Is Load Time Weaving required? [message #11984] |
Mon, 30 June 2008 21:39 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
When using EclipseLink in a Spring environment is it necessary to
configure Load Time Weaving (LTW)?
Btw, excuse my ignorance, but I was unaware until I started exploring
Spring that LTW was an issue with JPA. Indeed I do not have to take
special action when I am using JPA in a J5EE app server, but that may
well be because JPA is native to the environment. What really makes
me wonder is that Googling for:
+JPA "Load Time Weaving" LTW -spring
brings back only a few hits. Is this a Spring specific issue? Yes,
yes, I know, I should be asking this on the Spring Forum :-)
Joel
Joel Rosi-Schwartz
Etish Limited [http://www.etish.org]
/ o,o \ The proud parents of Useme
|) ::: (| The Open Requirements Management Too
====w=w==== [https://useme.dev.java.net]
Re: Is Load Time Weaving required? [message #12021 is a reply to message #12008] |
Tue, 01 July 2008 10:04 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Doug,
Thanks for the reply.
After reading up on the Spring LTW yesterday I am concerned about the
deploy time implications of using dynamic weaving. My goal is that ORMF
be deployable in any compliant web container it appears that there are
configurations differences, when depending on LTW, with Spring
depending on the environment. To avoid this I think that we would be
better off using static compile time weaving. Do you concur or are
there benefits to dynamic weaving that I am overlooking?
Joel
Re: Is Load Time Weaving required? [message #563975 is a reply to message #12008] |
Tue, 01 July 2008 10:04 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hi Doug,
Joel
FUDForum. Page generated in 0.04080 seconds
