Gray polyline connections [message #130293] |
Mon, 03 May 2004 21:28 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: Alexander.Eiken.post.rwth-aachen.de
I developed an editor with different types of connections between some
nodes. Each connection type should be displayed in a different color.
The problem is that all polyline connections are drawn in the same gray
color even though I set a different foreground color. The decorations of
these connections are displayed in the right color.
Any ideas what could cause this problem?
Thanks, Alexander.
Re: Gray polyline connections [message #130332 is a reply to message #130293] |
Tue, 04 May 2004 06:34 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: brian.fernandes.codito.com
Hi Alexander,
have a look at a previous thread - "Connections with different Colors" dated
20/01/2004.
All the best,
Brian.
"Alexander Eiken" <Alexander.Eiken@post.rwth-aachen.de> wrote in message
news:c76d3d$s8q$1@eclipse.org...
> Hello,
> Thanks, Alexander.
Re: Gray polyline connections [message #130631 is a reply to message #130293] |
Tue, 04 May 2004 20:11 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Maybe you are setting the foreground color more than once?
> Hello,
> Thanks, Alexander.
Re: Gray polyline connections [message #130720 is a reply to message #130631] |
Wed, 05 May 2004 09:19 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Randy,
I did set the foreground color more than once, but this isn't the
problem. I have the same strange problem with ellipse figures...
>>Hello,
>>Thanks, Alexander.
FUDForum. Page generated in 0.03698 seconds
