Home » Archived » DSDP » RSE 1.0.1: Persisting property sets of an IHost
RSE 1.0.1: Persisting property sets of an IHost [message #12093] Wed, 09 May 2007 11:22 Go to next message
Hi all,
I am adding a property set to a connection (IHost) and using the commit()
method of IHost they are persisted onto disk (I verified that in the file
system). That is what I expected, so far so good. The question now is, how
to retrieve them from disk. If I call getPropertySet() on the respective
IHost the property set is not there. It is still on disk, but it is
obviously not loaded. How do I do that?
Andreas
Re: RSE 1.0.1: Persisting property sets of an IHost [message #12106 is a reply to message #12093] Thu, 10 May 2007 05:49 Go to previous messageGo to next message
Hello Andreas,
this is a question specific to Target Management, so I'm cross-posting
to the eclipse.dsdp.tm newsgroup; please use that newsgroup for
follow-up questions.
I think that your problem is actually a known bug fixed for TM 2.0M6, see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=150115
Can you upgrade to the recent TM 2.0 milestones? M7 is coming next week,
and from then on the API will be frozen. There's been a lot of API
changes so if you have much code already you'll need to migrate it; the
build notes give initial help doing so, but full migration docs yet need
to be written.
Martin Oberhuber
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Andreas Schik wrote:
> Hi all,
> commit() method of IHost they are persisted onto disk (I verified that
> in the file system). That is what I expected, so far so good. The
> question now is, how to retrieve them from disk. If I call
> getPropertySet() on the respective IHost the property set is not there.
> It is still on disk, but it is obviously not loaded. How do I do that?
> Thanks
> Andreas
Re: RSE 1.0.1: Persisting property sets of an IHost [message #12119 is a reply to message #12106] Thu, 10 May 2007 08:02 Go to previous message
Hello Martin,
Am 10.05.2007, 10:49 Uhr, schrieb Martin Oberhuber =
<martin.oberhuber@windriver.com>:
> Hello Andreas,
> this is a question specific to Target Management, so I'm cross-posting=
> to the eclipse.dsdp.tm newsgroup; please use that newsgroup for =
> I think that your problem is actually a known bug fixed for TM 2.0M6, =
see
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D150115
yes, it seems to be the same. Sorry for not checking the bug reports clo=
se =
enough.
> Can you upgrade to the recent TM 2.0 milestones? M7 is coming next wee=
k, =
> and from then on the API will be frozen. There's been a lot of API =
> changes so if you have much code already you'll need to migrate it; th=
e =
> build notes give initial help doing so, but full migration docs yet ne=
ed =
> to be written.
Actually, I went for another solution, as my first approach using host =
properties would have brought other problems for me. Hence, I dropped th=
is =
idea.
I appreciate your help anyway. Thanks.
Andreas
Re: RSE 1.0.1: Persisting property sets of an IHost [message #571119 is a reply to message #12093] Thu, 10 May 2007 05:49 Go to previous message
Hello Andreas,
to be written.
Martin Oberhuber
> Hi all,
> Thanks
> Andreas
Re: RSE 1.0.1: Persisting property sets of an IHost [message #571152 is a reply to message #12106] Thu, 10 May 2007 08:02 Go to previous message
Hello Martin,
> Hello Andreas,
see
se =
enough.
k, =
e =
ed =
> to be written.
is =
idea.
Andreas
Previous Topic:RSE 1.0.1: Persisting property sets of an IHost
Next Topic:Target Management 2.0M7 is released!
Current Time: Wed Oct 15 04:13:12 EDT 2025
Powered by FUDForum. Page generated in 0.05908 seconds
