| JRE 5.0 [message #132309] |
Thu, 26 January 2006 21:25  |
Originally posted by: jtrink.gmail.com
Hello, I just installed Eclipse 3.1 and installed a java platform. Now,
i'm trying to write things using ArrayLists and Scanners. I continually
get the error that the ArrayList in eclipse doesn't have the java platform
updated to 5.0. I know for a fact that i updated to 5.0...does anyone
have any ideas????
| Re: JRE 5.0 [message #132565 is a reply to message #132551] |
Fri, 27 January 2006 11:58  |
Originally posted by: weconsul.ptd.net
Olivier Thomann wrote:
> IchBin a écrit :
>> After you installed 1.5 did you let Eclipse know where you installed it.
>> Go to the menu:
>> - Select Windows -> preferences -> Java -> Installed JRE
>> If it's not there then
>> - Select Add
>> - Add same name to say JRE 1.5.0_6
>> - Select Browse to the Java JRE home directory (For me it's:
>> C:\Program Files\Java\jre1.5.0_06 )
>> - Save and your done.
> I would highly recommend using a SDK to compile code. Using a JRE, you
> might not get deprecation warnings since the JRE is purged from any
> deprecated information.
> A JRE is fine to execute the code.
> Olivier
I use the JRE and I get deprecation warnings where needed. I have not
looked into this because I did not care. Since Eclipse has their own
compiler where does Eclipse compiler end and the class file to JVM for
Sun Start?
Thanks in Advance...
IchBin, Pocono Lake, Pa, USA
http://weconsultants.servebeer.com/JHackerAppManager
____________________________________________________________ ______________
'If there is one, Knowledge is the "Fountain of Youth"'
-William E. Taylor, Regular Guy (1952-)
FUDForum. Page generated in 0.11526 seconds
