Home » Archived » BIRT » BIRT 2.0.0 Preview problem
BIRT 2.0.0 Preview problem [message #130008] Tue, 14 February 2006 05:06
Hi all,
In open method of the script file I try to open a shell window as follow:
ownFields=["OMXEnvCd"];
fields=["OMXEnvCd","OMXAppCd"];
new
Packages.nl.remain.mx.birt.dynamicFields.OMXDynamicFields(fi elds,ownFields, "OMXEnvironment",null);
When I try to peview this script file I get the following error:
Error0 : Error.ScriptEvaluationError ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: There are
errors evaluating script "c=0;
new
Packages.nl.remain.mx.birt.dynamicFields.OMXDynamicFields(fi elds,ownFields, "OMXEnvironment",null);".
org.eclipse.birt.report.engine.script.internal.DtEScriptExec utor.handleJS(DtEScriptExecutor.java:76)
org.eclipse.birt.report.engine.script.internal.DataSetScript Executor.handleJS(DataSetScriptExecutor.java:159)
org.eclipse.birt.report.engine.script.internal.ScriptDataSet ScriptExecutor.handleOpen(ScriptDataSetScriptExecutor.java:6 6)
org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.open( ScriptDataSetRuntime.java:68)
org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor$CustomDataSet.open(PreparedScriptDSQuery.j ava:204)
org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor.executeOdiQuery(PreparedScriptDSQuery.java :180)
org.eclipse.birt.data.engine.impl.PreparedQuery$Executor.exe cute(PreparedQuery.java:711)
org.eclipse.birt.data.engine.impl.QueryResults.getResultIter ator(QueryResults.java:110)
org.eclipse.birt.report.engine.data.dte.DteDataEngine.execut e(DteDataEngine.java:210)
org.eclipse.birt.report.engine.executor.QueryItemExecutor.op enResultSet(QueryItemExecutor.java:62)
org.eclipse.birt.report.engine.executor.TableItemExecutor.ex ecute(TableItemExecutor.java:122)
org.eclipse.birt.report.engine.executor.ReportExecutorVisito r.visitTableItem(ReportExecutorVisitor.java:187)
org.eclipse.birt.report.engine.ir.TableItemDesign.accept(Tab leItemDesign.java:69)
org.eclipse.birt.report.engine.executor.ReportExecutor.execu te(ReportExecutor.java:125)
org.eclipse.birt.report.engine.executor.ReportExecutor.execu te(ReportExecutor.java:89)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:175)
org.eclipse.birt.report.services.ReportEngineService.runAndR enderReport(Unknown
Source)
org.eclipse.birt.report.viewer.aggregation.layout.EngineFrag ment.doService(Unknown
Source)
org.eclipse.birt.report.viewer.aggregation.BaseFragment.serv ice(Unknown
Source)
at org.eclipse.birt.report.viewer.servlet.ViewerServlet.doGet(U nknown
Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:740)
org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:247)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:193)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:256)
org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:643)
org.apache.catalina.core.StandardPipeline.invoke(StandardPip eline.java:480)
at org.apache.catalina.core.ContainerBase.invoke(ContainerBase. java:995)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191)
org.apache.catalina.valves.CertificatesValve.invoke(Certific atesValve.java:246)
org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:641)
org.apache.catalina.core.StandardContext.invoke(StandardCont ext.java:2422)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:180)
org.apache.catalina.valves.ErrorDispatcherValve.invoke(Error DispatcherValve.java:171)
org.eclipse.tomcat.internal.EclipseErrorReportValve.invoke(E clipseErrorReportValve.java:153)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:174)
at org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapte r.java:199)
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:828)
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.processConnection(Http11Protocol.java:700)
org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndp oint.java:584)
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:683)
at java.lang.Thread.run(Thread.java:534)
Caused by: org.eclipse.birt.data.engine.core.DataException: A BIRT
exception occurred: Error evaluating Javascript expression. Script engine
error: Wrapped org.eclipse.swt.SWTException: Invalid thread access
(DataSet[Data Set].__bm_OPEN#5)
Script source: DataSet[Data Set].__bm_OPEN, line: 1, text:
