Home » Archived » Visual Editor (VE) » AWT/Swing application
AWT/Swing application [message #130048] Thu, 17 August 2006 17:55 Go to next message
Is there a simple VE compatible example AWT/Swing application with a
menu bar containing File, Edit and Help menus and the File menu
containing Open and SaveAs menuItems utilizing fileFinder available for
download?
Thank you
Norwood Sisson
Re: AWT/Swing application [message #130074 is a reply to message #130048] Thu, 17 August 2006 18:09 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
No there isn't one, but you can use New->Examples->Swing->Slider Game to
have an example of a JFrame with a menu bar.
> download?
> Thank you
> Norwood Sisson
Rich Kulp
Re: AWT/Swing application [message #130098 is a reply to message #130074] Thu, 17 August 2006 18:15 Go to previous messageGo to next message
Opps, my bad! We do have an example. It is just that is an application
containing a JFrame, not just a JFrame by itself.
Use New->Other->Java->Visual class, then from the wizard select the
styles Swing->Application.
Rich Kulp
Re: AWT/Swing application [message #130135 is a reply to message #130098] Fri, 18 August 2006 00:24 Go to previous message
thanks
Norwood Sisson
Re: AWT/Swing application [message #614552 is a reply to message #130048] Thu, 17 August 2006 18:09 Go to previous message
> download?
> Thank you
> Norwood Sisson
Rich Kulp
Re: AWT/Swing application [message #614554 is a reply to message #130074] Thu, 17 August 2006 18:15 Go to previous message
Rich Kulp
Re: AWT/Swing application [message #614557 is a reply to message #130098] Fri, 18 August 2006 00:24 Go to previous message
thanks
Norwood Sisson
Previous Topic:SWT GridLayout and Performance Issue
Next Topic:How to edit JFace in VE
Current Time: Wed Apr 23 23:11:25 EDT 2025
Powered by FUDForum. Page generated in 0.03006 seconds
