/wDsprl/E3jBdC8Vf2bdWswtI/D99rDSkQJHMLd4VZBN JOgjZRKCfMQI
RIp8xdjAiuM47Tvg5py+E9S0K/m0mNL7WxqZj0jRHsLSGJrWOzuIEgErY862 FwhfdlWuC6gM
qmrvjL4Yp4g8cQeI/tuknZqVhqHm32gtdX9t9llhfyLW681fs8L+Tkpsf5pp 2yd+BoeFfi74
P8QW8VzFc/Y7Y/a1nup7m2a1tpbeOKZ4nuIpXhZzDL5wCO42RTbipjdQXnxY 8PafrnhvSNWt
L3S7nxBbWs0EV7PaxXED3DbI4ZLUzfad+/CMUidFJOWAVypqI7zzk9JP+/bf 4UecnpJ/37b/
AAqSijUCPzk9JP8Av23+FHnJ6Sf9+2/wqSijUCPzk9JP+/bf4UecnpJ/37b/ AAqSijUCPzk9
JP8Av23+FHnJ6Sf9+2/wqSijUCPzk9JP+/bf4UecnpJ/37b/AAqSijUCPzk9 JP8Av23+FYXi
rR18Q6Baad9pktvJ1DT77eIGfP2W6huNmOPveVtznjdnBxg9DWF4p1n+wvD9 ne7tvm3+n2ef
I83/AI+LqGDG3emM+bjdk7fvbXxsY1uM8/v/AIRpdaH4e065uvDurf8ACNW0 mm6Sut+GGvbd
bFlgVfNiMy77ofZk/fqyKQ0g8obgRs2/w6trXwn4g8PW+qyCHVbm1nj3acqx qtva2luIJYow
iSQyC0xJGgiVo5XjAQYNYmm/HCxsfh14U1/xfo82mapr1ilzFave2FrHcKIY Xkniee6WMRbp
kCo8gmIOdmFYjptG+KGga1aa3faRZ6nc6do9it7NfyRpbW0iPaQ3UQSSd0Xc 8U4PzbQmxvMM
YaMuaiMHwL8LrjwlrK61pup6HaXbX07y22n+HHtbBbWeOySaKKBZyY5SbCNh KXZQXkzG2Ri7
8KfhjpngG+EtlFoaxW9j9gtZLHw6lpdzQ5T5ru4yzTy/u0yyeUpYuzISU8ut 4b+L1v4p8VaF
Y+GNJm1OxvIr5NRFvcWkslhNA9jtdpUuDC8QjvNzeU0rZZQAGV1Gn8OPi74P 8e65NpGg3O+Z
bZry3P2m2l+0W6sqmTZDK7w8yR/JOsT/AD425VwpqA/SvBNxZ+IrOeTWVl0X TdXvdasLRdOd
blbq6+0eb5s+8q8Q+2XG1ViRh+7y7bW34tx8HtDPg220GAWFw1nq51K2XVNK a9s2CwNaW8M1
uzgyLFaeVECHUl4UlbLFg29e/EvTraa6K+H/ABBdWiS3ltZXVtBFIuo3dqkz TWsEYk87zR9m
uFG+NEYxEBjuTdB4q+Lvg/w/by3Mtz9sth9kWC6gubZbW5luI5ZkiS4llSFX EMXnEO6DZLDt
LGRFJqBZ+Hvgm28Iahc3cE9tsuNNtrM21lpK2dvE0VxeTsY44+FQteFVU5YB AWeRmZqxvGXw
xTxB44g8R/bdJOzUrDUPNvtBa6v7b7LLC/kWt15q/Z4X8nJTY/zTTtk78DX8 F/FDQPGGrWun
aBZ6ndmexW9kuY40a2t0MtzCweZXKMyzWrx/IXD7laMvGHdLuq+PNO07UdYj l0zU5NL0KJ31
nV41i+zWBS3FyUdTIJ3bynjb91E4/eKM5DBTUCp4Q8Fp4f8A+EN/4mclz/wj PhuTQv8AjzZP
tO/7H+96nZj7J935v9Z1+XnjIfhKmif21qf2PSfEXmeG9Q0n7Db6W2n3+t+f 5TZvr/zW82Z/
I2mbYnzTSPxnFN+MPxQ1zTfDkqaTZ6n4W121ivJ57W/jtZpDD/ZOpz28oMbz RbTPZZxu3ZhI
ZdrDd0Evxx8AweJ9T0O61DyP7O+2LLcedBJl7RJHuF+zxyNcrsWGY7nhVG8v 5WbfHvNQOi0b
wpp0Hw8k8Haw0mqQ3ttPHq0vlPD9uluS7XUuFOY/MkllbapATfhcADHGar8G tO1HQzaT6tJ9
vn0S9sr69+xP/pN/cLcD7d5YfCbWv9RbyV+U/a8ZHlR7d3/hOvEB8ceHtEfw JrVpDqdtfSXE
VxLZG4gEMtkq3BKXLJ5IFzIGUFpSVXCY6w+Ffipp2q6To142n6nPaXUWnxXu rR20UNtbXd5F
A8MLxGdpgz/abf7glRfOUGT5XKmoFmw8E3FprOnyjWVfS9M8QXWuWlsdOcT7 7qO9E8cku/ay
+ZelkIjUqqBTvJ3iZvBaf8ITc+Hl1OQTNrc2t21ybNisc51JtQiV0zl0WQor AMpdQcFCQVk8
A/EKz8W/2djQda0X+1dN/tTS/wC0fs5+22o8rdIvkSybNvnw5WTY37wYBw23 s6NQPL2+F9tP
47XxZenw7dXtxc2t9fXUnhhZL0XMEUUYFrPI7/Z4T5CHYVkdd0pWRWZWQ0r4 XJY6Rp2n/wBu
ySfYtN8N2O/+z2G/+yLtrjfjdx5u7bjnZjOX6V6hRRqB4r4M+GXiG58CeFYf FmsW1vq2g6JZ
2umwWulsq2csUtnc7bk+c4ucS2MCkxmEFfNxgurJ1vhbwTcaZ41PjDU9ZW91 S4ivBfLb6c8E
EjzrYRq0as7tGqx6dGCrM5ZnZsqMKO9oo1A8VsPgolt4htNT/tfSU+yeQPtF v4eaK/v/ACtQ
srzzL6584/aZm+xbTJsTLTSPj+Guzu/DiX/xft/E1xp8kVtp2mxeVcbmP2q6 zconyg5TyIp7
kcgrJ9u55hXHb0Uagcr4w8Kad4k1zQNUumkR9JufMdfKc+fFujmWLII24ube zm3YJP2fZ913
B8/8Z/BRPEWr6hd/2vpMH2v+0T9uk8PNLqp+12lzb+XJeecPMhi+0/JHsGEh iTPy7j7VRRqB
5347+HyeJtcvtW/tC2/0m2sYPsGoaU13YzfZmvDi5h3p56H7ZuVMrskgifLY 21zOkfB3UtN0
jU9EtvE2kwaTremy6Zq1tbeHJItsEl3fTsLTFxtt8LfvGoZZQvlocEZWvaqK NQPHNS+CmmXm
pzX00uh30t3LdC5k1bwyl9JBDLf3V2v2QyNthlX7ZIpd1lVzHETGApVvX/OT 0k/79t/hUlFG
