Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Transaction Questions
| Transaction Questions [message #12360] |
Thu, 19 January 2006 06:55  |
Originally posted by: stepper.sympedia.de
Hi Christian,
I'm just evaluating the new Transaction API for use in my product.
Here are some questions:
1) Is it necessary that own ResourceSets implement IEditingDomainProvider to be used with TXEditingDomain?
2) Is a concurrent thread allowed to read (only!) the ResourceSet of the TXEditingDomain directly, for example to validate in background?
3) Where is the relation between the physical files in the workspace and their in memory representation, e.g. Resources in the ResourceSet? What shall an editor do when the user hits "Save"?
Cheers
/Eike
| Re: Transaction Questions [message #12379 is a reply to message #12360] |
Thu, 19 January 2006 08:38   |
Hi, Eike,
See responses in-line, below.
Christian
Eike Stepper wrote:
> Hi Christian,
No. The TXEditingDomain.Factory links the resource set to its editing
domain by attaching an Adapter to it; the getEditingDomain(ResourceSet)
method does not require the IEditingDomainProvider interface. However, if
you do implement that interface for some other reason, then you will need
to ensure that it is consistent with what the factory thinks the
association is.
I don't understand your question. A thread may actually read multiple
resource sets in different editing domains, but then you would need to be
wary of deadlocks (perhaps by implementing some kind of domain ordering).
Note that the Transaction API doesn't actually implement concurrency as
such; multiple "concurrent" readers of a resource set must cooperatively
yield read access to others. And write access is exclusive of all readers,
yielding or otherwise.
The WorkspaceSynchronizer class can provider the IResource representing an
EMF Resource. As you have probably seen already (indicated by your other
post), the example editor uses this in determining when it needs to refresh
from disk.
> Cheers
> /Eike
| Re: Transaction Questions [message #12388 is a reply to message #12371] |
Thu, 19 January 2006 08:41   |
Hi, Eike,
Marking the changes with some kind of comment is a good idea. Raise a
bugzilla and I'll see to it!
Regarding the code that you had to comment out: you need the M4 or later
version of Eclipse 3.2. This new findEditors() method is more correct than
the older simple editor-input-based findEditor() because it considers the
editor type as well, so that we do not accidentally close (e.g.) a text
editor.
Christian
Eike Stepper wrote:
> I'm just about to analyze your Transaction-related changes to the
> EXTLibraryEditor. It would be easier, if you annotated all your changes
> with @generated NOT (or @ADDED).
> Btw. I had to comment out the following in ResourceLoadedListener
> IEditorReference[] editors = page.findEditors(
> new FileEditorInput(file),
" org.eclipse.emf.workbench.examples.extlibrary.presentation.E XTLibraryEditorID ",
> //$NON-NLS-1$ IWorkbenchPage.MATCH_ID | IWorkbenchPage.MATCH_INPUT);
> page.closeEditors(editors, false);
> MATCH_ID and MATCH_INPUT can't be resolved.
> Cheers
> /Eike
> Eike Stepper schrieb:
>> Hi Christian,
>> Cheers
>> /Eike
| Re: Transaction Questions [message #14496 is a reply to message #12379] |
Thu, 19 January 2006 17:50   |
Christian W. Damus schrieb:
> Hi, Eike,
> Cheers,
> Christian
> Eike Stepper wrote:
>>Hi Christian,
> association is.
I see. That is a nicer solution than EMF's own one ;-)
> from disk.
I should have been running the editor before looking at its code!
I very much like your solution that now there is a visual 1:1 representation
of modified files and editor instances.
Your Transaction component is really great work! Thanks for this ;-)
Cheers
/Eike
| Re: Transaction Questions [message #14527 is a reply to message #14496] |
Thu, 19 January 2006 17:56   |
Thanks for the positive feedback, Eike! That certainly helps to validate
the approach we're taking with this API.
Please don't hesitate to raise any issues that strike you (as I see you are
already doing). I look forward to them.
cW
>> Hi, Eike,
>> Cheers,
>> Christian
>> Eike Stepper wrote:
>>>Hi Christian,
>> if you do implement that interface for some other reason, then you will
>> need to ensure that it is consistent with what the factory thinks the
>> association is.
>> an
>> refresh from disk.
