Home » Language IDEs » Java Development Tools (JDT) » CVS and Eclipse - Removing Files?
CVS and Eclipse - Removing Files? [message #129701] Wed, 24 December 2003 07:21 Go to next message
Originally posted by: brant.hahn.insightbb.com
Hi guys,
Is there an easy way to do a 'cvs remove' within Eclipse? There doesn't
seem to be any options for it under the Team subcontext menu. Right now,
I've been doing it straight from the command line, which is fine, but I
thought they would provide that somwhere in Eclipse. I'm using version
2.1.2, if that helps any.
Brant
Re: CVS and Eclipse - Removing Files? [message #129845 is a reply to message #129701] Wed, 24 December 2003 19:30 Go to previous messageGo to next message
Just delete the file in Eclipse (right-click -> Delete). Next time you
synchronize with the repository (right-click -> Team -> Synchronize) it
will do a CVS delete on the files you've deleted in Eclipse.
(This is in 3.0m6, but I'm pretty sure 2.1.x work the same way.)
-- Laura
Re: CVS and Eclipse - Removing Files? [message #134524 is a reply to message #129845] Wed, 14 January 2004 07:41 Go to previous messageGo to next message
Originally posted by: heger.geomi.com
i can confirm that this works in 2.2
nik
"Laura Werner" <laura@lwerner.org> wrote in message
news:bsdb1k$v22$1@eclipse.org...
> -- Laura
Re: CVS and Eclipse - Removing Files? [message #134786 is a reply to message #134524] Wed, 14 January 2004 18:28 Go to previous message
Originally posted by: smesh.openrules.com
confirm for 2.1.X
Previous Topic:classpathentry kind="src" means?
Next Topic:go back to Java Perspective after Debug
Current Time: Wed Apr 16 04:14:47 EDT 2025
Powered by FUDForum. Page generated in 0.05198 seconds
