Home » Modeling » GMF (Graphical Modeling Framework) » How programmatically modify model elements' attributes?
How programmatically modify model elements' attributes? [message #131984] Mon, 04 June 2007 04:49 Go to next message
Originally posted by: tyhoho.gmail.com
I use my gmf developed editor draw a gragh, the model file and diagram
file are named"hello.test"and "hello.diagram_test".I want to rename one of
the elements in the model file programmatically,here is the code
TransactionalEditingDomain editingDomain =
GMFEditingDomainFactory.INSTANCE
.createEditingDomain();
ResourceSet resourceSet = editingDomain.getResourceSet();
EMDiagramImpl modelDiagram=null;//it's the diagram for the model
Resource resourceModel = resourceSet.getResource(URI
.createPlatformResourceURI("fileroot/hello.test", true), true);
diagramRoot= (EMDiagramImpl) resourceModel.getContents().get(0);
EList docList=modelDiagram.getDocument();
EMPDocumentImpl doc=(EMPDocumentImpl)(docList.get(0));//
doc.setName("can i change it");//!!note:doc is not null!!
Errors are arised by the last sentence,they are:
1.java.lang.IllegalStateException: Cannot modify resource set without a
write transaction
2.Unhandled event loop exception
Anybody can help?
Thanks in advance.
Tina
Re: How programmatically modify model elements' attributes? [message #131997 is a reply to message #131984] Mon, 04 June 2007 04:53 Go to previous message
> write transaction
> Anybody can help?
> Thanks in advance.
> Tina
Previous Topic:GMF learning materials
Next Topic:Error opening gmfmap file with GMF 1.0.3
Current Time: Tue Nov 04 08:26:33 EST 2025
Powered by FUDForum. Page generated in 0.06922 seconds
