Home » Eclipse Projects » GEF » No more handles error [bug 53632]
No more handles error [bug 53632] [message #131233] |
Thu, 06 May 2004 18:46 |
Originally posted by: phil.williams.toadmail.com
All,
After going through and plugging all my own leaks when creating SWT
resources, I am still getting the dreaded no more handles error in my
GEF-based plugin. I am using 2.1.2 and have updated the draw2d jar that
Pratik posted to bug 53632. I have this error happening for several
users on several different machines and configurations.
In the last comment to this bug Randy mentions that this doesn't happen
in 3.0 because there is better error handling. Is it possible to get
these into the 2.1.x stream?
Also, I noticed that there are several open bugs on different causes of
the "No more handles" error. What is the best way to determine which
effect I am seeing? Obviously if I see draw2d in the stack, I know that
it is this one.
Phil
Re: No more handles error [bug 53632] [message #131247 is a reply to message #131233] |
Thu, 06 May 2004 22:40 |
You should report the conditions which cause this problem on the bugzilla.
Version 2.1.3 has been completed and tested by various GEF clients. There
are no plans for a 2.1.4 at this point. That doesn't mean that it won't
happen, but it is not scheduled.
You can try taking the code from HEAD and merging it into your own 2.1.x
version of the draw2d plug-in. The affected class is
BufferedGraphicsSource.
"Phil Williams" <phil.williams@toadmail.com> wrote in message
news:c7e0qg$uoc$1@eclipse.org...
> All,
> it is this one.
> Phil
Re: No more handles error [bug 53632] [message #131385 is a reply to message #131247] |
Fri, 07 May 2004 23:35 |
Originally posted by: gupolet.ulb.ac.be
I had the same problem but usually it was a loop that never stopped. Also,
I don't know what to do about that, but the paintFigure method is called
way too often and so eats all the ressources. So far, the only solution I
found was to put a sleep but it sure ain't great.
> > All,
> > it is this one.
> > Thanks,
> > Phil
Re: No more handles error [bug 53632] [message #131433 is a reply to message #131385] |
Sat, 08 May 2004 06:23 |
Originally posted by: alex.weirig.telewalfer.lu
I recently downloaded the Clay Database Modelling tool from Azzurri
(www.azzurri.jp). Once I installed this plugin into both Eclipse 2.1.3
and WSAD 5.1.1 and tried to create a new database model I got the "No
more handles" exception.
Since I tried this at the office, I use my regular userid. I then
tried to do the same with my Windows Administrator userid and
strangefully enough, everything worked just fine.
After I created a new database model and left the GEF based model
editor opened when closing Eclipse/WSAD, I was no longer able to
restart Eclipse/WSAD with my regular userid because of the No handles
exception.
So it looks like the code that is executed could require some special
access rights. If you work on your private PC you normally have all
the rights, but on a corporate PC, based on your corporate security
setting and constraints, your userid might not have all the necessary
access rights.
I have not been able to recreate the problem with my Administrator
user, but with my normal user I get the problem each and every time.
Maybe this can help tracking down what is happening.
Alex
PS: I'll be on holiday 'til next Thursday. So if I might not be able
to reply to a follow up question. I will do so on Thursday of at the
latest of Friday.
>>>All,
>>>it is this one.
>>>Thanks,
>>>Phil
Re: No more handles error [bug 53632] [message #131532 is a reply to message #131433] |
Mon, 10 May 2004 15:34 |
It could be another application which is associated with a specific account
is causing a side-effect.
"Alex Weirig" <alex.weirig@telewalfer.lu> wrote in message
news:c7htv9$28t$1@eclipse.org...
> Hello,
> exception.
> access rights.
> Alex
> latest of Friday.
Also,
I
bugzilla.
There
> >>>All,
that
that
> >>>it is this one.
> >>>Thanks,
> >>>Phil
Re: No more handles error [bug 53632] [message #131544 is a reply to message #131385] |
Mon, 10 May 2004 15:37 |
Which platform? What do you mean it is called too often?
"Guillaume" <gupolet@ulb.ac.be> wrote in message
news:c7h6gg$g9r$1@eclipse.org...
bugzilla.
There
> > > All,
that
happen
of
that
> > > it is this one.
> > > Thanks,
> > > Phil
Current Time: Sat Oct 19 06:28:50 GMT 2024
Powered by FUDForum. Page generated in 0.04051 seconds
