how to delete extra plugins inside eclipse? [message #127060] |
Sat, 31 December 2005 09:18 |
Originally posted by: murley.murley.murley
I had downloaded a exta plugin, and it runs properly in eclipse. Now i
want to delete the plugin inside eclipse, how can i do that (not delete file
directly from the plugin directory)?
My eclipse platform:
eclipse SDK 3.1
Thanks.
Re: how to delete extra plugins inside eclipse? [message #127173 is a reply to message #127060] |
Mon, 02 January 2006 09:33 |
Originally posted by: rmidas.yahoo.com
murley wrote:
> eclipse SDK 3.1
> Thanks.
go to,
Help > Software Updates > Manage Configuration
find your plugin there and select disable from the context menu
eclipse will ask you about a restart
after that you will be able to uninstall it from the same place
procedure does not always work but you could give it a try
FUDForum. Page generated in 0.08975 seconds