oEfnJ6Sf9+2/wqopzIx55Y9R71fqh/y1f/eb+dJjLqVl33/tV/6VqJWXff8A tV/6VM/hKW5H
cEhlwSPkX+QqLc3qfzqS5++n/XNf5Coqxe5Qu5vU/nXOeEfG+h+K/LbRP7Zk hltxcxXFxo15
bQSxHbhklmiVGyGBABJIyRwCa6Kvmz4aarot/wDDyw8BaTJNPrf2LTvttpP4 vs9Qh1FbV4nu
rS2hF7LtEsKzrs2RxMp2uVUcCVxXPcX8baLFqWo2N017btYajDp0krWztE00 q2hjAdAQNxvY
VAbaSd5A2ozDo9zep/OvneX4aapfapqFxafD2HR9BkvXul0WX7EoliSXQpGh 8uKRoszfYLsA
FgpON5QNmvZIrvVrDRbmHSPBnkQ2OjQzaZY/aoIfMn2yj7DhCyRbAkK7wSn7 zjIQ5bQXOk3N
6n86Nzep/OqUVxfNrVzayaf5djHbwyQ3nnKfOlZpRJHs6rsCRnceG83A+6au VIxdzep/Oiko
oA4T4Af8kl0b/euf/SmWuh07/krkH/YBm/8ASiKue+AH/JJdG/3rn/0plrod O/5K5B/2AZv/
AEoir1M2/wCRlX/xy/8ASmceB/3Sn/hX5I6O5t9Qs7m6uba9tEiuriNiktsW KsQkf3vMUEfK
DjGewycCrWl2k9qbqS5uI5pbmbzWMcRjUYREAALN2T171LqLbbdTu2/vohnd jrIox95fyzz0
w33TYrlsbnJ+JvAeneJ9Rmk8R6nqep6W8UqRaRI0UdtAZbd7aR0aKNZyzRSz L80rAeaxABCF
aEHw7tLu38QNqnizXtcudas4LFr2f7Iktn9mkmeJ4DBBGqSxyzO6uQzK6qRj bXTeJtT/ALKt
Irh7yysYN7m4ursfuoIkikkZ2O5QAAnJJwBk1yngL4haL4ojNxoviXRdStYb +5trxIXUyQBG
uMSkiZ9sbmBnjJwGjIIx0BcCfxf8MtI16xubGx1XU/Ddpe6Qui3sGkJbLHcW SCQRw7ZYZBGq
CaYKYthxIck7U29zXO+P9en0TwhdahpQtp9QkmhsLDzctALyedLaHzdpB8tZ pE37fmChsAkA
VzekfEi9fTtDs5fC2p634hu4r9LyDRzbxwpNp9wlrdOhuZ4/3RmceXyWKkFg DkUwPRqK8/0r
4raJql4JLDSNam0M3NlajXdkK2nm3kNvLbrsMouPn+12658nCs/zYCswp+Ff jd4J8S/2r/ZN
x5v2DTZtUj/06zP2m1ixuk4nP2f78fy3XkMN/IGyTYAemUV5z4V+MPhrxNfa Zp+i2Wp315fy
3ERjtfIuY7YwG2MhlnhleEKI7uKTcrsMZTPm7Ymhu/jT4Yg1jV9ESyvbvVtN uUtksbO8sZ5b
pmvIrP5QlwRDiWeEEXBhbDHAJRwoB6ZRXDJ8SLeaYabaeFvEF14hWWZLjQ4z aLc2wiSB3d5G
nFuVC3dqfklY/v14ysgSDRvi74P1b4hyeCLS5zfi5ns4n+02zebcQBzLH5Ky m4j2+VL88kSI
dnysd8e8A9AooooAKKKKACiiigAooooAqan/AKk/7v8A7MtZVaup/wCpP+7/ AOzLWVXPU+Iu
Ox89+N4dXsk+GPjDQ/FHgLQr/QbjXfJTxZqRtobnz5fLbYFwz7QTnkYLJ1zX NR6v4otPAWt+
CdF8XfsyaJo+tRXaXaafrU0bZuVZZHXLkBsNhcghQqqAFUKNX4gx2sniD4QP eeGYfFMUEXi+
5XR5YBMt88UTyJEEKtli6qB8rEHBAJrH8RX3g/4l+HvEWpfDH4U+GdM8G6H4 b1C61fW7rQba
C4kvG0+VorS3whKvFI8bu6nqgwwXb520dkS9z6P+F/hm3sfCvgO+e6W+u9F8 LJpUU9jOklpc
JIlqXlRurqTaoUYYBVjkHIxBa/C3R4ksIZtQ166ttK+zR6PBLJbhdNt4Lm3u Vt4ysYZ0LWls
paYyPtj4cFmZvPT4k1nS/gv8LtD0SSZbjVfC2mLtF59mjcNd6PashkWNpYmZ LyRRLGwMYZmC
s2wp7zoUE1rodhbXEflTQ20ccifbJLrawUAjzpAHl5/jcBm6kAk07CLPmP8A 88JPzX/GjzH/
AOeEn5r/AI1JRRYCPzH/AOeEn5r/AI0eY/8Azwk/Nf8AGpKKLAR+Y/8Azwk/ Nf8AGjzH/wCe
En5r/jUlFFgI/Mf/AJ4Sfmv+NHmP/wA8JPzX/GpKKLAR+Y//ADwk/Nf8aPMf /nhJ+a/41JRR
YCCV23xfuZB8/qvPyn3rj/GPg5/FPiy01C+MltZWGmyQ2r28im4F091a3CTA MCi+S9jCyht6
yF2DKFTEnZy/6yH/AH//AGU1xXjbxfdeHPGUFpLHCLGTw/e3tuXuyFuLqOe1 iSFo1t3k3M1x
GsZiZmYyOvlO3l0JDI4/htpcuk6hY61favrsuoavFqtzdXy2nmu6RQwGLEcS RiKSCHyXULl4
5ZVJw5qbXfANrqmuSagmr69YW1xqVnql7p1sbU295dWrQtFI5kjaVeLaBSsb opEY4yWLYeif
GOyktGvPEejzaHaWst7bahcSLcbYbiC0jvVjSKWCOdle1aaTc0SYMDKA2+Nm n1D4o3ml65oW
nap4a8v7Z9httVW2muLl9KvrpkRbd5I7c23ytLCSXnjYo4ZUbdGJCwj0jzH/ AOeEn5r/AI0e
Y/8Azwk/Nf8AGpKKLAR+Y/8Azwk/Nf8AGjzH/wCeEn5r/jUlFFgI/Mf/AJ4S fmv+NHmP/wA8
JPzX/GpKKLAR+Y//ADwk/Nf8aPMf/nhJ+a/41JRRYCPzH/54Sfmv+NHmP/zw k/Nf8akoosBH
5j/88JPzX/GsnXdIt9f0a2sLxbpIoruzvVaFkBL21xHcIOc/KXiUHjOCcEHk bVc3411eTRPD
VleRGYNJqml2h8p0VsT3sEByXRxtxIcjAJGQrIxDqW1GY1t8O4rGx0230nxF 4k0yXSYpLTTL
iH7G8lnYuIgbJRJC6vEPs8JDyK82U5kILA3f+EE0kaTq+nI+rhdSvrXUPOku hLNb3FtFbRwS
I8m4uym0hk/e+ZuYNv3KStYfwa1bW4PghbeL/EFje6hf3mmrrMkVlqE2o3F8 XtkkJjjkVBC7
