Problems with params in drilldown reports [message #133750] |
Wed, 22 February 2006 00:30 |
Jose Meireles Messages: 8 Registered: July 2009 |
Junior Member |
I'm using BIRT 2.0 and I have a a sub report that will accept a value in
a parameter. In the master report I've created a link in a detail field
that will lead to the sub report. I've selected the parameter and the
value (row[<row_name>]). The first time I run the report (in preview
mode) it runs fine but if I select a different value the sub-report will
continue to show the same data. Pressing the "run report" button in the
BIRT report viewer will show a window with the correct parameter and
after pressing the "run report" button will refresh the correct data.
This behaviour seems strange... shouldn't the sub-report show me the
correct data without the need for that "refresh" operation?
Thanks in advance
Jose
FUDForum. Page generated in 0.03117 seconds
