Home » General (non-technical) » Eclipse Foundation » SWT API Copyright question
Re: SWT API Copyright question [message #12215 is a reply to message #12207] |
Wed, 19 January 2005 19:58 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Bjorn Freeman-Benson![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=bjorn%40superboy.org) Messages: 75 Registered: July 2009 |
Member |
Marco,
The EPL (Eclipse Public License) happily allows you extend the APIs,
reimplement the APIs, use the libraries, etc. In fact, as long as you have
not changed the SWT code and re-released it (or incorporated the SWT code in
your released code), then you are free to release your code under any
license you want. We, of course, think you should use the EPL, but then
we're just biased :-)
Have you considered contributing your code to the SWT team to see if they'd
like to consider it for the base SWT releases?
"not a lawyer and I don't play one on TV either"
Re: SWT API Copyright question [message #12218 is a reply to message #12215] |
Wed, 19 January 2005 20:13 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Marco Maccaferri![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=macca%40maccasoft.com) Messages: 147 Registered: July 2009 |
Good, so I can replicate the SWT class hierarchy and functionality
without problems. I think that I'll release the library under the EPL.
I don't know if the SWT team may be interested, as I said the library
replicates the SWT class structure, but the output is html for builing
web applications, not for stand-alone GUIs.
Bye
Re: SWT API Copyright question [message #12664 is a reply to message #12218] |
Thu, 20 January 2005 07:14 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Slamlander![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=slamlander%40livejournal.com) Messages: 31 Registered: July 2009 |
Member |
Have you considered some variation of subclassing?
On the surface, what you are doing may conflict with SWT. While I realize
that your library will probably not be linked at the same time as SWT, I can
see corner cases where this could become a problem for build/release/install
processes.
"Marco Maccaferri" <macca@maccasoft.com> wrote in message
news:csmf0v$4ph$1@www.eclipse.org...
have
code in
they'd
> Bye
Current Time: Sat Jul 27 12:19:39 GMT 2024
Powered by FUDForum. Page generated in 0.03507 seconds
