| importing packages [message #131618] |
Thu, 21 May 2009 14:58  |
I'm trying to import a package "pack.one" declared as exportable -that is
obtaining Export-Package: pack.one in Manifest.-
Well, if I import this package into a new bundle, I can see every class
contained in pack.one but it doesn't work when I run bundle.
I suppose it's a matter of localization of file .class; importing pack.one
doesn't require any information about localization of file .class which
can be found in a separate (bin) directory while source file (resolved
correctly when I write code) resides in src directory.
I hope this question is not much mess...
How can I fix this problem?
Andrea
| Re: importing packages [message #131671 is a reply to message #131652] |
Sun, 24 May 2009 07:00   |
Hi Andrea,
Your description is a bit cryptic, but I assume you're trying to explain
that you're having a problem with one particular OSGi bundle, that you
don't have any compile-time issues, but are experiencing run-time issues.
I would help if you could give some additional information:
- are you on 3.4 Ganymede, or any of the 3.5 Galileo milestones?
- are you trying to mix pure OSGi bundles with RCP plug-ins?
- can you create two example projects (bundles, or RCP plugins if that
applies) which reproduce the problem and offer them on-line somewhere?
The first thing I would check out is the state of your problem bundle,
at the OSGi console. Use 'ss' in the Console View, once your application
is run.
Best,
Dann
andrea wrote:
> Thx for your message.
>> In standard eclipse plugins, all of the .java files and resources
>> related to i18n are in the <proj>/src directory, and eclipse copies
>> the resources to the <proj>/bin directory when it compiles the .java
>> files.
> Yes, that's what occurs in my case too.
>> Are you saying you can't launch your app from within eclipse, or you
>> cannot deploy and run your bundle in an existing app?
> What I'm trying to say is that when I launch a plugin PLG in a OSGI way,
> PLG will work well, (for instance writing a sentence contained in start
> method) but the same PLG will not if I import a package pack.x.
> I want underline that only when pack.x is installed I can write code
> using pack.x's classes. This is the reason that make me suspect a kind
> of "splitted" behaviour: code works fine while launching plugin does not.
> Thx again
> Andrea
>> PW
| Re: importing packages [message #131681 is a reply to message #131671] |
Sun, 24 May 2009 15:55  |
Ciao Dann,
very kind of you.
I really was not able to understand the reason of failure in executing my
imported plugins, anyway, after many unsuccessful attempts, strongly
suspecting strange kind of bugs, I resetted everything and then I rewrote
my plugings. Something of magic occurred and now everything works fine.
Thx again
andrea
FUDForum. Page generated in 0.04457 seconds
