Logic Gates Example [message #129186] |
Tue, 27 April 2004 18:45 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: rbhatna.clemson.edu
This is regarding the Logic gates example. I created a project and
compiled the source and exported the jar to the plugins directory
repalcing the original jar to see if the example would run. it didnt.
upon inspections of the two JAR files i foudn that the original jar
contains
org.eclipse.gef.examples.logicdesigner.model.icons
org.eclipse.gef.examples.logicdesigner.figure.icons
org.eclipse.gef.examples.logicdesigner.icons
each of these contain a bunch of icons.The JAR created by me on
compilation does not contains these folders and I am stumped as to where
they could have come from . The source which came with the example did NOT
contain these folders.
Could someone advise.
many thanks
Rahul
Re: Logic Gates Example [message #129199 is a reply to message #129186] |
Tue, 27 April 2004 20:18 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
What are you trying to accomplish?
"Rahul Bhatnagar" <rbhatna@clemson.edu> wrote in message
news:c6m9nd$sja$1@eclipse.org...
> contains
> many thanks
> Rahul
Re: Logic Gates Example [message #129211 is a reply to message #129199] |
Tue, 27 April 2004 20:00 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
My ultimate aim is to create my own palette and replace the constituents
of the current palette with my own symbols. This would be used a graphical
representaton as part of my research.
For now I am trying to compile the source and run the program so that I
can then proceed to incrementally make changes and export the JAR file .
> > contains
> > many thanks
> > Rahul
Re: Logic Gates Example [message #129224 is a reply to message #129211] |
Tue, 27 April 2004 21:14 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
If you don't mind using the current version, you could try downloading the
source from CVS - simply grab the gef.examples.logic package. This would
create the project for you, with all the necessary pieces.
news:c6me51$26g$1@eclipse.org...
> > > contains
where
NOT
> > > many thanks
> > > Rahul
Re: Logic Gates Example [message #129386 is a reply to message #129224] |
Wed, 28 April 2004 19:02 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I downloaded the source from CVS and have included all the necessary
external JARS. On compiling the source I get an error such that the
package org.eclipse.gef.rulers cannot be resolved.
I have already included org.eclipse.gef. Shouldnt org.eclipse.gef.rulers
be packaged inside the gef package?
Any Ideas?
> > > > contains
> where
> NOT
> > > > many thanks
> > > > Rahul
Re: Logic Gates Example [message #129399 is a reply to message #129224] |
Any Ideas?
> > > > contains
> where
> NOT
> > > > many thanks
> > > > Rahul
Re: Logic Gates Example [message #129931 is a reply to message #129186] |
Thu, 29 April 2004 22:11 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
You should use the Import->External plug-ins wizard to import the logic
source. One of the options is to import the plug-in as source vs. binary.
The default is binary, I think. If you change this choice, everything
should compile.
> contains
> many thanks
> Rahul
FUDForum. Page generated in 0.04476 seconds
