Home » Eclipse Projects » Equinox » "No repository found..." errors for packages not being updated?
"No repository found..." errors for packages not being updated? [message #128702] Mon, 06 April 2009 14:37
I'm getting update failures where the error messages identify components
that aren't being updated. I've been seeing these messages off and on
for months, and the specific components listed change from one attempt
to the next. The error always occurs AFTER the requested updates have
been downloaded. See below for samples -- in both cases I was trying
to update a single component, PyDev.
Sometimes restarting Eclipse cures the problem, sometimes it doesn't.
Any suggestions?
Run at 11:20 today:
An error occurred while collecting items to be installed
No repository found containing:
org.eclipse.datatools.enablement.ibm.db2.iseries/osgi.bundle /1.0.0.v200805152355
org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinitio n/osgi.bundle/1.0.0.v200806100223
org.eclipse.datatools.enablement.ibm.db2.luw/osgi.bundle/1.0 .0.v200805152355
org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition/os gi.bundle/1.0.0.v200805152355
org.eclipse.datatools.enablement.ibm.db2.zseries/osgi.bundle /1.0.0.v200805152355
org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinitio n/osgi.bundle/1.0.0.v200805152355
org.eclipse.datatools.enablement.ibm.feature/org.eclipse.upd ate.feature/1.6.1.v200809191145-7D43EB7sQS9RbiYgHAa
org.eclipse.datatools.enablement.ibm.informix.dbdefinition/o sgi.bundle/1.0.1.v200807170829
org.eclipse.datatools.enablement.sap.feature/org.eclipse.upd ate.feature/1.6.1.v200809191145-440_kE77c7QAQEIQQ
org.eclipse.datatools.enablement.sybase.asa/osgi.bundle/1.0. 1.v200805310538
org.eclipse.datatools.enablement.sybase.ase/osgi.bundle/1.0. 1.v200807010411
org.eclipse.datatools.enablement.sybase.feature/org.eclipse. update.feature/1.6.1.v200809191145-7A-5E9IgKLhLGetRuu9
org.eclipse.datatools.enablement.sybase.ui/osgi.bundle/1.0.0 .v200808221518
org.eclipse.datatools.sqldevtools.data.feature/org.eclipse.u pdate.feature/1.6.1.v200809191145-30-9oA55S5SBG5ND5
org.eclipse.datatools.sqltools.data.core/osgi.bundle/1.0.0.v 200808260630
org.eclipse.datatools.sqltools.data.ui/osgi.bundle/1.1.0.v20 0808260630
org.eclipse.datatools.sqltools.tabledataeditor/osgi.bundle/1 .0.0.v200808300730
The same update run at 12:30 today:
org.eclipse.datatools.enablement.jdt.classpath/osgi.bundle/1 .0.1.v200805152355
org.eclipse.datatools.enablement.jdt.feature/org.eclipse.upd ate.feature/1.6.1.v200809191145-1-07w311916263466
org.eclipse.datatools.enablement.msft.feature/org.eclipse.up date.feature/1.6.1.v200809191145-442_kE77c7VBQDFNW
org.eclipse.datatools.enablement.mysql/osgi.bundle/1.0.1.v20 0808261158
org.eclipse.datatools.enablement.mysql.dbdefinition/osgi.bun dle/1.0.1.v200805170742
org.eclipse.datatools.enablement.mysql.feature/org.eclipse.u pdate.feature/1.6.1.v200809191145-442_kE77c7TBTBKPQ
org.eclipse.datatools.enablement.oda.feature/org.eclipse.upd ate.feature/1.6.1.v200809191145-797P6CYQCD4CvIcEeNW
org.eclipse.datatools.enablement.oda.ws/osgi.bundle/1.1.1.v2 00808211640
org.eclipse.datatools.enablement.oda.xml/osgi.bundle/1.1.1.v 200808261409
org.eclipse.datatools.enablement.oracle.dbdefinition/osgi.bu ndle/1.0.1.v200808021450
org.eclipse.datatools.enablement.oracle.feature/org.eclipse. update.feature/1.6.1.v200809191145-442_kE77c7UAOBJML
org.eclipse.datatools.enablement.postgresql.dbdefinition/osg i.bundle/1.0.0.v200805152355
org.eclipse.datatools.enablement.postgresql.feature/org.ecli pse.update.feature/1.6.1.v200809191145-441_kE77c7R_RCIOP
Previous Topic:Jboss inside RCP = java.net.MalformedURLException
Next Topic:[P2] Problems with Equinox p2 director application
Current Time: Tue Apr 29 01:37:54 EDT 2025
Powered by FUDForum. Page generated in 0.28658 seconds
