Home » Archived » Tigerstripe » Problems uploading TS 0.4 into Ganymede with update site
Problems uploading TS 0.4 into Ganymede with update site [message #11896] Sat, 11 October 2008 11:37 Go to next message
I have a problem with the provided update site
http://download.eclipse.org/technology/tigerstripe/updates/s ite.xml
I started from a fresh install of Ganymede.
Added the site in the Help - Software Updates - Add Site..
I get two entries in Available Software:
- http://download.eclipse.org/technology/tigerstripe/updates/s ite.xml
with following packages
- http://download.eclipse.org/technology/tigerstripe/site.xml
The latter always generate this error:
No repository found at
http://download.eclipse.org/technology/tigerstripe/site.xml.
Install from the above I get the following installed software:
-Tigerstripe Annotation Framework (Incubation) 0.3.0
- Tigerstripe Core (Incubation) 0.3.0
These are not the M0.4. Did I miss something ? Is the update working with
the latest Milestone packages?
Jerome
Re: Problems uploading TS 0.4 into Ganymede with update site [message #12892 is a reply to message #11896] Mon, 13 October 2008 16:07 Go to previous messageGo to next message
Hi Jerome,
Did you install all the dependencies required by Tigerstripe? EMF, GMF,
etc...
We keep a bundle with all of them handy at
http://www.eclipse.org/downloads/download.php?file=/technolo gy/tigerstripe/
tigerstripe-required-0.4.zip
You will need to unzip this on top of your fresh version of Ganymede.
I am guessing that once all the dependencies are resolved, the update site
will work.
Another option is to download the bundle-tigerstripe-workbench-....zip from
the downloads page which will contain the TS stuff + all the required
plugins. From then on, you will be able to run simple updates.
Let me know how this goes.
Eric
On 10/11/08 8:37 AM, in article gcqh6u$7p3$1@build.eclipse.org, "Jerome
> Jerome
Re: Problems uploading TS 0.4 into Ganymede with update site [message #12908 is a reply to message #12892] Thu, 16 October 2008 07:54 Go to previous message
Hi Eric,
No I thought the update manager would resolve the dependencies.
Anyway, I decided to go with the other approach. Extracting the ZIP into my
eclipse folder.
Still the error message "No repository found in <URL>" is misleading.
I thought something else was not working.
Wow what I nice new theme look to Tigerstripe!
Jerome
Re: Problems uploading TS 0.4 into Ganymede with update site [message #563790 is a reply to message #11896] Mon, 13 October 2008 16:07 Go to previous message
Hi Jerome,
etc...
will work.
Eric
> Jerome
Re: Problems uploading TS 0.4 into Ganymede with update site [message #563808 is a reply to message #12892] Thu, 16 October 2008 07:54 Go to previous message
Hi Eric,
eclipse folder.
Jerome
Previous Topic:Problems uploading TS 0.4 into Ganymede with update site
Next Topic:Importing a UML 2.1 file & profile
Current Time: Wed Apr 16 09:12:47 EDT 2025
Powered by FUDForum. Page generated in 0.04018 seconds
