Home » Archived » Riena » the cvs address does not exist!
the cvs address does not exist! [message #12085] Mon, 22 September 2008 11:51 Go to next message
zhaozhongwei is currently offline zhaozhongweiFriend
hi,i am a new guy,i try to download the source from the cvs ,but there is
a error as following:
could not connect to
pserver:anonymous@dev.eclipse.org:/cvsroot/rt/org.eclipse.riena I/O
exception occurred:Connection refused:cvs [pserver
aborted]:/cvsroot/rt/org.eclipse.riena:no such repository
thanks for your answer!
Re: the cvs address does not exist! [message #12098 is a reply to message #12085] Tue, 23 September 2008 09:07 Go to previous message
Christian Campo is currently offline Christian CampoFriend
> is a error as following:
The address is actually host:dev.eclipse.org repository:/cvsroot/rt and then
the base tree for riena projects is org.eclipse.riena. When you specify the
CVS repository in eclipse you only specify pserver:anonymous@dev.eclipse.org/cvsroot/rt
hope that helps
christian campo
Re: the cvs address does not exist! [message #575173 is a reply to message #12085] Tue, 23 September 2008 09:07 Go to previous message
hope that helps
christian campo
Previous Topic:the cvs address does not exist!
Next Topic:Logging in OSGI Enterprise Apps
Current Time: Fri Nov 08 22:38:27 GMT 2024
Powered by FUDForum. Page generated in 0.02990 seconds
