Home » Eclipse Projects » GEF » Tripolar connection
Tripolar connection [message #132923] |
Wed, 19 May 2004 08:27 |
Originally posted by: grandan.tiscali.it
I need some informations about GEF connections.
Is it possibile to create a tripolar connection? I mean a connection
between 3 different graphic figures. In other way, can I create an anchor
on a connection (for example, in a manner similar to bendpoints)?
Thank you very much!
Bye bye
Daniele
Re: Tripolar connection [message #132936 is a reply to message #132923] |
Wed, 19 May 2004 09:02 |
Originally posted by: brian.fernandes.codito.com
Hi Daniele,
"Daniele" <grandan@tiscali.it> wrote in message
news:c8f5p6$nkv$1@eclipse.org...
What you probably want is to connect a connection to another connection,
instead of any other EditPart. This is possible, install the
GRAPHICAL_NODE_ROLE in your Connections EditPart. This was discussed in a
previous threads as well... check
Branched Connections - possible Contribution 24/09/04
Connecting connections to connections ... 06/11/04
Hope this helps,
Brian.
Re: Tripolar connection [message #133208 is a reply to message #132936] |
Thu, 20 May 2004 11:45 |
Hi Brian,
thank you for the information, I found it very usefull. Now I have a
question: how can I create a connection anchor on the connection. Can I
put the FixedConnectionAnchor of LogicExample on a connection?
Where can I find an example of this process?
Thank you very much.
Daniele
Brian Fernandes wrote:
> Hi Daniele,
> > Hi,
> Hope this helps,
> Brian.
Re: Tripolar connection [message #133236 is a reply to message #133208] |
Thu, 20 May 2004 12:31 |
Hi Daniele,
I wrote my own Anchor for this purpose.
Basically what I did was - I went through all the points on the connection
(and also the connections that were connected to the connection) and found
the most appropriate point for the anchor. I returned this point in
AbstractConnectionAnchor#getLocation.
This allowed my connections to re-anchor themseleves as the connections they
are connected to moved.
Depending on how you want your sub-connections to connect to the
parent-connection, you will have to decide how advanced to make your anchor.
It can get a little complex, write back if you need more assistance,
All the best,
Brian.
news:c8i5oe$2fm$1@eclipse.org...
> Hi Brian,
> Daniele
> > Hi Daniele,
> > > Hi,
anchor
a
> > Hope this helps,
> > Brian.
Re: Tripolar connection [message #134095 is a reply to message #133236] |
Tue, 25 May 2004 14:41 |
Hi Brian,
I still need your help.
This is my case: I need a connection A which can anchor itself on a
connection B. So I create a ConnectionFigure for B which extends
PolylineConnection and I add a FixedConnectionAnchor (of the logic
example) on it. I add the anchor in the method
getConnectionCompleteCommand of the EditPart associated with connection B.
My problem is that connection A never anchor itself on the connection B,
but always in the position x=100, y=100.
Can you tell me where I'm wrong?
Can you send me an example (or a set of classes used by it) of an editor
with a connection which can connect itself on another connection?
Thank you very much for the help!
Bye bye
Daniele
> Hi Daniele,
> All the best,
> Brian.
> > Hi Brian,
> > Daniele
> > > Hi Daniele,
> > > > Hi,
> anchor
> a
> > > Hope this helps,
> > > Brian.
Re: Tripolar connection [message #134105 is a reply to message #134095] |
Tue, 25 May 2004 16:56 |
Hi Daniele,
I'm afraid my editor and it's anchors are too complex to be of any use to
you.
The FixedConnecitonAnchor won't work the way you want it to.
Implement your own anchor by extending AbstractConnectionAnchor
Override getLocation.
Your "owner" figure is the ConnectionFigure B. Since this is a
PolylineConneciton figure, call getPoints() to get a list of the points that
make up B's polyline.
For now, return the first of these points - later you can use your own logic
to return a point that will lead to the best possible routing.
Finally, use translateToAbsolute on this point to allow for scroll / zoom
etc. Something like getOwner().translateToAbsolute(returnPoint);
You can pretty much copy FixedConnectionAnchor, but change the getLocation
method.
Hope this helps,
Brian.
Re: Tripolar connection [message #134246 is a reply to message #134095] |
Tue, 25 May 2004 21:03 |
It sounds like your connection editpart is not implementing hte NodeEditPart
interface properly.
news:c8vltn$i7r$1@eclipse.org...
> Hi Brian,
> Bye bye
> Daniele
> > Hi Daniele,
connection
found
they
anchor.
> > All the best,
> > Brian.
> > > Hi Brian,
I
> > > Daniele
> > > > Hi Daniele,
> > > > > Hi,
connection
> > anchor
connection,
discussed in
> > a
> > > > Hope this helps,
> > > > Brian.
Re: Tripolar connection [message #134432 is a reply to message #134246] |
Wed, 26 May 2004 14:55 |
I created a new anchor for my connection implementing the method
getLocation on your (Brian) indications. My connection edit part also
implements the NodeEditPart.
When I drag the secondary connection onto the primary connection, the
secondary anchors itself at the right position. But when I click to fix
the connection always the target anchor becomes the point x=100, y=100.
I think the problem is not on the anchor.. but in the edit part (or in the
edit policy or in the connection model).
What about the connection model and edit policy? What do I miss?
Thank you very much for the help.
Your indications are very usefull for me.
bye bye,
Daniele
> interface properly.
> > Hi Brian,
> > Bye bye
> > Daniele
> > > Hi Daniele,
> connection
> found
> they
> anchor.
> > > All the best,
> > > Brian.
> > > > Hi Brian,
> I
> > > > Daniele
> > > > > Hi Daniele,
> > > > > > Hi,
> connection
> > > anchor
> connection,
> discussed in
> > > a
> > > > > Hope this helps,
> > > > > Brian.
Current Time: Fri Jul 12 08:48:50 GMT 2024
Powered by FUDForum. Page generated in 0.03886 seconds