> representation of modified files and editor instances.
> Cheers
> /Eike
| Re: Transaction Questions [message #14588 is a reply to message #14496] |
Fri, 20 January 2006 07:38  |
--------------020900020601010109090306
Eike,
AdapterFactoryEditingDomain has these methods so it's not generally
necessary for a resource set to implement IEditingDomainProvider
directly; it can provide the support using an adapters:
static public EditingDomain getEditingDomainFor(Object object)
if (object instanceof IEditingDomainProvider)
EditingDomain editingDomain =
((IEditingDomainProvider)object).getEditingDomain();
return editingDomain;
else if (object instanceof EObject)
AdapterFactoryEditingDomain.getEditingDomainFor((EObject)obj ect);
else if (object instanceof FeatureMap.Entry)
return getEditingDomainFor(((FeatureMap.Entry)object).getValue());
else if (object instanceof IWrapperItemProvider)
return
getEditingDomainFor(((IWrapperItemProvider)object).getValue( ));
else
return null;
static public EditingDomain getEditingDomainFor(EObject object)
Resource resource = object.eResource();
if (resource != null)
IEditingDomainProvider editingDomainProvider =
(IEditingDomainProvider)EcoreUtil.getExistingAdapter(resourc e,
IEditingDomainProvider.class);
if (editingDomainProvider != null)
return editingDomainProvider.getEditingDomain();
else
ResourceSet resourceSet = resource.getResourceSet();
if (resourceSet instanceof IEditingDomainProvider)
((IEditingDomainProvider)resourceSet).getEditingDomain();
else if (resourceSet != null)
(IEditingDomainProvider)EcoreUtil.getExistingAdapter(resourc eSet,
return null;
>> Hi, Eike,
>> Cheers,
>> Christian
>> Eike Stepper wrote:
>>> Hi Christian,
>> However, if
>> need
>> association is.
>>> and
>> representing an
>> other
>> refresh
>> from disk.
> representation
> Cheers
> /Eike
<html>
<head>
</head>
Eike,<br>
<br>
directly; it can provide the support using an adapters:<br>
<blockquote><small> static public EditingDomain
getEditingDomainFor(Object object)</small><br>
<small> {</small><br>
<small> if (object instanceof IEditingDomainProvider)</small><br>
<small> EditingDomain editingDomain =
((IEditingDomainProvider)object).getEditingDomain();</small ><br>
<small> return editingDomain;</small><br>
<small> }</small><br>
<small> else if (object instanceof EObject)</small><br>
AdapterFactoryEditingDomain.getEditingDomainFor((EObject)obj ect); </small><br>
<small> else if (object instanceof FeatureMap.Entry)</small><br>
<small> return
getEditingDomainFor(((FeatureMap.Entry)object).getValue());</small ><br>
<small> else if (object instanceof IWrapperItemProvider)</small><br>
<small> return
getEditingDomainFor(((IWrapperItemProvider)object).getValue( )); </small><br>
<small> else</small><br>
<small> return null;</small><br>
<small> }<br>
<br>
static public EditingDomain getEditingDomainFor(EObject object)<br>
{<br>
Resource resource = object.eResource();<br>
if (resource != null)<br>
{<br>
IEditingDomainProvider editingDomainProvider =<br>
IEditingDomainProvider.class);<br>
if (editingDomainProvider != null)<br>
{<br>
return editingDomainProvider.getEditingDomain();<br>
}<br>
else<br>
{<br>
ResourceSet resourceSet = resource.getResourceSet();<br>
if (resourceSet instanceof IEditingDomainProvider)<br>
{<br>
((IEditingDomainProvider)resourceSet).getEditingDomain();<br >
return editingDomain;<br>
}<br>
else if (resourceSet != null)<br>
{<br>
{<br>
}<br>
}<br>
}<br>
}<br>
<br>
return null;<br>
}<br>
</small></blockquote>
<br>
<br>
<br>
Eike Stepper wrote:
<blockquote cite="middqp53t$70j$1@utils.eclipse.org" type="cite"><br>
<br>
<br>
<blockquote type="cite">Hi, Eike,
<br>
<br>
<br>
<br>
<br>
<br>
Christian
<br>
<br>
<br>
Eike Stepper wrote:
<br>
<br>
<br>
<blockquote type="cite">Hi Christian,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
if
<br>
need
<br>
<br>
association is.
