Home » Language IDEs » ServerTools (WTP) » Tomcat 5.5: JavaMail Resource ClassCastException
Tomcat 5.5: JavaMail Resource ClassCastException [message #133883] Sun, 21 August 2005 10:24 Go to next message
Originally posted by: eclipse.2rue.de
Hello everybody,
I'm using Eclipse 3.1, WTP0.7 and Tomcat 5.5 running on Ubuntu. In my
web application, I'm using JavaMail. I have defined and configured the
mail session in WEB-INF/web.xml and META-INF/context.xml, as described here:
http://jakarta.apache.org/tomcat/tomcat-5.5-doc/jndi-resourc es-howto.html
During init() of one of my servlets, I execute the following code to get
the properly configured javax.mail.Session object:
Object o = envContext.lookup("mail/Session");
Session mailSession=(Session) o;
When I deploy the webapp and start tomcat outside of eclipse, this works
just fine. When I start the webapp in Eclipse, the second line of code
throws a ClassCastException. Funnily, Object o has javax.mail.Session as
its class. So I checked the classloaders of o's class and class
javax.mail.Session, and what goes - they are different:
o.getClass().getClassLoader().toString():
org.apache.catalina.loader.StandardClassLoader@dbe178
javax.mail.Session.class.getClassLoader().toString():
WebappClassLoader
delegate: false
repositories:
/WEB-INF/classes/
----------> Parent Classloader:
org.apache.catalina.loader.StandardClassLoader@872380
The JavaMail jars are in $CATALINA_HOME/common/lib. If I put them in
WEB-INF/lib, I get a NoClassDefFoundError with a stacktrace pointing to
Tomcat's resource initialization.
Is there any way around this? Should this be filed as a bug?
greetings from Berlin,
Rüdiger
Re: Tomcat 5.5: JavaMail Resource ClassCastException [message #134118 is a reply to message #133883] Mon, 22 August 2005 10:16 Go to previous messageGo to next message
I believe the StandardClassLoader difference is normal. The
StandardClassLoader@872380 instance is likely "shared/lib", whose parent
class loader is the StandardClassLoader@dbe178 instance. The problem
would appear to be that your servlet using the javax.mail.Session found
in your "WEB-INF/lib" and the resource configuration is using the
javax.mail.Session from "common/lib". According to the documentation
you cite, the mail.jar (and activation.jar) should not be in your
WEB-INF/lib.
Check your ".deployables" directory structure to ensure it's not in that
"WEB-INF/lib", then take whatever steps are necessary to prevent its return.
Larry
Rüdiger Schulz wrote:
> Hello everybody,
> here:
> WebappClassLoader
> delegate: false
> repositories:
> /WEB-INF/classes/
> Rüdiger
Re: Tomcat 5.5: JavaMail Resource ClassCastException [message #134294 is a reply to message #134118] Mon, 22 August 2005 17:21 Go to previous messageGo to next message
Hello Larry,
your assumption was wrong, but your implication was just the right thing :-)
Actually, I had the mail.jar and jaf.jar removed from my
WebContent/WEB-INF/lib directory, and refreshed my project, but never
looked into .deployables - and there were still copies there! So I
removed them, and gone were the exceptions. Thanks a lot!
What was wrong is that the ClassLoader difference would be normal. Now,
both classes have the same ClassLoader, and only then they can be
considered equal. Because I learned while searching the web for
conclusions, that a Class is defined by its fully qualified name *and*
its ClassLoader (e.g. here:
http://forum.java.sun.com/thread.jspa?threadID=493181&me ssageID=2321223)
So, I hadn't heard about that one before. Doesn't happen too often I think.
Another thing with JavaMail (and actually any other library) is, that
you can't put the .jars into $CATALINA_HOME/shared/lib directory, as
that would not be recognized while using the internal Tomcat of WTP -
you have to put them into common/lib. But that is already discussed in
another thread on this group, and also filed as a bug.
So thanks again for your help :-)
- Rüdiger
> WEB-INF/lib.
> return.
> Cheers,
> Larry
>> Hello everybody,
>> here:
>> get the properly configured javax.mail.Session object:
>> works just fine. When I start the webapp in Eclipse, the second line
>> of code throws a ClassCastException. Funnily, Object o has
>> javax.mail.Session as its class. So I checked the classloaders of o's
>> class and class javax.mail.Session, and what goes - they are different:
>> WebappClassLoader
>> delegate: false
>> repositories:
>> /WEB-INF/classes/
>> to Tomcat's resource initialization.
>> Rüdiger
Re: Tomcat 5.5: JavaMail Resource ClassCastException [message #134319 is a reply to message #134294] Mon, 22 August 2005 19:33 Go to previous message
Hi Rüdiger,
I'm glad you got it working. Just to clarify to finish the thread, the
parent classloader of the WebappClassLoader (WEB-INF/classes &
WEB-INF/lib) will be a StandardClassLoader ("shared/lib"), whose parent
classloader will also be a StandardClassLoader ("common/lib"). So it's
normal for the classloader instance for "common/lib" not to be the same
classloader instance that is the parent of the "WEB-INF" classloader,
though they are both StandardClassLoaders. I didn't mean to imply it
would be normal to try and use the same class from different classloaders.
Larry
> Hello Larry,
> - Rüdiger
>> parent class loader is the StandardClassLoader@dbe178 instance. The
>> problem would appear to be that your servlet using the
>> javax.mail.Session found in your "WEB-INF/lib" and the resource
>> configuration is using the javax.mail.Session from "common/lib".
>> According to the documentation you cite, the mail.jar (and
>> activation.jar) should not be in your WEB-INF/lib.
>> that "WEB-INF/lib", then take whatever steps are necessary to prevent
>> its return.
>> Cheers,
>> Larry
>>> Hello everybody,
>>> the mail session in WEB-INF/web.xml and META-INF/context.xml, as
>>> described here:
>>> Session mailSession=(Session) o; When I deploy the webapp and start
>>> tomcat outside of eclipse, this works just fine. When I start the
>>> webapp in Eclipse, the second line of code throws a
>>> ClassCastException. Funnily, Object o has javax.mail.Session as its
>>> WebappClassLoader
>>> delegate: false
>>> repositories:
>>> /WEB-INF/classes/
>>> Rüdiger
Previous Topic:How to upgrade wtp-0.7RC3 to wtp-0.7
Next Topic:Installation Woes w/WTP .7
Current Time: Thu Nov 06 23:54:21 EST 2025
Powered by FUDForum. Page generated in 0.03201 seconds