tuC20X7pCQFPJxS8PeP/ABV4g8ceHbPT7fwzJbXFtqR1WzttZlk+zeTLp4y5 e0SVLqMXEgNs
6x/eG9lIABYRuaL8O4tM1n+3l8ReJLnWnvnubjUJvsfmXEbx2sclsyLCsYiZ bK2yVRZAU+Vx
ubOn4N8JJ4X8uG11XXruwtLYWem2FzND9nsLcbQI0EaqZMKiKHmMrgKcMN8h fz3xJ8X9Xnnm
0nQdMhju5r6yk0a+DXItNRtTqlnbSZmmtFQLIl0mHt/tChXZg3EZfoG+J+pJ 47XwufB17cfZ
rm1sdUuLKO8uFt7maKKQmN1tfIaFBPGWeWWFwodvL4QOWA3NO8D2Nl4ii1Rb zV5bS2vrjUbL
S5Hg+zWt3ceb506MEEzM32i4+V5GQec2FG1NkEfw80e10ODTtJfUdJmtNSk1 KyvrQW/nWsrq
8QVVdGjZEt5DbIrowSJUUYKIw53wv8W9V1Kz0i91PwpZWVtfW2k3kxt9Wad4 YNUm8iyKq0CB
381XEqkqEQKytKSUWlpXxs1LVtIGpWHgS98m++xNpE119streVbq7t7eMTzS WgRHxco4EBuV
Ijlw2ArOWA9C8N+GbfRNWudWW61e/vruxt7O4mvZ0kaQRS3EofjG1me6kyq4 RQEVFRVAqnqv
gex1HUdYklvNXj0vXYnTWdIjeD7Nfl7cWxd2KGdG8pI1/dSoP3anGSxbnLHx x4u1H4o6X4ah
0nTIJbWK/i160Oos0CmP+zJY5oJvs++VlhvsbGWIFmcFsIrH1OiwHmuufCbS 9ftLlfEOt+JN
VvrmJ4JL+V7SObyWtLu2WILFEke1Vv7lwdm7cw3MyqFGnL8PtNn/ALTsrq+1 6fQNR+2NLof2
mOO0D3fmfaG3RhZ23maZtrysitJlVUpHs7eiiwHH23g+6S+03U7rxT4kvtU0 +WQR30yWKyPb
SGJpbRlSBY/KdoImLBRKCPlkUEisvQ/hbo+j2+nWFnqGvf2TZ/YZJtOeS3MV 5cWUcMdvcSt5
fmh1FtbHbG6ITEMoQzhvRKKLAcr4c8HaboP/AAjP2M6i/wDwjmiPoln5skZ3 wN9my0mAMv8A
6LHyMDluORjpvMf/AJ4Sfmv+NSUUWAj8x/8AnhJ+a/40eY//ADwk/Nf8akoo sBH5j/8APCT8
1/xo8x/+eEn5r/jUlFFgI/Mf/nhJ+a/40eY//PCT81/xqSiiwEfmP/zwk/Nf 8aPMf/nhJ+a/
41JRRYCPzH/54Sfmv+NHmP8A88JPzX/GpKKLAR+Y/wDzwk/Nf8aPMf8A54Sf mv8AjUlFFgI/
Mf8A54Sfmv8AjVRTmRjgj5jwfrV+qH/LV/8Aeb+dJjLqVl33/tV/6VqJWXff +1X/AKVM/hKW
5zGqa5ryX0kdp4PvLmCPCJN9tt08zAxuAL5APbPOOoHSq39u+Jv+hHvP/Bhb f/F11rrAm0Ms
hJUHhh3H0pubf+5L/wB9j/CsWijlP7d8Tf8AQj3n/gwtv/i6P7d8Tf8AQj3n /gwtv/i66vNv
/cl/77H+FGbf+5L/AN9j/CiwHKf274m/6Ee8/wDBhbf/ABdH9u+Jv+hHvP8A wYW3/wAXXV5t
/wC5L/32P8KM2/8Acl/77H+FFgOU/t3xN/0I95/4MLb/AOLo/t3xN/0I95/4 MLb/AOLrq82/
9yX/AL7H+FGbf+5L/wB9j/CiwHKf274m/wChHvP/AAYW3/xdFdXm3/uS/wDf Y/woosB5/wDA
D/kkujf71z/6Uy10Onf8lcg/7AM3/pRFXPfAD/kkujf71z/6Uy10Onf8lcg/ 7AM3/pRFXp5t
/wAjKv8A45f+lM48D/ulP/CvyR2Wottt1O7b++iGd2OsijH3l/LPPTDfdNiq +ottt1O7b++i
Gd2OsijH3l/LPPTDfdNiuY3KWqWk90bWS2uI4ZbabzVMkRkU5R0IIDL2f17V keHdDNmkK281
pHaQ6jd3jRRQtl55ZJmlbcZXwDJLI2O2cYXGB0lULW9tIoZBPeQoyyyk75hk APIe7HjCN342
nhcFQrAZ3jTwdoHjFdKh8R2EOo2mm3xvUtLiFJYJn8iWECRHUhlAmZh0IZVO eMHjF+ENvpXj
WDVfBerTeENOaK+e5h0m3tEKzTrp6KkUUlu8axFbEu3G7ewIOGIHY+MNen0+ PS7HSBbSalrV
+2nWUs2WgglWGaZ5JApDMES3l+QEFnCoWjDF15u71/xR4a8VWcHifWNM1G0X w/rGqXC2Fith
GwtnsBHk3E7hWAln+ZpUTDjdjbupgQ+GfhTDper6jG2r3sPhoalY3WnaFA8b W+2ztLOKBpXe
Iz70ltFYBZtrBE3Z3Op07T4aadBo39it4g8QTadaxQRaRbPPEI9JEEkcsBiC xjzWjeGEq1x5
xxHgkh5Q+ZpXxp8Mazb6fHoVle6vq19c3FtFpVneWLyloI45JdsxuBbSbUmh YiOZ2w54zHKE
uXfxT01U1e40/wAP61q1lpepJpD3VnJZ7Zb9rmK2+zKjzrIjiSYZMqou1SwY qyFgC74U+Htn
oPiebxNNr2taxq0/2nzri++zrv8APSyRsrDFGo2rYQAYA6vnJIxmQfCLSI7v S2k8ReIJ7HRo
oYNJsJGthDYwxXdpcpEjLCJHUNYwJmR3YqG+bcd1Ta38VdH0Xw3Nq+qaXe2M 1rqS6ZeWF5fa
fay207QidQ0k1ykD5iaNwI5XOHHGVcLzOp/FbV9R0vWr/wAN6Re3em2ut6HH pmo2qQKt7bXb
aZI1vtnlDiaRLyQBmREVSuXVwTQB2eofD2zm1+98Q6Zr2taLrF5cvM95Z/Z3 ZEeC1hkhVZop
E2MLK3YkqXDIcMFYqbujeDodJ1yS+tNc1oWBuZ7yLSPNjW0iuJ2d5ZMqglk3 PLK2ySR0DPlV
GyPZD/wk+p6v4N8RXPhzRZofE+lxTQJpOpGPcl6IFmhikaOQxlXWSFsrJgCT BZWDBcUfFLTm
sdd8T23k3vhPTrHTXhuhLFaSSXFyPNZC13JFGqiCexcbivMrLlnBRQD0aivL J/jToF94d1S/
