Home » Language IDEs » Java Development Tools (JDT) » Extensions/points and events/listeners, differences?
Extensions/points and events/listeners, differences? [message #131167] Sat, 03 January 2004 22:16 Go to next message
I am trying to figure out if there is any special handling through the
plugin.xml for a plugin to indicate it fires some user defined event it
provides and for other plugins to "tap into" listening for that event via
the plugin.xml file(s) they provide. In general, plugins are lazy created.
So if my plugin wants to fire an event that other plugins want to listen
for, how is that done? Do I provide an extension point and first create all
extensions, which each extension code of each plugin wanting to listen then
adds their listener? Or is there a more "automagic" manner in handling such
a common practice as this such that the eclipse plugin engine handles this
for me and I simply provide listener classes via plugin.xml extension
plugins?
Sorry if this is confusing, I am just trying to understand the correaltion
between extension points and extensions, and events and listeners. Is there
a specific difference when dealing with events and listeners? If I want my
"view" to fire off certain events, is the concept of events and listeners
null and void in Eclipse, replaced by the use of extensions and interfaces?
thanks.
Re: Extensions/points and events/listeners, differences? [message #131276 is a reply to message #131167] Mon, 05 January 2004 05:15 Go to previous messageGo to next message
>plugins?
>thanks.
The plug-in who contains a class that offers to add a listener and fire
events is declared as a required plug-in and then you can simply use the
API methods of that class to add the listener. There's nothing to be
done in XML except declaring the plug-in as required. For you as the
plug-in writer this means you simply have to provide the corresponding
API (via Java code).
Dani
Re: Extensions/points and events/listeners, differences? [message #131289 is a reply to message #131167] Mon, 05 January 2004 05:28 Go to previous messageGo to next message
Originally posted by: eostroukhov.hotmail.com
"spiderman" <supreme_java_guru_1@yahoo.com> wrote in message
news:bt80fs$blt$1@eclipse.org...
I believe, no.
all
then
such
> plugins?
There is no automated way to work with listener. In general, when you start
your plugin you should manually walk the extensions and add them as
listeners (i.e. instantiate classes or lookup initialized instances in some
well-defined places, etc.
there
interfaces?
Basically, extension points and extensions have nothing to do with
events/listeners. You declare places in your plugin where it could be
extended (extension point) and other plugins contribute some functionality
according to the rules you define (extension).
So, extension points and listeners are not mutually exclusive but
complimentary.
Eugene
Re: Extensions/points and events/listeners, differences? [message #131485 is a reply to message #131289] Mon, 05 January 2004 12:11 Go to previous messageGo to next message
Hi Eugene,
I almost agree with this, only that it seems when an extension point walks
its list of extensions, that is almost the same thing as an event being
fired, where the firing code walks the list of event listeners. The only
difference I see is if the use of the extension point walking the list is
done each time a "button" is pressed for example, or if the first time, the
extension point walks the list, gets a listener class from each and adds it
to some internal list of listeners, then from then on, the events are fired
like usual. Complimentary, possibly but really it seems that it's the same
thing. At some point, you are walking the list of extensions to add them as
listeners, so why even add them. Why not just walk the list of extensions
each time a button is pressed (assuming an extension point is referring to a
button it adds) and call the method of the interface each extension
implements? The ONLY difference I see in this manner is that with Swing,
events would go through the swing event thread, handled when they can be,
where as this way, walking the extensions, is basically sequential and in
the order the extensions are found.
"Eugene Ostroukhov" <eostroukhov@hotmail.com> wrote in message
news:btbe44$91u$1@eclipse.org...
via
> I believe, no.
> all
> then
> such
this
> > plugins?
start
some
correaltion
> there
my
listeners
> interfaces?
> complimentary.
> Eugene
Re: Extensions/points and events/listeners, differences? [message #131498 is a reply to message #131276] Mon, 05 January 2004 12:12 Go to previous messageGo to next message
When you use API methods of a required plugin, is that through an interface?
OR through a static ref to the plugin class, then making public method
calls? How is this API defined?
"Daniel Megert" <daniel.megert@gmx.net> wrote in message
news:btbdel$892$1@eclipse.org...
created.
all
then
such
this
> >plugins?
correaltion
there
my
interfaces?
> >thanks.
> Dani
Re: Extensions/points and events/listeners, differences? [message #131542 is a reply to message #131485] Mon, 05 January 2004 12:57 Go to previous messageGo to next message
Sorry, had another question on this issue. When you walk the extension list
I assume part of the "api" the extension point expects each extension to
provide is a classname of the listener that implements the listener type for
the event it wants to listen to (assuming an extension point were to define
its API in this way). The problem I see with this, or with ANY ability for
extensions to add event listeners, is that each extension plugin would have
to be created at startup in order to have their listener class instances
added to listen for events. This doesn't promote lazy creation of plugins
very well in my opinion. Is this how it is done? Or is there a way to
"delay" the creation of the plugin and it's listener class for each plugin
that extends the extension point until the event is first fired? Sort of
like a proxy event listener that handles the first event, then creates all
the extension listeners, adds their classes to the list, etc?
news:btc5qt$6kc$1@eclipse.org...
> Hi Eugene,
the
it
fired
as
a
it
> via
> > I believe, no.
listen
create
> > all
> > then
> > such
> this
> > > plugins?
> start
> some
> correaltion
> > there
want
> my
> listeners
> > interfaces?
functionality
> > complimentary.
