Home » Eclipse Projects » Equinox » [DS] Why is it necessary to activate bundles offering services?
Re: [DS] Why is it necessary to activate bundles offering services? [message #127953 is a reply to message #127934] |
Thu, 26 March 2009 15:38 |
Victor Roldan Betancort Messages: 524 Registered: July 2009 |
Chris,
thanks for your feedback. From intuition I thought DS register something
like a "proxy" to a service, so as soon the service is demanded, the
bundle gets activated and the proxy is resolved. I read the OSGi spec
for DS but couldn't clarify this issue. Only when I looked at the code
and saw (if bundle.getState() == Bundle.ACTIVE)...
I guess the implementation of R4.2 is not included in latest (HEAD)
org.eclipse.equinox.ds, right?
Cheers
Víctor.
Chris Aniszczyk escribió:
> Víctor Roldán Betancort wrote:
>> Hi everyone,
>> I've been lately experimenting with Declarative Services and faced and
>> issue I don't quite understand. Apparently, we need to activate
>> bundles offering services if we want org.eclipse.equinox.ds to
>> register it to the service registry. I don't exactly see the point of
>> this. Wasn't declarative services all about lazy registration? What's
>> the concept of delayed service for then? Am I missing something here?
> The lifecycle of the service registry and the extension registry are
> different. Services are only available when the bundle is in the ACTIVE
> state. Extensions are available in the RESOLVED state.
> In the R4.2 version of DS, DS allows to look for bundles in the STARTING
> state (lazy activation). Therefore, you can add:
> Bundle-ActivationPolicy: lazy
> Once you do that, DS should be able to work the way you expect it... as
> long as DS is started of course!
> Cheers,
> Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
> http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: [DS] Why is it necessary to activate bundles offering services? [message #128065 is a reply to message #127920] |
Mon, 30 March 2009 02:50 |
Hi Vik,
Note also that a classloader is not created immediately on activation of
a bundle if that bundle does not declare an activator and all offered
services are lazy (default).
Cheers
/Eike
Víctor Roldán Betancort schrieb:
> Hi everyone,
> Doesn't Eclipse's Extension Point work that in such a lazy way?
> Thanks in advance,
> Víctor.
Cheers
/Eike
http://www.esc-net.de
Re: [DS] Why is it necessary to activate bundles offering services? [message #128078 is a reply to message #127953] |
Mon, 30 March 2009 09:05 |
Stefan Messages: 316 Registered: July 2009 |
Victor,
AFAIK, DS doesn't use proxies (in contrast to Spring DM). Parts of R4.2
should be in CVS HEAD, too.
I found the slides in [1] very helpful.
Stefan.
[1]
https://www.gpublication.com/eclipse/#requestedContent=conte ntID://EclipseConferences/EC2009/245
> Chris,
> Cheers
> Víctor.
>>> Hi everyone,
>>> and issue I don't quite understand. Apparently, we need to activate
>> ACTIVE state. Extensions are available in the RESOLVED state.
>> STARTING state (lazy activation). Therefore, you can add:
>> as long as DS is started of course!
>> Cheers,
Re: [DS] Why is it necessary to activate bundles offering services? [message #128176 is a reply to message #128078] |
Tue, 31 March 2009 11:05 |
Stefan,
thanks for the hint. I'm using ganymede, so HEAD is not an option :(
I already created a special bundle that analyzes all registered bundles
and activates them if they define services component. Is not the best
solution, but at least is better than setting all service-providing
bundles to start at eclipe's startup!
Thanks for the slides, quite interesting!
ViK
Stefan Roeck escribió:
> Victor,
> Stefan.
> [1]
>> Chris,
>> something like a "proxy" to a service, so as soon the service is
>> demanded, the bundle gets activated and the proxy is resolved. I read
>> the OSGi spec for DS but couldn't clarify this issue. Only when I
>> looked at the code and saw (if bundle.getState() == Bundle.ACTIVE)...
>> Cheers
>> Víctor.
>>>> Hi everyone,
>>>> of this. Wasn't declarative services all about lazy registration?
>>>> What's the concept of delayed service for then? Am I missing
>>>> something here?
>>> Cheers,
Re: [DS] Why is it necessary to activate bundles offering services? [message #128188 is a reply to message #128065] |
Tue, 31 March 2009 14:47 |
Eike,
thanks for comment. This is indeed quite interesting: it would imply
that, if properly defined, eager start of our bundles won't cost that
much :D (I didn't know, but it seems, according to the slides Stefan
pointed out, creating the classloader is a bit expensive).
ViK.
Eike Stepper escribió:
> Hi Vik,
> Cheers
> /Eike
> http://thegordian.blogspot.com
>> Hi everyone,
>> Thanks in advance,
>> Víctor.
Current Time: Sun Oct 06 08:34:05 GMT 2024
Powered by FUDForum. Page generated in 0.03644 seconds