0C21O5Nl4fm1qS7jtEuLa2SP7Wjb2WZUlZZrN02pJiTcrRu0YeRIfix8XdN0 CLxb4Ysbn7D4
lstEvbnTpvtNnNuuI7J7lf3CyvMmFUtmaJUOzGTuQOAes0V5Z4m+KC6bqujJ qdnqfhZbW+ef
W7W/jgmkOn/2bqM6Sg27zLtMlkxwreZmEgrtYbjSvjp4N1OxdrNJptRN9b2M Gmw39hNJcTTi
QxKs0dy1srMIJ8K8ytmPG3LxBwD1OiobCaS5sbe4mtJrOWWJXe3mKGSEkZKM UZlLDodrMMjg
kc1NQAUUUUAVNT/1J/3f/ZlrKrV1P/Un/d/9mWsquep8Rcdj5v8AilcaNpOk fDfxLffFFPh/
qul3Guf2ZcHQpNT8/wA2YJL8qgqu1SB8wOd+RgiuM1H4haZf+HdR8PXH7V9q NL1KK4ivLeL4
bmJZRPuMxJSMEM5dyWBBJYnOTmu88TTazbeNPg1ceHLSG81qKLxg+nW8xxHN cCBzEjEsuFL7
QfmXg9R1pfEni34j/FjwX4r8TNpF74I8EaD4b1WO50+8B+1atqP2GeGWNvuk QwSM4BI5eMZU
tkQbR2RL3PYvAvg/wzqXw88CSkR65DpWiWMemahumt/OiQ2k6S+XkFd0lpby bWyRt2ngsD6B
mf8A55x/99n/AAr5x1G/1E/B/wCFHh2xlhiXVfC2lxyNOJZIWBv9EgaOWBZE SaJ0uZFdW5Kl
lDKruG7O28X+MNJ8Wp4c07w3ph8OaDfadoV5PBBb2dsXmhtjviaS8DQKv2pA lusExbYqCTMn
7t2Eet5n/wCecf8A32f8KMz/APPOP/vs/wCFfPvgz4h6/wCDvhb4YudRsIbX RbPwbbz6ZDJZ
PK2tvBpH2qRUu45Stoy+Wy7JoSWEbMjPkiP034X+IPGGp32q6X4z0mGwu7OK 3uIWC28EkiSm
VcG3iu7oqoMJxI0gDlmUKPLJYsB2uZ/+ecf/AH2f8KMz/wDPOP8A77P+FSUU WAjzP/zzj/77
P+FGZ/8AnnH/AN9n/CpKKLAR5n/55x/99n/CjM//ADzj/wC+z/hUlFFgI8z/ APPOP/vs/wCF
GZ/+ecf/AH2f8KkoosBBKZt8WUj+/wAfOf7p9q5zxD4Pt/EPiSPVNYEc9tb6 bLY29sjNGyNL
NDM83mg7g6tbW5jZNjRsrNuYldnTS/6yH/f/APZTXnvxF8Uaj4c8dWKLPD9n u/D94LGIQSyS
G/N3YwQqU89IpFke6iUBwhQhv3yK7kCQzc0zwL4f0/S7jTorG5nhutSg1Sdr zVbq6lkuoGha
KRpZWZztNvDhd23CAYwSCaz4F8P6vrkesXtjci5W5gu3SDVbqC3mngZGillg jZYpXUxx4Z1Y
4jQZwqgcVpHxP8UWNpc3Xizw1MsWl31xpd/FZ2i/apLo2lvd2myJLiaNFkWR 7cL50jPNJbAb
TIyJNqvj7xlpWuaTbzadZajbWtzpmkeJXsrQLb22o3TQK3lzy3Ky7FF1BIqi 2kyCFMiksYyw
j1XM/wDzzj/77P8AhRmf/nnH/wB9n/CpKKLAR5n/AOecf/fZ/wAKMz/884/+ +z/hUlFFgI8z
/wDPOP8A77P+FGZ/+ecf/fZ/wqSiiwEeZ/8AnnH/AN9n/CjM/wDzzj/77P8A hUlFFgI8z/8A
POP/AL7P+FGZ/wDnnH/32f8ACpKKLAR5n/55x/8AfZ/wrP1HTLbWNMt7TULS OeCOe2ukUzMu
JYJUmib5cdJI0bHQ4wcgkVqVyvxC1GbS/ClhcwLud9Y0i2I82SP5ZtQtom5j ZT91zwTtbowZ
SyktqM07DQ7Kw8K2/hixtmtdLtrFbCCOG8lSSKFU8tQsoPmKwUDDhtwIznPN Zln4F8P2n2J7
exuUubO5Nyl5/at0buVzs3Ca4LebOhEUQMcrMhWKJSCI0C8V8Kb268GfszDx pfQaZqN2fD//
AAkM4s7U2kl4/wBiSVjcSF5DLcOVO+cgFiQdnHOLqHijx/P4g8OW2veF4Zda 03V2vNPtBLbW
Ul6ZNI1cJEY0u7rylLw4EzuAxdgEHlMWLCPQovhh4RiuJJl0q5bNs1rDE+sX bRWcTSRSBbWM
uUtdrwQshhCGMxJs27Ri6vgXw+NUttRNjcyTW/kttl1W6eKeSJVWKaeJmKTz KEjxNKryAxxn
dlFI89f4j+PZ5rTw9o1nDq3iMy3jagsfh/7O2ni3SzLQPBcahGsjH7bG3nx3 DoRt2K4bzF7P
W/E/iib4daF4h0DRYWu9Sit570wldTj02F4TJJKqRSRm8VSAgEL7mD70V8BG LAX7XwH4ZtbO
3tINGjSG2ttNtYV+2THbFp8xms1yTk+XIxbJ5bo24cVDafDrwrbNmPSGZUlg kt45dSuJI7QQ
zxzxx26MxW3iEkMJ8qIIhEUYKlUUDifB/jHW5LLxn4oHiay1PSZbmwg0iNNJ m3S3l1p2m/Zz
EslyojhkluB+4bZhpSzzKNxEPhDxZ498RfFHSdIvmh0O70qLU4NWtri0zHeI v9kTKywxXciQ
yhLsqrmWYAbjtG8opYD0ifwdokustrX9ntDqL3wvnube/nhkeQRwxFWKEZiZ LeANCf3bmJSy
kjNdBmf/AJ5x/wDfZ/wrwrSvir8Rb/QrDU5dB0zSovEMWn3Gjy3sUTLAlzfW cBHlxXrS3ShL
wMZNtsFKJuUGUKl2/wDip4u0yzPm6fpmqXd7Ld2Onx2ls0TR3Frq1tpbuwkn 2yrLJciZY98W
wJ5bSNu85SwHtGZ/+ecf/fZ/wozP/wA84/8Avs/4V5JoXjD4l614isvCzp4f 0DVFi1CW8lvd
PF0ziD+z2jHkW9+wt2IvjlWmkJCI+FEgUXPgV4k1/wAY3niDxNcXkMWi3ktl Pb6XIjyzWjza
Tp05VJy4Xyh5r/IIgSzM+4ZK0WA9PzP/AM84/wDvs/4UZn/55x/99n/CpKKL AR5n/wCecf8A
32f8KMz/APPOP/vs/wCFSUUWAjzP/wA84/8Avs/4UZn/AOecf/fZ/wAKkoos BHmf/nnH/wB9
