| Home » Newcomers » Newcomers » Can't Specify Build Directory
 Goto Forum:|
| Can't Specify Build Directory [message #129395] | Thu, 12 January 2006 15:15  |  |
| Eclipse User  |  |  |  |  | Originally posted by: anon.anon.org
 Hello all,
 I'm a newcomer to Eclipse and am trying to import an existing java project
 in CVS with an ant build file.  I've created the project, however I can't
 find the proper way to specify where I want the build output to go.  The ant
 buildfile requires a variable "BUILDDIR" to be set, but I can't find the
 proper place in the IDE to add this environment variable to the project.
 I've tried a couple of different things, but then when I specify a directory
 not in my workspace, the compilation fails with "directory is not in the
 project."  I'm totally confused.  Why do you have to explicitly add a target
 directory to a project and how do I go about doing this?  I can't find
 anything in the IDE to give me a clue.
 Shane
| Re: Can't Specify Build Directory [message #129927 is a reply to message #129395] | Mon, 16 January 2006 13:34   |  |
| Eclipse User  |  |  |  |  | Originally posted by: eclipse3.rizzoweb.com
 Shane Fisher wrote:
 > Hello all,
 Do you want to let Eclipse do the building (at least the parts that it
 is capable of doing), or do you want to continue to use only you Ant
 script to do the build?
 I highly recommend setting it up so that Eclipse does its part
 (compiling and copying non-source files into the build output location)
 as that will give you the most value from what Eclipse has to offer. In
 that case, you specify things like source directories, dependent
 libraries, and build output locations by right-clicking on the Project
 and choose Properties.
 I also STRONGLY recommend opening the Help and going through the Getting
 Started guides for Java Development and Workbench - understanding those
 topics will save you a LOT of time as you get used to the tool.
 HTH,
 Eric
| Re: Can't Specify Build Directory [message #130196 is a reply to message #129927] | Tue, 17 January 2006 15:07   |  |
 Eric,
 Thanks for the suggestion, however we have a large development team with a
 build team that requires command-line automation via the ant script.  Is
 there no way to specify the required variables in a way that Eclipse can
 understand and utilize so they can share the same ant script?  It seems the
 IDE should integrate with the automated build in a seamless fashion, simply
 by specifying the required env variables in the project file.  Am I
 misunderstanding the tool?  I recall doing similar things with the JBuilder
 IDE on a previous project.
 Thanks again,
 Shane
 "Eric Rizzo" <eclipse3@rizzoweb.com> wrote in message
 news:dqgp0i$tqi$1@utils.eclipse.org...
 > Shane Fisher wrote:
 > > Hello all,
 project
 can't
 ant
 directory
 target
 > HTH,
 > Eric
| Re: Can't Specify Build Directory [message #130525 is a reply to message #130196] | Wed, 18 January 2006 18:52  |  |
 Shane Fisher wrote:
 > Eric,
 First, don't make the mistake of comparing Eclipse to JBuilder - it is a
 very different colored horse and you'll only frustrate yourself by
 trying to think of them as equivalent or even similar. :-)
 Now, about your question: it is certainly possible (and desirable) to
 have an "automatable" Ant build script that is used for "official"
 builds, and still let Eclipse do it's part during development. The key
 is to configure your Eclipse project to build into the same output
 location that the Ant script builds into. That way Eclipse gets to use
 its very intelligent Java compilation and processing tools to provide a
 rich dev environment, but you still always have the "official" Ant
 script to fall back on. One key here is to have a "clean" target that
 you can invoke easily from within Eclipse when you want to toss out the
 build work Eclipse did and use the Ant script instead.
 Once configured that way, you have two directions to choose between for
 invoking the parts of the build that Eclipse can't handle (perhaps code
 generation, complex/intricate file copying, JAR production, remote
 deployment, etc.) One choice is to just use the Ant view to manually
 invoke the Ant script when you need it. This is how I have set up a lot
 of projects. Most of the build work that is used many times per day can
 be accomplished by Eclipse, but there are some Ant targets that I need
 to invoke occasionally to keep the dev build up to date. (Eclipse's
 advanced source path and output location configuration features can help
 here).
 The other alternative is to set up a builder for your project that will
 get invoked every time a build is triggered in Eclipse (it can be set up
 to run before/after the Eclipse build/compile). By default, Eclipse will
 build every time you save a file that is on the project's source path,
 so doing this with an Ant target that takes a long time is not a great
 idea - you'll find yourself constantly waiting for the Ant script to run
 on every file save! Where this works well is when the Ant target you
 need to run must run upon all (or at least most) source file changes,
 and/or it does not take more than a couple of seconds.
 [In any case, the Ant script must be maintained and used exclusively for
 those pesky "official" builds :-). But that is no big deal, and you
 should be doing "official" builds on a non-dev clean machine anyway, so
 Eclipse would have no impact there.]
 Either way, this is how I've worked with Eclipse for several yeas now on
 projects of various sizes - it has served me well.
 HTH,
 Eric
 Current Time: Fri Oct 31 13:40:00 EDT 2025
 Powered by FUDForum . Page generated in 0.08936 seconds |
