Home » Eclipse Projects » Eclipse Platform » New RMI Problem
New RMI Problem [message #134239] Tue, 23 September 2003 09:58 Go to next message
Originally posted by: lists.luebken.spamremove.com
Hi there
Well I have a rmi server running in an eclipse plugin.
All worked fine until I added some classes to my serialized objects from
the org/eclipse/core/runtime plugin. (Status and CoreException)
Now when invoking Naming.rebind I'll get an Error.
Any Idea ?
Thanks in advance
MAtt
StackTrace:
java.rmi.ServerError: Error occurred in server thread; nested exception is:
java.lang.NoClassDefFoundError: org/eclipse/core/runtime/IStatus
at sun.rmi.server.UnicastServerRef.oldDispatch(UnicastServerRef .java:349)
at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.ja va:207)
at sun.rmi.transport.Transport$1.run(Transport.java:148)
at sun.rmi.transport.Transport.serviceCall(Transport.java:144)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTranspo rt.java:460)
sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCP Transport.java:701)
at java.lang.Thread.run(Thread.java:536)
sun.rmi.transport.StreamRemoteCall.exceptionReceivedFromServ er(StreamRemoteCall.java:247)
sun.rmi.transport.StreamRemoteCall.executeCall(StreamRemoteC all.java:223)
at sun.rmi.server.UnicastRef.invoke(UnicastRef.java:350)
at sun.rmi.registry.RegistryImpl_Stub.rebind(Unknown Source)
at java.rmi.Naming.rebind(Naming.java:160)
de.itwps.uke.StartupServices.bindPatientenService(StartupSer vices.java:203)
at de.itwps.uke.StartupServices.access$1(StartupServices.java:1 36)
at de.itwps.uke.StartupServices$MyRunnable.run(StartupServices. java:67)
at de.itwps.uke.StartupServices.run(StartupServices.java:123)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:295)
at org.eclipse.core.launcher.Main.run(Main.java:751)
at org.eclipse.core.launcher.Main.main(Main.java:587)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/core/runtime/IStatus
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:140)
de.itwps.uke.service.AbstractPatientenServiceServer_Stub.cla ss$(Unknown
Source)
de.itwps.uke.service.AbstractPatientenServiceServer_Stub.<clinit >(Unknown
Source)
at sun.misc.Unsafe.ensureClassInitialized(Native Method)
sun.reflect.UnsafeFieldAccessorFactory.newFieldAccessor(Unsa feFieldAccessorFactory.java:20)
sun.reflect.ReflectionFactory.newFieldAccessor(ReflectionFac tory.java:122)
at java.lang.reflect.Field.acquireFieldAccessor(Field.java:779)
at java.lang.reflect.Field.getFieldAccessor(Field.java:760)
at java.lang.reflect.Field.getLong(Field.java:398)
at java.io.ObjectStreamClass.getDeclaredSUID(ObjectStreamClass. java:1434)
at java.io.ObjectStreamClass.access$400(ObjectStreamClass.java: 45)
at java.io.ObjectStreamClass$3.run(ObjectStreamClass.java:331)
at java.io.ObjectStreamClass.<init>(ObjectStreamClass.java:329)
at java.io.ObjectStreamClass.lookup(ObjectStreamClass.java:249)
at java.io.ObjectStreamClass.initNonProxy(ObjectStreamClass.jav a:449)
at java.io.ObjectInputStream.readNonProxyDesc(ObjectInputStream .java:1521)
at java.io.ObjectInputStream.readClassDesc(ObjectInputStream.ja va:1435)
java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStre am.java:1626)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java :1274)
at java.io.ObjectInputStream.readObject(ObjectInputStream.java: 324)
at sun.rmi.registry.RegistryImpl_Skel.dispatch(Unknown Source)
at sun.rmi.server.UnicastServerRef.oldDispatch(UnicastServerRef .java:342)
Re: New RMI Problem [message #134486 is a reply to message #134239] Tue, 23 September 2003 15:10 Go to previous messageGo to next message
Originally posted by: olivier_thomann.ca.ibm.comNOSPAM
Le Tue, 23 Sep 2003 11:58:19 +0200, Matthias Luebken
<lists@luebken.spamremove.com> a écrit :
>Hi there
>Any Idea ?
Did you define org.eclipse.core.runtime as a required plugin in your
plugin.xml file?
Olivier
Re: New RMI Problem [message #134572 is a reply to message #134486] Tue, 23 September 2003 17:54 Go to previous messageGo to next message
> plugin.xml file?
yap.
It wouldn't compile otherwise.
I guess it has something to do with the rmi serialization.
Is there anything I should look for ?
matt
Re: New RMI Problem [message #134618 is a reply to message #134239] Tue, 23 September 2003 20:01 Go to previous messageGo to next message
Genady Beryozkin is currently offline Genady BeryozkinFriend
RMI support in eclipse plugins still puzzles me a lot. My uneducated
guess would be that you first, find whether the exception is thrown by
the client or by the server. I case it is thrown by the client (the
server is your plugin), try adding the code plugin to the codebase
exported by the plugin server.
Genady
Matthias Luebken wrote:
> Hi there
> Any Idea ?
> Thanks in advance
> MAtt
> StackTrace:
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
Re: New RMI Problem [message #134993 is a reply to message #134618] Wed, 24 September 2003 12:49 Go to previous messageGo to next message
this might be the problem.
I manually added runtime.jar to the <runtime> element in my plugin.xml
(... <library name="lib/runtime.jar"/> ...)
and it seems to work.
I still don't no why.
I first thought it has something to do with running in the development
mode. But adding the lib worked outside eclipse too.
Matt
> Genady
Re: New RMI Problem [message #260955 is a reply to message #134993] Tue, 13 July 2004 02:09 Go to previous message
> Thanks
> Matt
>> Genady
Hi, Matthias:
That problem comes out from the Eclipse plugin class loading mechanism.
Eclipse plugin's class loading is different from general java application.
Eclipse plugin even will not load the classes you put in the JRE's
extension libraries.
Ted Zhou
Previous Topic:Implement a Progressbar for a DOS command
Next Topic:Eclipse 3.0 manifest.mf classpath issue
Current Time: Sat Nov 09 02:37:06 GMT 2024
Powered by FUDForum. Page generated in 0.03316 seconds