n/CjM/8Azzj/AO+z/hUlFFgI8z/884/++z/hRmf/AJ5x/wDfZ/wqSiiwEeZ/ +ecf/fZ/wozP
/wA84/8Avs/4VJRRYCPM/wDzzj/77P8AhRmf/nnH/wB9n/CpKKLAR5n/AOec f/fZ/wAKMz/8
84/++z/hUlFFgI8z/wDPOP8A77P+FVFz5jZAB3HOPrV+qH/LV/8Aeb+dJjLq Vl33/tV/6VqJ
WXff+1X/AKVM/hKW5Fc/fT/rmv8AIVFUtz99P+ua/wAhUVYvco8h+KHivW9K 8d6lYadr2sWs
1vo1hNpGn2+mJNZ3t/PcXUUcV1MYGMKSPHbxgmWH7zYYHLDev/iPPD8Q5fDF n4Y1K+tbW9gs
by7gtrpzHLMkbhhsgaDy1WeNnaSeNgBIQhwnmaPinwxrOoa1e32kX3hyCHUd Oi0+/h1TRpr7
7REjTEIcXUabMTyDbsJO45JGApongTT4fsN5rTf2hqlv5bSyQT3UVrcyRYEM 0tvJPIssyKkX
72UySZiRtw2rtegjnPDXxU1PUbTSbzUfC9nZ297b6XdzG31Vp3ih1OXyLMqG gQO/mh/NUlQi
hWVpSSgmj+KV0mkWutX3h2GHTdQ0r+3bKSLUDI66Yklv9omuEMQ8uSOG5SXy ozLvKOobO0t1
Nr4H8LW1pb2sGl7Ibe30+2iX7RKdsVhKZbRclsnY5JyeW6NuHFTeHvCOgaBe vd6XaTRyGMwx
LLdzTJaxEgmK3SRmW3jO1P3cQVcIgxhFwroNTkPEfxTnsb37HpXhubUpJr28 htJB9qdJorMw
xXEhW2tp5UK3ErRAGPaREzbwGQN6Bol9/ami2Op/Y7yx+128c/2a8i8ueHeo bZImTtcZwRng
gisi48EeHJtF0rSEtry0t9It1tbB7LUbi1nhhCqvlCaJ1kKEImVLEMUQnJUE btja2tjZQWVl
bQ2trbxrFDDCgRIkUYVVUcAAAAAcACh2AmooopDOE+AH/JJdG/3rn/0plrod O/5K5B/2AZv/
AEoirnvgB/ySXRv965/9KZa6HTv+SuQf9gGb/wBKIq9TNv8AkZV/8cv/AEpn Hgf90p/4V+SO
y1Fttup3bf30Qzux1kUY+8v5Z56Yb7psVX1Fttup3bf30Qzux1kUY+8v5Z56 Yb7psVzG4VX0
5t1ux3bv30ozuz0kYY+835Z46YX7osVQtb20ihkE95CjLLKTvmGQA8h7seMI 3fjaeFwVCAj8
SaJa65YpBPJNbzwSiezvLchZ7SYAhZY2IIDYZlIIKsrMjqyMynmb34b2+ptb z674p8QavfWk
UqWl3cC0jkty09pcI6rDAiFo5rKF13KwJLBw6kKNfxhr0+nx6XY6QLaTUtav 206ylmy0EEqw
zTPJIFIZgiW8vyAgs4VC0YYuudN4h13w79l0rWIP+Et1+9864t7bQLBLHFrF 5SyOwurop8ry
xg/vAx81cIQrMGBmXvwmsdS0nUtJ1rxX4g1ax1m++2azDdQ2BXUSIreJUfbb Dy1VLZNrQ+W4
JLBtwUrD44+Fj67e3OtweIL19flubJba+uI7ZG06zi1GC8kihMcH7zHkgoJx LhlHIDyFoPEv
xQW/07Tp/BVnqd7Yz6vokFxrMccC20CXdxaOYnSZ1mLPbXMfKRMF85fmVlbZ p/Dj4u+D/Huu
TaRoNzvmW2a8tz9ptpftFurKpk2Qyu8PMkfyTrE/z425VwoBOnw3t4ZhqVp4 p8QWviFpZnuN
cjFo1zciVIEdHjaA24UraWo+SJT+4XnLSF4NI+FOiaTpdrpNjq+tR6bB/Zkj 2peFlnuLBrXy
bh2MW8OUs4I2VWVCoJCBzvrA8PfEzVH1bWL/AMQ6pDZ6FpV9q6XEcXgzUiqW 9nLcIHOoCRrc
tthDnCcnMYAbFb938UrOxvLfS9S8KeJrTW7m5it4dK8m3nuH82G5khk3QzPE Ec2c6ZLjYV3S
bI/3lAHW6NolrpWo63fW8kzS6zfLe3AkIKq628NuAmAMLsgQ85OS3OMAc/H8 ONEtdDg07Sbm
90ma01KTUrK+tFh861ldXiCqrxtGyJbyG2RXRgkSoowURhmT/F3SLdr57jw7 4gitLOW/Ml0V
tjG1tYzmC9uwBMX8qF9gKlRKwkUxxvhttL4lfGPSPDFz4l0C3WEeIdN0i6vL FZrq2ljnmis2
ugjQxTm4RdiMS0kcakLgNlk3AGnp3wp0S10DxHpEur61ef8ACR6bNp+oXM7w iVllnvZ3kXZE
qK5e/m/h2gBBt4OYfEnwi0jXVuLO58ReIINHmlv510uFrYQQzXsFxFcSq7Qm bcftc7gNIVDP
wu0BQD4kXtn4q1S317wtqek6Lp3h+HWL24mNu8mnAvfCQziKd96slqhQQLIc lt2MgClo3xz8
KausUWnWGp32oS30dlHY2EtpfSF5ILiWImS2nkhVW+yzL80gKEBpAkZ8ygDT vfhTomru03if
V9a8RXMmY557x4Ymmt/s13bC3YW8UShAt9csGUB9zjLkKqi7eeBbu90O90y9 8d+Jrt77Edzc
XEVhJ5luFdTbmBrY2+xvMYs3lb2+UM5VVUdnRQBS0LS7DQ9DsNE0uD7PYafb R2trFvZvLijU
Ki5YknCgDJJPrV2iigAooooAqan/AKk/7v8A7MtZVaup/wCpP+7/AOzLWVXP U+IuOx83/FIe
Gv7I+G/9qP8AEoa99o1z+xR4ISM3f+uHn7tx3/cxjZ/DvzxXJa8LH+w7/wDt 2T9rv+yfs0n2
77ai/Z/I2nzPM3nbs253buMZzxXbeJodZufGnwat/Dl3DZ61LF4wTTriYZjh uDA4idgVbKh9
pPytwOh6UviTS/it478F+K/HnxPg/wCEVsvDnhvVbfS/Dlo+Vubw2M8FxeSk k5Q7pREMn5SC
p25efaK0RL3Pb/hto/hzUPhp4LuLGwju7C30Sy/suTU7SN7qOAJBLHuI4D7o YHO3jfGpH3VI
6C48OaNc+IrbxHcaPpE2tWsRht9RksUa5hQ7gUSU/Mq/O/AOPmb1NeFW+sav pvgH4O22j6h/
