EclipseWTP + JBoss: JSP changes [message #129955] |
Thu, 04 August 2005 23:53 |
Originally posted by: no.thank.you
I've seen very vague answers to similar posts elsewhere so I'll post here in
hopes of getting a clearer answer.
EclipseWTP0.7
JBoss4.0.3RC1
JDK1.5
Everything set up properly the best I can tell.
Created a dynamic web project with a simple test.jsp. Run on server
publishes, starts server, launches browser and displays page. Good but...
I see no sane way of changing the jsp and seeing the result in a browser. It
continues to use the original version. I've tried stopping the server and
republishing, then restarting...no effect. I've cleaned the project and
rebuilt, etc, etc, with no effect.
JBoss's server\default\deploy folder has my test.war which has the correct
jsp content.
The work\jboss.web\localhost\test folder (which I assume gets sent to the
browser) contains the original version. If I stop the server, delete this
folder, clean and rebuild project, and run on server I get the updated
version. INSANE!
There must be a better way and if there's not, this is a problem. Eclipse
with Tomcat was easy to work with, JBoss should be too.
If anyone can clearly describe the proper way to edit JSP's, please let me
know. If you have a snide comment such as "Have I mentioned scripts", please
keep them to yourself.
I've seen several questions posted with people having the same issue. Please
enlighten us all.
Craig Foote
p.s. please post reply, I did not provide my email address.
FUDForum. Page generated in 0.02564 seconds
