| [TCS] custom separators in KM3.tcs [message #12281] |
Thu, 17 April 2008 10:39  |
I noticed in KM3.tcs, there are custom separators declared in template
Package and Context:
"before_block_bracket" and "after_supertypes_coma"
however, in class org.eclipse.gmt.tcs.extractor.prettyPrinter in
serializeSeqElem(Object, Object), it seems these custom separators are
never considered. Are they obsolete?
| Re: [TCS] custom separators in KM3.tcs [message #12292 is a reply to message #12281] |
Thu, 17 April 2008 11:41   |
By definition, they are custom. So, you can define your own.
However, they need to be mapped to an implementation. For instance, you
can have a refining transformation that would transform
<before_block_bracket> into <space>. In this way, you separate the
presentation from the contents.
Note that we never actually experimented with this, but such a
transformation could be written quite quickly.
Frédéric Jouault
| Re: [TCS] custom separators in KM3.tcs [message #12352 is a reply to message #12343] |
Mon, 21 April 2008 08:40  |
>>> template Package and Context:
> Okay, but where are these defined? I mean, how does the extractor know
> what to do with "after_supertypes_coma", if this is not specified in the
> TCS, where else?
The extractor ignores custom separators it does not know. So,
"after_supertypes_coma" actually means "nothing" if you do not transform
it to a supported separator.
If you want to give a different meaning than "nothing" to a custom
separator, you can for instance do this in an ATL transformation.
If you do not feel that separating the definition of a custom separator
from its actual implementation is necessary for a specific TCS model,
then you may directly use the predefined custom separator.
At the current time, "after_supertypes_coma" is defined as being
"nothing", which is the default, and does not require any additional
specification.
Frédéric Jouault
FUDForum. Page generated in 0.04048 seconds
