Running abbot tests with TPTP [message #128281] |
Wed, 09 April 2008 20:46 |
Originally posted by: tianshangdeniao.hotmail.com
I am new to TPTP and trying to runing a abbot tests in the TPTP
framework by "Import-> JUnit Tests to TPTP". When I run the tests I get
the following error.
org.osgi.framework.BundleException: The bundle could not be resolved.
Reason:
Missing Constraint: Require-Bundle: com.gerhardtinformatics.rcprobot;
bundle-version="0.0.0"
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:305)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:265)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:257)
org.eclipse.tptp.test.tools.junit.plugin.runner.BundleSet.st art(BundleSet.java:113)
org.eclipse.tptp.test.tools.junit.plugin.runner.BundleSet.in stallAndStart(BundleSet.java:151)
org.eclipse.tptp.test.tools.junit.plugin.runner.EclipseTeste rAgent.launchTest(EclipseTesterAgent.java:134)
org.eclipse.tptp.test.tools.junit.plugin.runner.EclipseTeste rAgent.doHandleCommand(EclipseTesterAgent.java:119)
org.eclipse.tptp.test.tools.junit.plugin.runner.EclipseTeste rAgent.startProcessing(EclipseTesterAgent.java:68)
org.eclipse.tptp.test.tools.junit.plugin.runner.ui.PluginTes tHarness$1.run(PluginTestHarness.java:50)
org.eclipse.tptp.test.tools.junit.plugin.runner.ui.PluginTes tHarness.runTests(PluginTestHarness.java:56)
org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(Work benchTestable.java:68)
at java.lang.Thread.run(Thread.java:619)
Also I tried writing the tests manuals through TPTP, and but the tests
returns with a "java.lang.NoClassDefFoundError" in the results and does
not seem to be loading the classes from the import statement of the .java
files.
Any suggestion? Thanks in advance,
Ivan
FUDForum. Page generated in 4.71668 seconds