<br>
</blockquote>
<br>
<br>
<br>
<br>
<blockquote type="cite">3) Where is the relation between the
<br>
<br>
<br>
</blockquote>
<br>
<br>
an
<br>
other
<br>
refresh
<br>
from disk.
<br>
</blockquote>
<br>
<br>
representation
<br>
<br>
<br>
<br>
<br>
Cheers
<br>
/Eike
<br>
</blockquote>
<br>
</body>
</html>
--------------020900020601010109090306--
| Re: Transaction Questions [message #563162 is a reply to message #12360] |
Thu, 19 January 2006 07:51  |
I'm just about to analyze your Transaction-related changes to the EXTLibraryEditor.
It would be easier, if you annotated all your changes with @generated NOT (or @ADDED).
" org.eclipse.emf.workbench.examples.extlibrary.presentation.E XTLibraryEditorID ", //$NON-NLS-1$
Cheers
/Eike
> Hi Christian,
> Cheers
> /Eike
| Re: Transaction Questions [message #563187 is a reply to message #12360] |
Hi, Eike,
Christian
Eike Stepper wrote:
> Hi Christian,
association is.
from disk.
> Cheers
> /Eike
| Re: Transaction Questions [message #563212 is a reply to message #12371] |
Hi, Eike,
editor.
Christian
> Cheers
> /Eike
>> Hi Christian,
>> Cheers
>> /Eike
| Re: Transaction Questions [message #563423 is a reply to message #12388] |
Thu, 19 January 2006 17:20  |
> Hi, Eike,
I filed https://bugs.eclipse.org/bugs/show_bug.cgi?id=124558
In the context of the generated editor the following bugzilla might also be interesting:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=108470
> editor.
I see. I've had some problems with M4 and switched back to M3.
I'll try newer I-builds...
/Eike
| Re: Transaction Questions [message #563449 is a reply to message #12379] |
> Hi, Eike,
> Cheers,
> Christian
> Eike Stepper wrote:
>>Hi Christian,
> association is.
> from disk.
Cheers
/Eike
| Re: Transaction Questions [message #563472 is a reply to message #14496] |
cW
>> Hi, Eike,
>> Cheers,
>> Christian
>> Eike Stepper wrote:
>>>Hi Christian,
>> association is.
>> an
>> refresh from disk.
> Cheers
> /Eike
| Re: Transaction Questions [message #563502 is a reply to message #14466] |
Thu, 19 January 2006 18:00  |
Yes, Eike,
I followed that newsgroup thread with some interest, but I hadn't had a look
at what you and Steven had contributed. I should do so.
cW
>> Hi, Eike,
> be interesting: https://bugs.eclipse.org/bugs/show_bug.cgi?id=108470
>> than the older simple editor-input-based findEditor() because it
>> considers the editor type as well, so that we do not accidentally close
>> (e.g.) a text editor.
> Thanks
> /Eike
| Re: Transaction Questions [message #563528 is a reply to message #14496] |
Eike,
return
else
return null;
else
return null;
>> Hi, Eike,
>> Cheers,
>> Christian
>> Eike Stepper wrote:
>>> Hi Christian,
>> However, if
>> need
>> association is.
>>> and
>> representing an
>> other
>> refresh
>> from disk.
> representation
> Cheers
> /Eike
<html>
<head>
</head>
Eike,<br>
<br>
<small> return
<small> return
<small> }<br>
<br>
{<br>
{<br>
{<br>
}<br>
else<br>
{<br>
{<br>
}<br>
{<br>
{<br>
}<br>
}<br>
}<br>
}<br>
<br>
return null;<br>
}<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Christian
<br>
<br>
<br>
Eike Stepper wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
if
<br>
need
<br>
<br>
association is.
<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
an
<br>
other
<br>
refresh
<br>
from disk.
<br>
</blockquote>
<br>
<br>
representation
<br>
<br>
<br>
<br>
<br>
Cheers
<br>
/Eike
<br>
</blockquote>
<br>
</body>
</html>
Current Time: Sat Nov 01 08:42:03 EDT 2025
Powered by FUDForum. Page generated in 0.62602 seconds