> > Eugene
Re: Extensions/points and events/listeners, differences? [message #131577 is a reply to message #131498] Mon, 05 January 2004 13:16 Go to previous messageGo to next message
Yes, e.g. org.eclipse.ui.IPartListener but might also be a class, e.g.
org.eclipse.swt.widget.Control.
Dani
>created.
>all
>then
>such
>this
>>>plugins?
>correaltion
>there
>my
>interfaces?
>>>thanks.
>>Dani
Re: Extensions/points and events/listeners, differences? [message #131703 is a reply to message #131542] Tue, 06 January 2004 03:34 Go to previous messageGo to next message
I'm currently working with Eclipse 2.1.2 so I don't know for sure how
Eclipse 3.0 will work, but Eclipse 2.1.2 activates plugin when you need the
class for it i.e.:
IExtensionPoint extensionPoint =
plugin.getDescriptor().getExtensionPoint("storages"); // Extension
plugins are still inactive
List storageTypes =
new ArrayList(extensionPoint.getExtensions().length);
IExtension[] extensions = extensionPoint.getExtensions(); // Extension
for (int i = 0; i < extensions.length; i++) {
IConfigurationElement[] configurationElements =
extensions[i].getConfigurationElements(); // Extension plugins are
still inactive
for (int j = 0; j < configurationElements.length; j++) {
try {
storageTypes.add(
configurationElements[j].createExecutableExtension(
"storage-type")); // Only this call to createExecutable
extension activates the plugin that supplied the extension.
} catch (CoreException e) {
log.error("Failed to instantiate class", e);
return storageTypes;
So you can activate child plugins only when the first event that should be
fired to listener is triggered. No plugins will be be activated when the
plugin that supplied extension point is activated - you have pretty
fine-grained control over when to activate the "child" plugins. I.e.:
private List listeners = null;
private void fireMyEvent(MyEvent event) {
if (listeners == null) {
initializeListeners();
for (Iterator i = listeners.iterator(); i.hasNext(); ) {
((MyListener)i.next).onMyEvent(event);
private void initializeListeners() {
listeners = new ArrayList(...);
// Walk the extensions and add listeners.
In Eclipse 2.1.2 you don't have dynamic plugins so it's enough to check
extensions once.
So I cannot think of more lazy way to activate the child plugins. Or you
just want to avoid activating child plugins at all?
Eugene
news:btc8gm$9kv$1@eclipse.org...
list
for
define
have
Re: Extensions/points and events/listeners, differences? [message #131763 is a reply to message #131703] Tue, 06 January 2004 12:00 Go to previous messageGo to next message
Very good reply. I figured that is basically how it's done. First, I have to
ask if there is a utility class in Eclipse that does most of this work? It
seems EVERY extension point either has to walk it's list of extensions if
more than one can be called (i.e. an event listener case like you present),
or it has to use a preference to choose a specific extension to use, or in
the case of something like an email filter list of plugins, it make allow
the user to define the order in which they are called, if they are
active/inactive, etc.
Still, it seems pretty laborious to do this for each extension point. I
realize that it's different plugin developers usually writing the extension
points, but the same thing seems to apply in most cases.
Still, it answers my question on how listeners are added. I wasn't sure if
there was an automagic way of handling it, such that you wouldn't have to
walk the extension list, grab a listener class name and create it.
I take it the createExecutableExtension() is only to be used to create an
instance of a class within an extension plugin, correct? Is there any way
for an ExtensionPoint to define an interface AND implement it such that
extension plugins could get a ref to the implementation of the interface
from the extension point, and "control" the extension point. This is sort of
the reverse of how it works now, but I can see where such cases may be
useful. Or, is it better that an extension point define two interfaces. One
is the one extensions implement, the other is an implementation the
extension point implements and passes to each extension so that each
extension can make calls on the passed in implementation the extension point
sends. The only problem I see with this is classloader visibility. Each
extension plugin would have to have access to the extension point
classloader in order to see the class bytecode of the 2nd interface passed
to each extension plugin. Does that make sense? Is that possible now? How
would that be done?
news:btdrq5$sfe$1@eclipse.org...
the
> class for it i.e.:
> List storageTypes =
> still inactive
> try {
> storageTypes.add(
createExecutable
> extensions once.
> Best regards,
> Eugene
> list
> for
> define
for
> have
plugins
plugin
all
Re: Extensions/points and events/listeners, differences? [message #133284 is a reply to message #131763] Mon, 12 January 2004 03:22 Go to previous message
news:btephn$1jf$1@eclipse.org...
to
present),
I don't know of such plugin - but it's really easy to create a utility that
will take name of the extension point and class name attribute and will
return collection of the extensions. I haven't found such utility in the
org.eclipse.core.runtime package.
of
One
point
> would that be done?
As far as I understood you are asking if the plugin that declares extension
point can also provide some interface, so the reference to its
implementation can be obtained by the extension plugin and some methods are
called - right? Extension plugin (the one that contributes tio the extension
point) must declare dependency on a plugin that declares extension point -
so it has access to all classes that are exported by that plugin. You can
instantiate classes, use static methods, so on - you use a lot of classes
from the eclipse teams' plugins when you write your plugin.
Eugene
Previous Topic:Which Should I use 2.1 vs 3.0M6?
Next Topic:two editor views on the same file ?
Current Time: Fri Oct 31 05:19:34 EDT 2025
Powered by FUDForum. Page generated in 0.10687 seconds
