Home » Eclipse Projects » GEF » PropertySource vs Adapter beginner question
PropertySource vs Adapter beginner question [message #129332] Wed, 28 April 2004 12:11 Go to next message
hello,
i am just starting out with GEF. i am creating a diagram as an editor
using the GraphicalEditor. i want to have the elements on the screen
exposed on the Properties View. i see two slightly different ways to do
this:
1) have your model implement IAdaptable and call off to a IPropertySource
2) have your model implement IPropertySource
the logic example seems to use the (2) case and the example at eclipse.org
uses the (1) case. i decided to use the (1) case because i had started
down that road from reading the example, and all works very well.
my question is more about what is happening under the covers, because i
eventually want to use my own EditorPart and not the GraphicalEditor. why
does the model have the handle to the property sheet information, it seems
to clutter the model? how is the model geting called to update the
property sheet? does anyone have an example of using a model with a
custom GraphicalEditor?
BTW - to the people who developed the GEF framework. it is very
impressive and very comprehensive.
thanks,
steve
Re: PropertySource vs Adapter beginner question [message #129602 is a reply to message #129332] Wed, 28 April 2004 18:35 Go to previous message
Originally posted by: chris.gaudi.freeserve.co.uk
I have just been doing something similar and asking myself the same
question.
It seems the abstract graphical viewer implements ISelectionProvider (which
provides the selection object(s) to Eclipse - and hence the property sheet).
The selection is the selected EditPart(s) - which implements IAdaptable and
delegate (if possible) to the model object to provide for IPropertySource or
IAdaptable (which in turn means the model can provide an IPropertySource
adapter) [see source code for AbstractEditPart#getAdapter()].
If you don't like "polluting" the model with IPropertySource methods then
implement IAdaptable and provide another class to do the IPropertySource
methods. Personally I can live with the model implementing IPropertySource,
as I am normally editing the properties of the model object.
The proprty sheet uses the methods of IPropertySource (such as
getPropertyDescriptors and getPropertyValue(Object propID)) to populate the
sheet.
- Chris
"Steven Melzer" <smelzer@paymentech.com> wrote in message
news:c6ol3t$iet$1@eclipse.org...
> hello,
> this:
> thanks,
> steve
Previous Topic:missing org.eclipse.gef.rulers package
Next Topic:connection drawing problem
Current Time: Sun Oct 19 03:31:55 EDT 2025
Powered by FUDForum. Page generated in 0.05055 seconds
