Using eclipse.buildScript [message #133234] |
Fri, 19 September 2003 19:45 |
Originally posted by: matt_conway.nospam.i2.com
How do I use the eclipse.buildScript task to generate the build.xml from
a plugin.xml?
I'm trying to automate the release of my plugins via an ant script, and
need to generate the build.xml for the feature and its plugins so that I
can then call ant on it and push the results out to an update site.
If I do something like:
<eclipse.buildScript elements="plugin@my.plugin"
workingDirectory="${eclipse.home}"/>
it generates a build.xml in the instaled plugin directory, but I can't
seem to get it to generate a plugin in the source project that is in my
workspace.
Matt
p.s. trying this on build 200309170800
Re: Using eclipse.buildScript [message #190039 is a reply to message #133234] |
Thu, 05 February 2004 15:11 |
Originally posted by: john.ellis.ascentialsoftware.com
Matt,
Did you ever figure this out? I am in the same position right now and would
love to know what the solution is.
Cheers, John
"Matt Conway" <matt_conway@nospam.i2.com> wrote in message
news:bkfmaa$mbh$1@eclipse.org...
> a plugin.xml?
> workspace.
> Matt
FUDForum. Page generated in 0.02709 seconds
