Home » Language IDEs » C / C++ IDE (CDT) » Exception processing debug async queue
Exception processing debug async queue [message #133783] Fri, 07 January 2005 05:17 Go to next message
When I debug my program with Eclipse, sometimes I have some crashes
"Exception processing debug async queue".
Below is an extract of my .log file, with the trace of the problem.
Has someone got any idea ?
Platform: Windows 2000, Eclipse 3.0.1, CDT 2.0.2
Jerome
ENTRY org.eclipse.debug.core 4 120 Jan 07, 2005 10:44:12.62
!MESSAGE Exception processing debug async queue
!SUBENTRY 1 org.eclipse.debug.core 4 120 Jan 07, 2005 10:44:12.62
!STACK 0
java.lang.ArrayIndexOutOfBoundsException: 0
org.eclipse.cdt.debug.internal.core.model.DisassemblyBlock.i nitializeAddresses(DisassemblyBlock.java:183)
org.eclipse.cdt.debug.internal.core.model.DisassemblyBlock.c reate(DisassemblyBlock.java:64)
org.eclipse.cdt.debug.internal.core.model.Disassembly.create Block(Disassembly.java:90)
org.eclipse.cdt.debug.internal.core.model.Disassembly.getDis assemblyBlock(Disassembly.java:52)
org.eclipse.cdt.debug.internal.ui.views.disassembly.Disassem blyEditorInput.create(DisassemblyEditorInput.java:186)
org.eclipse.cdt.debug.internal.ui.views.disassembly.Disassem blyView$4.run(DisassemblyView.java:544)
at org.eclipse.debug.core.DebugPlugin$AsynchJob.run(DebugPlugin .java:876)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
Re: Exception processing debug async queue [message #133848 is a reply to message #133783] Fri, 07 January 2005 11:24 Go to previous message
Originally posted by: mikhailk.qnx.com
This bug has been fixed in CDT 2.1. I would suggest to switch to CDT 2.1.
"jerome correnoz" <jerome.correnoz@st.com> wrote in message
news:crlnki$r7u$1@www.eclipse.org...
> "Exception processing debug async queue". Below is an extract of my .log
> Thanks
> Jerome
> !STACK 0
> at
> at
> at
> at
> at
> at
Previous Topic:test
Next Topic:the problem of hello jni
Current Time: Wed Nov 05 08:13:14 EST 2025
Powered by FUDForum. Page generated in 0.04949 seconds