Zk194RsLY3kVrBJcQrLfaFbv5bSxuFzHPJxgqTtJBKLjT8X+NfEmg3N9otz4 xmeDSdXlsw9t
Lp8fiHVSbOynjS2gmh+z3DB7uRWjRI3IEG0s+5ZXYR65pHhHw5o+qHVNI8O6 Dp9+1slobq10
2OKUwIqKkW9cHYqxxgLnACKAOBU3hvw5o3hqxex8OaPpGjWkkpmeCwsUt42c gAuVTALYVRnr
gD0rx2z1yfwz4P8AFFrF4vms9Ul8U36yRXV3Z2kHh9JdQvJ4pppHtpWgiuI1 G15klDtLEI9g
cMMzRPH3jXWPCnibxQvi/b/wi3huTUYYNPW1uLLU5YL3VYg8spgDyJIljDlo fIB3MyLHuAUs
B9EYn/56R/8AfB/xoxP/AM9I/wDvg/414vrnjXXIdK8UXdp4xhTxNa30tq3h 2aW1hj0uxGpJ
bjUGBheeJRalbgzS+ZEBJ5nlsm1KpaP411yWx06HxP8AErTNH0KWW9KeKbC7 tZY53jFp5Nub
ue0jtZWYzXh/cwg4tgu7dFPksB7R/atj/bn9hf2vp39rfZvtf2HzF+0eRu2e b5e7ds3fLuxj
PGc1dxP/AM9I/wDvg/415V8AX13VtS8U+Jddub2wvby5sWvtF+zpHbwXT6Np jyNh0M6upJTa
0hUAcru+avWaLAR4n/56R/8AfB/xoxP/AM9I/wDvg/41JRRYCPE//PSP/vg/ 40Yn/wCekf8A
3wf8akoosBBKJt8WXj+/x8h/un3rJ1LwxY6nrj6pqix32dNl0xbW4iVrcQTM rTgp/H5nlwhg
5YYiUKF3Pv2Zf9ZD/v8A/sprzD4r61e+H/HVpfQ3U3lTeFtSRNsVuosZBd6f GLrz3hdool+0
b5mbfGqQBzGxTDCQzttI8I+HNH0s6XpHh3QdPsGuUuza2umxxRGdGRkl2Lgb 1aOMhsZBRSDw
KNV8I+HNW1y013VPDug3+rWez7LfXOmxyXEGxi6bJGyy7WJYYIwSSOa8j8I/ EbxgNBu9bN9p
ni600vV5tD22GpW80d7NcW1rLZyG7SCJGb7TKLTCQoqi5DPnyGdpvFPjfxN4 b8ceHtEl8V2U
1za3Ok6Tf2uoXVtaSay9xLDHNe29kLdpXTE7YZLiNFkhkGxhGwkLCPb8T/8A PSP/AL4P+NGJ
/wDnpH/3wf8AGpKKLAR4n/56R/8AfB/xoxP/AM9I/wDvg/41JRRYCPE//PSP /vg/40Yn/wCe
kf8A3wf8akoosBHif/npH/3wf8aMT/8APSP/AL4P+NSUUWAjxP8A89I/++D/ AI0Yn/56R/8A
fB/xqSiiwEeJ/wDnpH/3wf8AGqslnFe2UMN3Da3EStFMqTQBwHjZXjbBP3ld VYHqCoI5FXq5
X4japf6N4Ee/0+f7K4ms4p7vYrfY7aS4ijuLn5gUXyoXkl3OCi7NzgqCCW1G bOkCxgtzpekS
adFDpmy0NraooW0xGjJFsU4TEbRkLgfKykDBFZll4G8I2WktpFn4U8N22nNL JM1pFpUSQl5I
jC7lANu5omaMnGSrFTwcV5J4T8Tajoc/ivxL4d1//hPdJfxI1i7/AGm0X7bd TaZpy2b+fDGI
xi4VbTCIFH2nzHOIWJ2bbVPGuk3mqXmoeNr3VH0XxJougPatYWsVpdrcw6ak 87KsXmq5e8mk
ULKFVggwVBUlhHoVx4G8I3Ph228OXHhTw3NotrKZrfTpNKia2hc7iXSIjarf O/IGfmb1NXfE
nhzRvEtilj4j0fSNZtI5RMkF/YpcRq4BAcK+QGwzDPXBPrXgknxN8VX/AIjk 0rTvFkNvFq8t
tIsCXtndanoQfVtPtjBLALRFtpRFeSo0cxuSHjwHyjF9O+8WeJlm0mzv9X/t WG/1trcreWVs
wh/s/wASWGnpIgWNRvljlaRyc7ZQrReSAFosB7Rf+HNGv764vr7R9Iuru5sW 06eeaxR5JbVj
lrdmPLREkkoflJPSqVh4G8I2Fjb2Nj4U8N2tpbXy6jBBDpUSRxXSjC3CqBhZ QAAHHzADrWH8
FNefxBoZvr/xh/a2uSW1tLq+jbrYf2FcurGS28uNFljw+9Ns7O48rBOQxPDf DvW9c8I/B7wf
fafqs3ilbKxj0bU9GmltYZLDUZLeBLa0Z0jDRMlwqWxjkBdTe+ZK22KiwHrl p4R8OWdxfXFp
4d0G3m1C5ju72SLTY1a5njk82OWQjl3WQlwxyQ3IOeaml8OaNLDJDLo+kSRS xXMMiNYoVdLl
w9whHdZXAZx0cjLZNeR2XirxBpvjO90K8+JP9r+IdN1vSdLTQfIsov7Qtpba wN3eeQsf2gY8
+7nykmxPL5BRGBu/Abxd4y8R64w8Ra3ot352mm5v9MtrwXFxpF3ujxbuiWkX 2TG6ZTDcSzSk
xgKx8uViWA9P0fw5o2jQ2kOj6PpGnRWcUsNqlrYpEsCSuryIgXG1XdVZgMAl QTkgUWHhzRrC
+t76x0fSLW7trFdOgnhsUSSK1U5W3VhysQIBCD5QR0rxCXXNc8M+GtWtdJ8X w2d3L4y1BdUi
1G7tbSPw/ay3WoTwzGRraUwLcFYNr3CSq4lUR7N6sNPTPG/iZtY8HWur+K7K 5F95apaeHbq2
kvb/AHXksYuZYbm3RprLyI0Zri1EX/LaREMRVoiwHt+J/wDnpH/3wf8AGjE/ /PSP/vg/415h
8DL5dD+AWnzNqWp+JLvRdIiS906GOCS7sriG1jMmnLFEqESoRtEcuZNzYZjx jhvCfjjxfr/i
uy8HxfESyuoZtStfM1fQ9QsdUlVJbLVJWgMv2KKFcNYwtt8kuA7fOQwCFgPo K/uo7CxuL6+v
bW1tLaJpp55vkjiRRlnZi2FUAEkngAVNif8A56R/98H/ABr5q+JvjLUdQ+HP jLS/E3jf+wIb
XRNVtNOYi0hbxDPDdajaPE/mxkO/l21qWW2EZDXJOAHjC+s/FPXn0vXNFsb/ AMYf8IXod1bX
ctxrO62j/wBJjaAQ23mXSPEN6SXD7du9vIypAVwSwHeYn/56R/8AfB/xoxP/ AM9I/wDvg/41
