Re: [EcoreTools] NPE in ComposedAdapterFactory.adapt [message #132175 is a reply to message #132161] |
Tue, 13 January 2009 10:45 |
Hi Andrew,
Can you please open a bug [1] against EcoreTools with your NPE's stack
trace (and, if possible, steps to reproduce)?
Thanks!
Benjamin
[1] https://bugs.eclipse.org/bugs/enter_bug.cgi?product=EMFT
Andrew H a écrit :
> We are having a lot of troubles with the ecore diagrams. We are using
> them heavily as they are so useful - i.e. we use them almost exclusively
> to develop our models.
> Unfortuately they are extremely brittle. Our model is evolving heavily
> and we keep breaking the diagrams. The worst part is not simply that
> they break but that they break leaving no clue as to how to fix it. This
> is because we tend to get these NPE's. If this was trapped and a useful
> message given then we could modify the xml for the diagram and fix the
> problem (in theory at least).
> This would be very valuable until such a time as proper refactoring
> support is built into the diagrams.
> Is there any advice as to how to determine the cause of breaks such as
> these?
> Also, how long before we have a way to evolve the ecore models that
> doesn't break the diagrams?
> The NPE is
> java.lang.NullPointerException
> at
> org.eclipse.emf.edit.provider.ComposedAdapterFactory.adapt(C omposedAdapterFactory.java:340)
> at
> org.eclipse.emf.edit.provider.ComposedAdapterFactory.adapt(C omposedAdapterFactory.java:277)
> at
> org.eclipse.emf.ecoretools.diagram.edit.parts.EAttributeEdit Part.getLabelText(EAttributeEditPart.java:233)
> at
> org.eclipse.emf.ecoretools.diagram.edit.parts.EAttributeEdit Part.refreshLabel(EAttributeEditPart.java:415)
> at
> org.eclipse.emf.ecoretools.diagram.edit.parts.EAttributeEdit Part.refreshVisuals(EAttributeEditPart.java:404)
> at
> org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractE ditPart.java:676)
> at
> org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh( AbstractGraphicalEditPart.java:571)
> at
> org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.access$3(GraphicalEditPart.java:1)
> at
> org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt$3.run(GraphicalEditPart.java:839)
> at
> org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl.runExclusive(TransactionalEditingDomainImpl.java:289)
> at
> org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.refresh(GraphicalEditPart.java:829)
> at
> org.eclipse.gef.editparts.AbstractEditPart.addNotify(Abstrac tEditPart.java:235)
> at
> org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotif y(AbstractGraphicalEditPart.java:219)
> at
> org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:198)
> at
> org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.addChild(GraphicalEditPart.java:1295)
> at
> org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:727)
> at
> org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractE ditPart.java:677)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.gef.editparts.SimpleRootEditPart.setContents(Sim pleRootEditPart.java:101)
> at
> org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents( AbstractEditPartViewer.java:601)
> at
> org.eclipse.gmf.runtime.diagram.ui.parts.DiagramGraphicalVie wer.setContents(DiagramGraphicalViewer.java:378)
> at
> org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents( AbstractEditPartViewer.java:610)
> at
> org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.initi alizeGraphicalViewerContents(DiagramEditor.java:870)
> at
> org.eclipse.emf.ecoretools.diagram.part.EcoreDiagramEditor.i nitializeGraphicalViewerContents(EcoreDiagramEditor.java:448 )
> at
> org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.initi alizeGraphicalViewer(DiagramEditor.java:863)
> at
> org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditorWithFl yOutPalette.initializeGraphicalViewer(DiagramEditorWithFlyOu tPalette.java:116)
> at
> org.eclipse.emf.ecoretools.diagram.part.EcoreDiagramEditor.i nitializeGraphicalViewer(EcoreDiagramEditor.java:335)
> at
> org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.creat eGraphicalViewer(DiagramEditor.java:807)
> at
> org.eclipse.gef.ui.parts.GraphicalEditor.createPartControl(G raphicalEditor.java:163)
> at
> org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.creat ePartControl(DiagramEditor.java:1555)
> at
> org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditorWithFl yOutPalette.createPartControl(DiagramEditorWithFlyOutPalette .java:328)
> at
> org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.createPartControl(DiagramDocumentEditor. java:1459)
> at
> org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
> at
> org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:428)
> at
> org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
> at
> org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:266)
> at
> org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2820)
> at
> org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2729)
> at
> org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2721)
> at
> org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2673)
> at
> org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
> at
> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2668)
> at
> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2652)
> at
> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2643)
> at org.eclipse.ui.ide.IDE.openEditor(IDE.java:646)
> at org.eclipse.ui.ide.IDE.openEditor(IDE.java:605)
> at
> org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:318)
> at
> org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:160)
> at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:22 8)
> at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:20 7)
> at
> org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:274)
> at
> org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:250)
> at
> org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:363)
> at
> org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 5.open(PackageExplorerPart.java:603)
> at
> org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:820)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
> at org.eclipse.core.runtime.Platform.run(Platform.java:880)
> at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
> at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
> at
> org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:818)
> at
> org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1079)
> at
> org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1183)
> at
> org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:263)
> at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:257)
> at
> org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:297)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1158)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3401)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3033)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:585)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
My blog: http://blog.benjamin-cabe.com
Re: [EcoreTools] NPE in ComposedAdapterFactory.adapt [message #620577 is a reply to message #132161] |
Originally posted by: benjamin.cabe.anyware-tech.com
Hi Andrew,
Thanks!
Benjamin
> these?
> The NPE is
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
FUDForum. Page generated in 0.03669 seconds
