Re: Code generation from ant or maven [message #620339 is a reply to message #130050] |
Wed, 08 October 2008 10:38 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Ed Merks![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ed.merks%40gmail.com) Messages: 33196 Registered: July 2009 |
Pavel,
The description, if I recall correctly, is where the physical location
of the project is being specified. It sounds like there's a problem
with that in your case. You run this under debug control to see that's
happening. I.e., what specific value doesn't it like?
Pavel Bernshtam wrote:
> Thank you and sorry for asking a trivial question.
> I try to use both build.xml example (with antRunner application) or
> codeGen.cmd script from an example.
> However in both cases I receive "Invalid project description" error.
> What may be a reason?
> I receive this error even if I use the .project file from examples ..
> Thank you
Ed Merks
FUDForum. Page generated in 0.04862 seconds