4V4k+JXiKz+JlxY6Z4j8P2cU8t/ZrpWvapCrWJt7K4lW7mto7dJobdpLZX81 riQNDMGCKXXy
4fCWtS6x448IazqHjXWoLaH+09OGq3M2mSWmp3Dy6YyWdtcRQLFPDKUm2lVj uC0Mo+QoyKWA
97xP/wA9I/8Avg/40Yn/AOekf/fB/wAakoosBHif/npH/wB8H/GjE/8Az0j/ AO+D/jUlFFgI
8T/89I/++D/jRif/AJ6R/wDfB/xqSiiwEeJ/+ekf/fB/xoxP/wA9I/8Avg/4 1JRRYCPE/wDz
0j/74P8AjRif/npH/wB8H/GpKKLAR4n/AOekf/fB/wAaqLnzGyQTuOcfWr9Y WqaibS4MSRqW
ILkspI5Zh2I9KqFKVSVoiclFXZtpWXff+1X/AKVkS+Jb2IgiO3YZ5Gxhkf8A fVaLzC4iaQAj
FxMn/fL7f6VWJw86UU5BTqRm9Dn77wRo+oXcl7dWmoSzTNuZ/t1wAfoA+AOw A4A4FQ/8K88P
/wDQO1D/AMD7n/4uuouCQy4JHyL/ACFRbm9T+dcTsbHOf8K88P8A/QO1D/wP uf8A4uj/AIV5
4f8A+gdqH/gfc/8AxdXNB8TaXrepavp2nyXrXGj3Atr0TWM8CpKV3BVaRFWT 5SrZQsNro3Rl
J19zep/OjQDnP+FeeH/+gdqH/gfc/wDxdH/CvPD/AP0DtQ/8D7n/AOLro9ze p/Oqd/qtnYXe
n2t3cGObUbg21ou1j5koiklK5AwPkikOTgfLjqQCaAZH/CvPD/8A0DtQ/wDA +5/+Lo/4V54f
/wCgdqH/AIH3P/xddHub1P50bm9T+dGgHOf8K88P/wDQO1D/AMD7n/4uiuj3 N6n86KNAOD+A
H/JJdG/3rn/0plrodO/5K5B/2AZv/SiKue+AH/JJdG/3rn/0plrodO/5K5B/ 2AZv/SiKvTzb
/kZV/wDHL/0pnHgf90p/4V+SOy1Fttup3bf30Qzux1kUY+8v5Z56Yb7psVX1 Fttup3bf30Qz
ux1kUY+8v5Z56Yb7psVzG4VX05t1ux3bv30ozuz0kYY+835Z46YX7osVQtb2 0ihkE95CjLLK
TvmGQA8h7seMI3fjaeFwVCAj8SaJa65YpBPJNbzwSiezvLchZ7SYAhZY2IID YZlIIKsrMjqy
Mynn5vAt3N9lupPHfiZtYtPOjg1byrD7QlvN5Rkt9n2byShaCJ9xj3grgOFJ U6PjDXp9Pj0u
x0gW0mpa1ftp1lLNloIJVhmmeSQKQzBEt5fkBBZwqFowxdc6bxDrvh37LpWs Qf8ACW6/e+dc
W9toFglji1i8pZHYXV0U+V5Ywf3gY+auEIVmDApf8Kp0S3+yWukavrWkaPb3 On3Umk2zwvb3
Etl5AgZ3mieYYW1t0ISRQRGD95mZtrwb4Oh8L+XDa65rV3YWlsLPTbC5lj+z 2FuNoEaCNFMm
FRFDzGVwFOGG+QvyXiX4oLf6dp0/gqz1O9sZ9X0SC41mOOBbaBLu4tHMTpM6 zFntrmPlImC+
cvzKyts0/hx8XfB/j3XJtI0G53zLbNeW5+020v2i3VlUybIZXeHmSP5J1if5 8bcq4UA6C38I
aMnhLVPC1wk15peqy373kcsmGcXk0ssyBk2kLmZwMcgY5J5rM0/4e2cOv2Xi HU9e1rWtYs7l
JkvLz7OjOiQXUMcLLDFGmxRe3DAhQ5ZxliqhRmDxrdXuvWco8V+EvDul3Or3 Gl2mn6rAXv8A
U3trk28/kt9ojVGaRSqKElIBjc8v5aZmmfH7wTqqXH9jw3upzL5DWVvZ3NnL LepNcw2yMqi4
zB+8uIMrc+S+HPy5RwoB0GofC/QL3Tr2xlvNTWK8sdbspCsibgmq3C3FwR8n 3ldQE7AfeDHm
oNV+FOiapeGO/wBX1qbQzc3t0dC3wraebeQ3EVw28RC4+f7XcNjzsKz/AC4C qop+IfjT4Y8P
28cesWV7YasbmW2m0q8vLG2lgaOOGRt00twts3yXNuwCTMxEo4ykgTT0b4oa BrVprd9pFnqd
zp2j2K3s1/JGltbSI9pDdRBJJ3RdzxTg/NtCbG8wxhoy4BNcfD2zvfN/tfXt a1T7dpr6XrHn
/Z0/tW1PnbI5vKiTZ5f2iXa0HlMd3zl8DE9l4IVNR03U9V8T+INcvtNvvtlv LeyQKoP2e4gC
eXDFHGF23MrFgodjs3MyoqjmPDfxet/FPirQrHwxpM2p2N5FfJqIt7i0lksJ oHsdrtKlwYXi
Ed5ubymlbLKAAyuou+Ffipp2q6To142n6nPaXUWnxXurR20UNtbXd5FA8MLx Gdpgz/abf7gl
RfOUGT5XKgHo1FcZ4B+IVn4t/s7Gg61ov9q6b/aml/2j9nP221HlbpF8iWTZ t8+HKybG/eDA
OG29nQAUUUUAFFFFAFTU/wDUn/d/9mWsqtXU/wDUn/d/9mWsquep8Rcdj5v+ KVromr6R8N/D
V/8ADF/H+q6pca5/ZtuNfbS/I8qYPL8wG1tygH5iMbOPvVxnib4d6T4a0mbV dd/ZTWxtIYpZ
WaT4lgswjieZwihizsI45H2qCcIxxxXX/EGS1j8QfCBLzxND4Wini8X2y6xL OIVsXlieNJQ5
ZcMHZSPmUk4AINY97NZ654T8WeNfiv8AF3wZrfiyw8N6npXhzStJ1y3NvFut ZIXuQiMN81xy
duOA4BUEIkO0VoiXufSvws1nRJvA/gjT9PSTSv7R8Nw32nabvabyLWOK3BTz SvzbPPhXLYZs
5x1x2flv/wA95PyX/CvBNDi1uP4efDPUNI0u9u0T4bSWk01us3+jCY6SGkBh KyM6RLNKsUbL
LJ5LLGQ2CMy3l1i60F9D1y6+I32f+17iLT9c0/TvEFrJbWYtrN5D5IeS4lla aSVYmumeNSkr
AlUWB3YR9HeW/wDz3k/Jf8KPLf8A57yfkv8AhXnvh6LX5/iTeaK2rzT6LoN9 PqRnW5dpZXu4
yYrKZvussXm3TmLAKRnTWBPzZ9GosBH5b/8APeT8l/wo8t/+e8n5L/hUlFFg I/Lf/nvJ+S/4
