Re: Plug-In loaded but not working [message #132047 is a reply to message #131958] |
Fri, 29 May 2009 09:16 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hauke Fuhrmann![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=haf%40informatik.uni-kiel.de) Messages: 333 Registered: July 2009 |
Hi Matthias,
I often have the same Problem, but no answer:
I start plugins in an Eclipse application. There they are available in
the Plug-in registry and I get no errors in the log (e.g. about
unresolved dependencies). However, I don't see any effects of the
plugins, i.e. the contributed items, e.g. buttons, editors, views, are
not available.
I have no solution for this, so how is a way to debg the behavior? Any
hints from anyone??
Starting an Eclipse Application from a Run configuration has the
"Validate Plugins" option, which sometimes help to find the flaw. Is
there something equivalent when I run a standalone Eclipse with some new
plugins?
Please help!
Hauke
Matthias Schmeling schrieb:
> I made a feature with several plug-ins. One of them adds an entry to the
> context menu. I also made an update site to test if one can install and
> use it. However, after installing the feature, the new context menu
> entry is not shown. All of the plug-ins are loaded and the others are
> working fine. I don't have a clue how to debug this. Can you tell me how
> I can find out what's wrong with the context menu plug-in?
> (The plug-in works when I start the project in a new eclipse instance.
> There I have the menu entries.)
> Thanks in advance,
> Matthias
Re: Plug-In loaded but not working [message #132060 is a reply to message #131958] |
Fri, 29 May 2009 09:16 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hi Matthias,
not available.
hints from anyone??
plugins?
Please help!
Hauke
> Thanks in advance,
> Matthias
FUDForum. Page generated in 0.03179 seconds