__bm_OPEN(). See next exception for more information.
Error evaluating Javascript expression. Script engine error: Wrapped
org.eclipse.swt.SWTException: Invalid thread access (DataSet[Data
Set].__bm_OPEN#5)
__bm_OPEN()
org.eclipse.birt.data.engine.core.DataException.wrap(DataExc eption.java:113)
org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJ SAsExpr(ScriptEvalUtil.java:531)
org.eclipse.birt.data.engine.script.JSMethodRunner.runScript (JSMethodRunner.java:79)
org.eclipse.birt.report.engine.script.internal.DtEScriptExec utor.handleJS(DtEScriptExecutor.java:71)
... 53 more
Caused by: org.eclipse.birt.core.exception.CoreException: Error evaluating
Set].__bm_OPEN#5)
__bm_OPEN()
org.eclipse.birt.core.script.JavascriptEvalUtil.wrapRhinoExc eption(JavascriptEvalUtil.java:220)
org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateScri pt(JavascriptEvalUtil.java:93)
org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJ SAsExpr(ScriptEvalUtil.java:527)
... 55 more
Caused by: org.mozilla.javascript.WrappedException: Wrapped
Set].__bm_OPEN#5)
org.mozilla.javascript.Context.throwAsScriptRuntimeEx(Contex t.java:1776)
at org.mozilla.javascript.MemberBox.newInstance(MemberBox.java: 210)
org.mozilla.javascript.NativeJavaClass.constructSpecific(Nat iveJavaClass.java:226)
org.mozilla.javascript.NativeJavaClass.construct(NativeJavaC lass.java:182)
at org.mozilla.javascript.ScriptRuntime.newObject(ScriptRuntime .java:2060)
at org.mozilla.javascript.gen.c107._c1(DataSet[Data Set].__bm_OPEN:5)
at org.mozilla.javascript.gen.c107.call(DataSet[Data Set].__bm_OPEN)
org.mozilla.javascript.optimizer.OptRuntime.callName0(OptRun time.java:105)
at org.mozilla.javascript.gen.c8._c0(DataSet[DataSet].__bm_OPEN :1)
at org.mozilla.javascript.gen.c8.call(DataSet[DataSet].__bm_OPE N)
org.mozilla.javascript.ContextFactory.doTopCall(ContextFacto ry.java:304)
at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime .java:2769)
at org.mozilla.javascript.gen.c8.exec(DataSet[DataSet].__bm_OPE N)
org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateScri pt(JavascriptEvalUtil.java:86)
... 56 more
Caused by: org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.SWT.error(SWT.java:2865)
at org.eclipse.swt.SWT.error(SWT.java:2836)
at org.eclipse.swt.widgets.Widget.error(Widget.java:395)
at org.eclipse.swt.widgets.Shell.<init>(Shell.java:246)
at org.eclipse.swt.widgets.Shell.<init>(Shell.java:237)
at org.eclipse.swt.widgets.Shell.<init>(Shell.java:190)
at org.eclipse.swt.widgets.Shell.<init>(Shell.java:128)
nl.remain.mx.birt.dynamicFields.OMXDynamicFields.<init>(OMXDynamicFields.java:63)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAccessorImpl.java:39)
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:2 74)
at org.mozilla.javascript.MemberBox.newInstance(MemberBox.java: 200)
... 69 more
Any idea what going here wrong?
Said
Previous Topic:ChartReportItemUIImpl (reportitem was unable to load ChartReportItemUIImpl)
Next Topic:Plz con: BIRT_VIEWER_REPORT_ROOT
Current Time: Fri Apr 25 02:06:38 EDT 2025
Powered by FUDForum. Page generated in 0.02713 seconds