UeW//PeT8l/wqSiiwEflv/z3k/Jf8KPLf/nvJ+S/4VJRRYCPy3/57yfkv+FH lv8A895PyX/C
pKKLAQSo2+L99Ifn9F4+U+1Z72Wkp4qivJblf7alsXigWSYGQW6OplMaH7q7 3i3soG4iEMTt
jxpy/wCsh/3/AP2U15h8V7jV7Lx1aDRzqdw194W1KO4tobu58tFW709PtKwR OrNLDHcTuBDt
mkA2KwYpgSGen+W//PeT8l/wo8t/+e8n5L/hXhXhGX4jWeg3eqaVdanqsthq 82l6fBq2nalb
RT291bWvl3DQXLvcssN6fmlkkbZB9r2ceWqzeKY/Fuj+OPD1lpl74mb+y7nS dNheS01K/wD7
VsjLCtzdXE8Ugson2SXCv58LSfuvMDLviKFhHt/lv/z3k/Jf8KPLf/nvJ+S/ 4VJRRYCPy3/5
7yfkv+FHlv8A895PyX/CpKKLAR+W/wDz3k/Jf8KPLf8A57yfkv8AhUlFFgI/ Lf8A57yfkv8A
hR5b/wDPeT8l/wAKkoosBH5b/wDPeT8l/wAKPLf/AJ7yfkv+FSUUWAj8t/8A nvJ+S/4Vn6jq
NnpGmW95qN7JbwST21qjBN372eVIYlwFJ5kkRc9BnJIAJrUrj/idaXV74O06 GztprmVdd0SZ
kijLsEj1O1d3IH8KorMT0AUk8Ci2ozf1HR7PULzTbu88yWbTLk3Vm27HlymG SEtgcH93NIuD
kfNnqARd8t/+e8n5L/hXzvHqniuHWNYuNU03xndWV/ps1xqOj2VtrcJsL83l oIYY73zJPMRP
NuNz2CorRRuwikURoOgt7LXbfTtD0LQfFHiC8XxRYzafdS6o17BfWAjuHlmv II7jM8CrFNcQ
rJKZCJP7MUsylnYsI9o8t/8AnvJ+S/4UeW//AD3k/Jf8K4P4p+Z/bmi/2r/w k3/CL/Zrv7X/
AGB9t+0fbd0H2bd9h/0jZ5f2vP8Ayzzt3fN5dcZrul+Nl8GTXg1rxNE154u1 BdSaSG8uXtdL
S5vvsywQWjxXJQubYhom3lHXczQIEUsB7f5b/wDPeT8l/wAKxr1fD2qXmjXd xqdtPNaalMNN
Zblf+PxIbiGVFA4d1jNyrIc7drkgFMjxDxzP8QrTwJp32W88Tf2np2m3V1pF 7FouqTS6jOZZ
TDBJb29ywh8uOO2w2oecZBN+8UOk6m7eaX4w0fT7+08HQeJoPFMniTW7qVXe 5axKz2+sTWDI
ZSbTYzyWrME+USGMS4cAUWA9u07R7PT7zUruz8yKbU7kXV427PmSiGOENg8D 93DGuBgfLnqS
Td8t/wDnvJ+S/wCFeIQ6ZqGseK9K07RZPiBF4Im1K3+0NeXuq2t0JhZam0+6 Wdlulh3DTsfM
Ii+AuWLivTfhl/aq+FDBrH23zrbUtQtoDebjKbWK9mjtizP8z5gWIiRiWcYY lixJLAdF5b/8
95PyX/Cjy3/57yfkv+FSUUWAj8t/+e8n5L/hR5b/APPeT8l/wqSiiwEflv8A 895PyX/Cjy3/
AOe8n5L/AIVJRRYCPy3/AOe8n5L/AIUeW/8Az3k/Jf8ACpKKLAR+W/8Az3k/ Jf8ACjy3/wCe
8n5L/hUlFFgI/Lf/AJ7yfkv+FHlv/wA95PyX/CpKKLAR+W//AD3k/Jf8KPLf /nvJ+S/4VJRR
YCPy3/57yfkv+FHlv/z3k/Jf8KkoosBH5b/895PyX/Cjy3/57yfkv+FSUUWA j8t/+e8n5L/h
XL+IuNRwSSfJ6/8AA3rrK5LxH/yEz/1x/wDaj114JfvTKt8Jh3PArp7X/j0f /r9uv/RrVzF1
0FdPa/8AHo//AF+3X/o1q6c1/hxMsL8bJ7n76f8AXNf5CoqwtU1zXkvpI7Tw feXMEeESb7bb
p5mBjcAXyAe2ecdQOlVv7d8Tf9CPef8Agwtv/i68F7neeYW8Ok+NvifquhXm n6PqdvbeMm1O
8srm+sbvdbR6Q1iZHt1ldxtuUj4dAR5kZwCGCY934R1DSJvA9v4i8Gf25b3n 9mNqOlg2s327
Vl07VjeTSLLIsck2Tbs8rtl9i4ZioA9n/t3xN/0I95/4MLb/AOLo/t3xN/0I 95/4MLb/AOLq
uYVjzC+8BeI30q6t5vDH224u9Omg8Nyebbn/AIRWZ7q8kifLuDB5cU9kmbXz CPsmFyI4t2jc
/DhRpFve6j4Qh16VPF2o6rqGnStDO95aySagtsqCdxEAv2uOYRlkVSZWx5jE N339u+Jv+hHv
P/Bhbf8AxdH9u+Jv+hHvP/Bhbf8AxdLmYWL9xqGtp9t8rw/5vk6jb29t/piL 9otn8nzbnp8v
l+ZN+7PLeRx98VbsLi+mu9Qju9P+ywwXAjtJfOV/tURijYyYHKYdpE2nn93u 6MKxf7d8Tf8A
Qj3n/gwtv/i6P7d8Tf8AQj3n/gwtv/i6QzpqK5n+3fE3/Qj3n/gwtv8A4uig DK+AH/JJdG/3
rn/0plrodO/5K5B/2AZv/SiKue+AH/JJdG/3rn/0plrodO/5K5B/2AZv/SiK vUzb/kZV/wDH
L/0pnHgf90p/4V+SOy1Fttup3bf30Qzux1kUY+8v5Z56Yb7psVX1Fttup3bf 30Qzux1kUY+8
v5Z56Yb7psVzG4VX05t1ux3bv30ozuz0kYY+835Z46YX7osVQtb20ihkE95C jLLKTvmGQA8h
Re: Creating a new Visual Class [message #576668 is a reply to message #12420] |
Gili Mendel![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=gmendel%40us.ibm.com) Messages: 338 Registered: July 2009 |
>> of the
>> that it
>> also
> main() method.
attachement).
name="Image2.jpg"
7seMI3fjaeFwVCAj8SaJa65YpBPJNbzwSiezvLchZ7SYAhZY2IIDYZlIIKsr MjqyMynn5vAt
3N9lupPHfiZtYt
FUDForum. Page generated in 0.04598 seconds
